Question about Jarden Health o Meter HDM545DQ1-37 Weight Tracking Scale
After replacing the battery for HDM545DQ1-37 the display is showing only "E".
#324 chak printer alram cameing
when you power on your fax machine and display show DATA ERROR its mean that 3 volts battery on the main board expired and lose all data fax number, logo and related with cartridge ink data so first of all you replace the battery. (this is a pure technical job and if your are not a technician you must take help of a technician)
After replacement of battery you power on fax machine and press
function key display show DATA REGISTRATION
press # display show #1SSSW
press left arrow key one time display show TEST MODE
press start/copy key display show TEST MODE [1]-[8]
press # display show AMI MODE
Press 7 display show FACULTY 1-6
press 5 display show INK CHECK 1-2
press 2 and start key
display show INK=YES and INS (ink level any one within 100 for example 42/205 you just remember first two digit of lest side)
press stop display show FACULTY 1-6
press 6 display show LOST INK CHECK
press start/copy key display show LOST INK CHECK [1]-[2]
press 2 display show SET LOST CNT
press start/copy key display show LOST INK= (here you enter the last left side two digit which you remember for example 42)
press stop two times
and unplug fax and plug again now your fax machine is okkkkk
NOTE:- If you can't get the success first time you must try until you get the success because this is the only way to get success
Jun 11, 2012 | Canon FAX-L250
I pod displays "connect to power" then shows
It sounds like your battery is bad. They can be replaced readily easily. Batteries an be found on eBay for as little as $5 and directions to replace it can be found here:
http://www.ifixit.com/Browse/iPod
Jul 26, 2011 | Apple iPod MA446LL/A MP3 Player
The wall timer to my outside lights says "noop"
noop means no operation.
This usually shows on older timer.
You posted under Intermatic ST01C.
Other have written to fixya with same symptoms.
CR2 battery might be bad. Replace battery.
Replace battery quickly and current time remains in memory.
Battery out of timer longer than 30 seconds, then current time and day disappear.
Programming remains inside timer forever with or without battery until timer is reset.
Others report they changed battery and timer never came back to life afterward.
http://waterheatertimer.org/ST01C-program.html#battery
Manual troubleshoot section also suggests resetting timer, and then re-programming.
Manual:
http://waterheatertimer.org/Intermatic-st01c.pdf
To reset timer, hold down ON-OFF button and push small round reset button with paper clip.
Push reset for 3 seconds and release.
Keep holding down ON-OFF until INIT shows on display.
Release ON-OFF and wait for display to show.
If display never shows, then battery is dead or timer is bad.
ST01C comes with 1 year limited warranty.
Advantage of Intermatic battery operated timer is simple wiring, plus astronomic function (dawn-dusk).
All in-wall timers have advantages and disadvantages.
Nextag shows new ST01C sellers
http://www.nextag.com/intermatic-st01c/products-html?nxtg=90ff0a280507-C4F7FB4C58223A3F
Page also shows Intermatic EI600 astronomic timer that comes with 5 year limited warranty
Nov 29, 2010 | Intermatic Inc. ST01C Digital In-Wall...
On my intermatic HB88RC,I replaced the battery because it was dead and now it shows 44:44 on the display can this be reset?
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers/hb88rc.aspx
HB88RC is 7-day plug-in digital outdoor timer that uses AA battery installed on back of timer to power the display.
People write to fixya frequently report Intermatic timer stops working after replacing battery.
To check if your timer is still functional:
Press and hold clock button.
Press Day button until current day shows in display.
Press Hour until current hour shows in display
Press MIN until current minute show in display
Release clock button.
If current time shows in display, then timer is probably still good.
To set programs:
step 1) Press PROG button until 1 and ON show on display.
This is program1 ON.
Press day button until choice of days shows for program1 ON
Press hour until hour for program1 ON shows
Press MIN until minute for program1 ON shows.
step 2) Press PROG button until 1 and OFF show on display
This is program1 OFF.
Press day button until choice of days shows for program1 OFF
Press hour until hour for program1 OFF shows
Press MIN until minute for program1 OFF shows.
step 3) Press PROG button until 2 and ON show on display
Repeat steps above to set program2 thru program7
step 4) When programs are set, press CLOCK button to return to current time
step 5) add a comment for more help
Nov 18, 2010 | Intermatic HB88RC - 7-Day Programmable...
Stopped working and all digital figures displayed!
If the display is not dim the battery is probably OK. Try removing the battery, test it anyway, and after a minute or two replace it (I'd use a new one anyway) and see if the problem is cleared. Sometimes just power cycling will "reboot" the watch. If that doesn't do it I'm afraid it will need to visit a Breitling service center.
Apr 15, 2010 | Breitling Aerospace 455 Wrist Watch
Display battery level
Well, I tried pressing and HOLDING down the mode button. The battery level display miraculously showed up. I’ve also read (yahoo answers) that battery level display will show up automatically when battery is low. Hopefully I won't have to do this every time I recharge the battery.
Mar 17, 2009 | Kodak EasyShare M1033 Digital Camera
Phone Switches off on its own, even though the battery is new
DOES IT SHOW FULL BATTERY POWER on the DISPLAY?
If it does, the phone device itself could be broken - take steps to get it replaced.
If it doesn't - if it's not the battery, it's the charger. Try a different charger - make sure while it's plugged in - the display shows that the charger is charging it, blinking - or bars going up or down, or a thunderbolt on the display etc. It could still be the battery - there are such things as OUT OF THE BOX FAILURES, where you get a dud for a battery.
All in all, trade someone for their battery, or their charger - if you dont wanna buy one at first. See if the problem follows your old battery etc.. Buying a battery or charger is usually like $5 on ebay, so that's much better than replacing the phone.
Mar 12, 2009 | Cell Phones
Razr external display
Has the phone ever displayed this information?
First try Enabling Caller ID, if that doesn't work then Shut Down the phone, remove the battery, then replace the batter and try again.
Dec 28, 2007 | Motorola Mobility RAZR V3
Jarden Health o Meter HDM545DQ1-37 Weight Tracking Scale Logo
60 people viewed this question
Top Jarden Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Jarden Exercise and Fitnes Expert? Answer questions, earn points and help others
