Question about Breville ESP8XL Espresso Machine
No rubber fitting on steam arm
We have lost the rubber fitting on the steam arm. Do we need it? & if so where can we get one?
Terry , Brisbane.
  • 2,976 Answers
The rubber fitting does 2 things. It splits the steam and it keeps the end from bumping too hard. You don't need it but make sure you clean the steam tube well.
Posted on Jan 25, 2009
    Problem Solver:
  • 7 Answers
You can buy it from Breville. I would recommend stocking up on a few since they are quite cheap anyway.
Posted on Mar 18, 2009
2 Suggested Answers
  • 32 Answers
SOURCE: rubber fitting for steam arm
You really don't need it. You should have a cloth nearby to clean the wand when you're done. So if for some reason you need to move the wand (and with it's meagre rang of mobility I don't know why you would) be sure to grab it with the cloth because it gets really hot. The rubber thing is just there to avoid lawsuits I'm sure.  USA USA!
Posted on May 12, 2009
I have a lauraStar Magic Evolution and Steam is escaping around the filling cap. Alot What do I need to do
rubber fittings destroyed in internal compartment,ervice by expert professional
Jan 12, 2015 | Irons
When steaming the milk more steam comes out near the nut where the steam arm connects to the machine
If its coming out of the arm at the top and not out of arm where it should be coming out, the product arm is faulty. the rubber washerin inside the head must not be sealing the arm.
Either A. open it up and check for youself if the rubber washer is in the correct place
B. ensure the arm is screwed on fully
c. Go get the arm replaced.
Oct 19, 2012 | Coffee Makers & Espresso Machines
Delonghi Magnifica My steam arm drips when I make coffee.
I initially replaced the o-rings in the pipe/valve assembly. It didn't work for long (not correct size o-rings probably). I then bought a new pipe-valve unit. To replace you need to pry off the stream handle (chromed plastic). It only fits one way on the axle (so take notice when replacing!). Then remove back and side covers (6 screws all at the back). Then remove top (2 screws each side at the front and a couple at the back). Then the front panel should be lose. (Instructions based on a slightly different model)
Mine made better coffee after I fixed the leak! A large portion (perhaps 25%) of the water intended for the coffee went via the steam wand straight into the drip tray, which is not good.
Oct 15, 2012 | DeLonghi Magnifica 3300 Espresso Machine
Steam wand on Vienna plus detached from arm
Lets first make sure you have all the parnello wand parts. The nut, hard plastic gasket, soft rubber gasket, the inner wand then the sleeve and the center in the sleeve. When putting it back together find the notch on the metal steam wand and slide the nut onto the wand, then add the rest in the order above.
Jun 02, 2012 | Saeco Vienna Plus Espresso Machine
It is sticky and looks like glue.It looks gooey
Hello :
Here I'm going to tell you the basics of cleaning your Rowenta iron :
Things You'll Need:1:Rowenta Soleplate Cleaning Kit
2: Ironing board
3:Clean, dry cloth
4:Two cotton terry cloths, such as washcloths
Now to the cleaning :
1:Pour out any water from the iron. Turn the steam iron on to the "Cotton" setting, which is the one with three dots on the settings dial.
2:Cover an area of the ironing board with a clean, dry cloth. Fold one washcloth or other piece of cotton terry cloth in half and place it onto the cloth on the ironing board.
3:Dispense a 2-inch long daub of cleaning solution onto the terry cloth. Run the heated iron over the cloth directly on the cleaning solution. Move the steam iron in a circular motion over the cleaner on the cloth for a minute or two.
4:Remove the steam iron from the cloth. Carefully wipe any remaining cleaning solution from the soleplate using the second terry cloth.
5:Add water to the steam iron. Turn on the "Steam" or "Burst of Steam" feature. Run the iron over the clean, dry cloth on the ironing board to ensure the cleaning product is entirely gone from the soleplate.
Apr 20, 2010 | Rowenta DX6700 Iron
The steam spout (pannarello) will not stay on
there is a rubber sleeve inside, and also a hard plastic olive (like a wedding ring). When tightened, the hard olive compresses the rubber sleeve and it grips.
If you lose the plastic olive, the rubber remains uncompressed and the pannarello will blow off.
The olive is about the size of a wedding ring for a person with a 5mm finger (impossible I know - but the shape is like a tiny black wedding band all the same.).
Oct 31, 2009 | Saeco VIA Venezia
Lost a piece of the black plastic steaming wand
Check with WholeLatteLove, yes I know the only have gaggia parts, its the same thing.
May 07, 2009 | Saeco VIA Venezia
Rubber fitting for steam arm
Jan 25, 2009 | Breville ESP8XL Espresso Machine
How to use the self clean feature on a tefal steam iron
I cleaned mine with alcohol and clean terry cloth. Took some work but it eventually got clean.
Dec 24, 2008 | Irons
Looking for a rubber ring for the Saeco Via Venezia. It fits on the steam arm to keep the plastic steam sleeve in place.
you can find that ring to home depot or any other hardware store.Is called o-ring and if you bring your little part with you someone will help you to find one in home depot.This part is also used in air compression department for airgun atec.
Pls don`t forget to rate your experience
Sep 03, 2008 | Saeco VIA Venezia
Breville ESP8XL Espresso Machine Logo
110 people viewed this question
Top Breville Coffee Makers & Espresso Machines Experts
Steve Banks
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
