Question about Whirlpool 24 in. GU1200XT Built-in Dishwasher
Washer is overfilling
Water leaks under door ,,dishwasher is 6 years old first problem
    Novelist:
  • 166 Answers
If your dishwasher leaks, check these:
Main tub seal
Door gasket or seal
Water-inlet valve
Hoses
Main tub seal
Note… If the main motor of your dishwasher is mounted vertically, beneath the center bottom of the dishwasher, the following instructions probably apply to you. But if your motor is mounted horizontally, the pump isn't serviceable--you need to replace the entire pump and motor assembly.
The main tub seal is beneath the drain impeller. It prevents the water in the dishwasher from leaking out near the shaft of the motor. To get to the seal, which is inside the dishwasher, remove the:
1. Lower rack
2. Spray arm
3. Spray arm support
4. Wash/drain impellers
Then pry the seal out of its housing and replace it.
Door gasket or seal
Over time, door gaskets and seals harden and lose their ability to seal properly. You can't repair the seals. You need to replace them if they've begun to leak.
Water-inlet valve
The water-inlet valve, itself, seldom leaks. But, the water-supply line from the house and the rubber tube leading from the valve to the inside of the dishwasher may leak. Tighten or repair/replace these as necessary.
The water-inlet valve could mechanically stick open. When that happens, the water continues to flow into the dishwasher, which then floods your kitchen. Turn off the water supply to the dishwasher, and replace the valve.
Hoses
Behind the lower access panel on your dishwasher are several rubber or plastic hoses. If the leak appears at a connection, try a new clamp. If that doesn't work, replace the hose.
thanks for using FixYa
Posted on Feb 11, 2009
Frigidaire pld2850rdc1
It is likely that the door seals on an 8 year old dishwasher could be ready for replacement.
Dec 21, 2013 | Dishwashers
My dishwasher is leaking water from the front door
The water inlet level setting could be faulty and thus "overfills" the washer with water. The water level is senced via a plastic tube feeding an ajustable switch. Sometimes the plastic pressur sence pipe gets clogged and water level is then not correct. The switch can have burnt contacts and might need replacing.
Jan 23, 2010 | Dishwashers
Door leaks at the bottom of my ge profile dishwasher
1 has the machine been pushed into the cupboard hole,this will push the door away from the front of the machine,does it hit the trim around the opening before the closeing?pull out check under are the legs still straight,some you can remove the lower front panel to look under
Dec 02, 2009 | GE Profile PDW8400J Built-in Dishwasher
I have ge dishwasher thats 3 years old and I'm having problems with it leaking from the bottom of the door. I replaced the seal once but I can't tell what else the problem could be. Any suggestions?
it could be overfilling. check the overflow float inside. if it is stuck down, the water level will get to high. the seal is not meant to be under water. it just stops splashing water. if it moves freely, it is okay.
Oct 26, 2009 | Dishwashers
Water leaking onto floor noted after dishwasher cycle
this could be many things,if its only happening when you run the unit i would look for either a door gasket,pump seal,or your lines going to & from the pump these are your most common leakage problems(if you don't know which is which then contact me & we'll see if we can isolate it.thanx for using fix ya
Nov 22, 2008 | Maytag Dishwashers
Dishwasher problem - no water in the tub
hi.
The sensore key that control the door of dish washer may be show that the door is open & it doesent let that water come to machine . you should checke the key
Nov 09, 2008 | Frigidaire 24 in. FDB1250RE Built-in...
KitchenAid Dishwasher Leaking from under Door
I had a similar problem with a KUDM25SHWH1 dishwasher. Rubber seal looked fine. I found an incredible tip on another fixi it site. One possible problem iss the pump cover screws may have worked loose and is squirting water directly on the door seal. Man that was it! I saw a couple of looses screws and a small portion of the pump cover gasket showing. I loosened the pump top, reset the gasket tightened it all down...no leaks! The pump I refer to is located directly below the spray arm inside the washer. Easy to get to. Another tip was to look for a split sspray arrm that may spray water directly into the door seal.
Nov 04, 2008 | KitchenAid 24 in. KUDS25 Built-in...
Fisher and paykel water leak
Code F1 indicates that Flood switch has been
activated which explain why you feel that it is overfilling.
Water leaking
Drain hose disconnected
from waste pipe.
Reconnect the drain hose to the waste pipe.
Supply inlet hose not
properly connected.
Ensure the inlet hose is connected securely.
Other leaks. Turn water and power supplies to the
Dishwaher off.
Mar 30, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Leaking door (Running Water)
being in the uk i dont know this appliance, but the fault is probably that it is overfilling caused by crap in the airchamber or the hose leading to the pressure stat blocked or a split in this hose
Apr 15, 2007 | GE 24 in. GSD4630Z Built-in Dishwasher
Whirlpool 24 in. GU1200XT Built-in Dishwasher Logo
199 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
