Question about Onkyo TX-DS777
TX-DS777(B) A fault has manifested itself in that after switching on the receiver (perfect picture and sound) the video disappears after about 20 secs and cannot get any output at the MONITOR. If you switch off the receiver and a couple of minutes later switch it back on the same thing happens. I took it to the local Hi-Fi shop anf they confirmed that it is faulty but were reluctant to work on it. Can you tell me where I can get the circuit diagrams or the maintenance manual or even better a repair shop near. I am in Dunfermlnie Scotland.
  • 139 Answers
It Does not sond to difficult Check the Connection on the Video out on the Board inside the Reciever Sometimes Because of the Weight of the Video wire it will cause a Circle Break,As the Reciever is turned on it Cold and the heat,as the unit warms up Expands the Break causing loss of Pix Good Luck TTech
Posted on Jul 20, 2007
SOURCE:
Tx-ds777 no sound from front speakers on a speakers work on b but if I run a and b the center and surround stop working
Hi MJ, If you run your B speakers you will drop your 2 surrounds as the B speakers are meant to be used in a different room. I would suggest that you give us a call so that we can try some troubleshooting, please call our Product Support Team at 800-229-1687, Thanks, JT
Aug 19, 2015 | Onkyo TX-DS777
Can i connect an ipod to my Onkyo tx-ds777?
You should be able to do it with the right adapter cable.
Jul 21, 2014 | Onkyo TX-DS777
Onky TX-DS777, no sound from speakers
Are the speakers selected for A or B or AB check the speakers by using a 1.5 volt batter on the cable going to the speakers, if you get a sound from the speaker, you know they are ok, if not, speakers are faulty.
Apr 01, 2014 | Onkyo TX-DS777
Onkyo TX-DS777 does not retain settings after power loss
No internal battery, a large "SuperCap" on the main board acts as one. Look for C8007, 0.1 F, 5.5V.
Apr 26, 2010 | Onkyo TX-DS777
Onkyo TX-SR606 Reciever - 20 sec after power on, screen is green
The HDMI version in your receiver is 1.1 or 1.2 which will not pass video as it should. It's not Onkyo's firmware at issue, it's HDMI and in all receivers up to 2008 model year this is a very heated problem! The only fix is to run FIOS directly to the TV via HDMI and run it's audio to your receiver with Digital Coaxial or Optical. Hope this helps
Jun 11, 2009 | Onkyo TX-SR605 Receiver
Remote problem on onkyo TX-DS777
ya thats the universal remotes having list of codes .
first you set up with the code that should match for your revelent make and model of your dvd player.
so you just go through with codeing list that accompany with purchaseing of universal remote.
and set up with code particularly for your make and model of your dvd player.
and finaly try with your dvd player.
ok all the best.
Oct 08, 2008 | Onkyo TX-DS777
Tx-ds777 onkyo receiver codes
Hi Firewall
What remote do you currently have that you need the codes for?
regards
Graeme
Jan 18, 2008 | Onkyo TX-DS777
Synchronisation problems
try to change the sound setting of your reciever.. try all options of sound setting..
Dec 27, 2007 | Onkyo TX-DS777
Onkyo receiver TX-DS777
You have a bad amplifier left or right whichever pops if both sides pops then it both amps
Dec 25, 2007 | Onkyo TX-DS777
Tx-ds777
Same thing happened to our TX-DS777.
Took it to a locate electronic comany and they told us it was the
DSP board gone bad. Est 425.00 to 450.00 to fix.
Aug 16, 2007 | Onkyo TX-DS777
Onkyo TX-DS777 Logo
79 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
