Question about Linksys Rangeplus Wireless Pc Adapter
Linksys Rangeplus works fine for short periods
My Linksys Rangeplus works fine for at times hours then it will drop and it cannot see any wireless connections. But after restarting the computer the contection works. Any suggestions?
    Problem Solver:
  • 6 Answers
Improve your PC's cooling system and your wireless adapter will work fine. you can attach a USB cooling fan to do the trick.
Posted on Jan 25, 2009
Linksys WRT100 won't connect wirelessly
Has the adapter in the laptop been enabled?
Ryan Frame
Creative Energy Associates Technical Center
Sep 05, 2009 | Linksys RangePlus WRT100 Wireless Router
At the end of installing rangeplus wireless router, I got a message that I had no internet connection but my internet works fine when I hook it right into the computer
If you have ADSL (high speed over the internet) you might have to clone your mac address or call your provider to reset the mac address assigned to your modem. If you have Cable internet most of the time just resetting (power cycle) the modem will fix the issue.
Aug 21, 2009 | Linksys Ultra RangePlus Wireless Routr...
Linksys wrt160n drops connection
Did you try the firmware upgrade ? http://www.linksysbycisco.com/US/en/support/WRT160N/download.
The updated firmware seems to have fixed a few wireless issues.
Hope this helps
Thanks
Ranjit ranjit@supportminds.com
Aug 11, 2009 | Linksys Ultra RangePlus Wireless Routr...
Wireless signal problem.
Try upgrading the firmware of the router.
Apr 11, 2009 | Linksys RangePlus WRT100 Wireless Router
Linksys rangeplus drops wireless connection ever 5-10 mins
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router’s firmware. For instructions, click here
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 19, 2009 | Linksys Ultra RangePlus Wireless Routr...
Wireless linksys
If the setup CD is not working fine for you , It will be better for you to call the Linksys tech support and they can walk you through wtih the process on how to manually configure the router and set it up as a Home network, this is the Linksys phone number 800-3267114...
Hope that helps.........
Aug 11, 2008 | Linksys Wireless-N WRT150N Router
2Wire USB 802.11g adaptor on XP: drops wireless periodically
when you get your computer connected, set the wireless channel to 6 and disable wireless zero configuration that will stablize your connection
Dec 03, 2007 | 2wire (1000-100052-000) 802.11g/b Wireless...
Linksys Rangeplus Wireless Pc Adapter  Logo
79 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
