Question about DeLonghi Ovens
Delonghi Electric oven LMFS60
Need specifications for LMFS60 electric oven
  • 3 Answers
SOURCE: DeLonghi Debige 2440 Electric/Gas Double Oven Fan Failure Light
I had the very same problem. I slid the oven out of the wall about 6" or so, unplugged it, plugged it back in. It worked. I'm not sure if I jostled some connection, or if unplugging/repluging it in reset some sort of circuit fault.
Posted on May 30, 2008
  • 833 Answers
SOURCE: DeLonghi doubleoven electric cooker ESS602
It is hard to know exactly from here. I'd suspect the heater element is open before anything else. If you can get to the terminals of the element itself (unit unplugged!, element disconnected on at least one side), then test for resistance with an ohm meter...available at any electronics shop or large retailer like Radio Shack, Sears Hardware or the Depot.
If there is none, the element is bad...hint: defective elements often have an area on them that is discolored differently from other parts. Food particles, particularly grease splash, will cause burnout. Terminals or connectors that are loose or corroded will cause non-function or failure. Look for those issues. Make sure all connections are tight when you're finished.
Posted on Jun 16, 2008
SOURCE: DeLonghi ESS601 electric oven
We just moved in to a place that has this oven, if you use the setting with the fan with a circle round it, seems to get hot! Don't know what the other is for though!
Hope it helps!
Pete
Posted on Jun 24, 2008
SOURCE: Need wiring diagram for old 1960's General Electric Wall Oven
55de40b.jpg Hopefully this will help. Don't know if it is the same model, but it is a 60s GE built in oven.
Posted on Jan 10, 2009
  • 8 Answers
SOURCE: Need serial number for my electric coronet integra wall oven
ther should be 4 screws holding the wall oven in you need to take them out and puul the oven out just alittle and look on the sides,be carefull not to far out
Posted on Sep 01, 2009
Testimonial: "I realise that the serial number is on the back of the oven,but was hoping for another solution as that's a job beyond my capabilities being over 60."
Hi my delonghi double oven keeps tripping the electric power supply it trips on the top oven when using the grill and the bottom oven on oven
I would have a electrician look at the breaker switch as being in need of replacement. They do weaken over time and cannot handle the load that they were designed to carry when brand new.
May 13, 2016 | DeLonghi Ovens
How do i clean inside my delonghi glass door the inside
if you pull the oven out a little bit and look under the the door there should be 3 screws you only need two undo one on each side but when undoing the last screw hold the bottom of the door tight as it will fall when you have door frunt off job done ok
Oct 12, 2012 | DeLonghi DEBIE24SS Stainless Steel...
The Pilot Light on my Delonghi DEBIE 24 SS Electrical is on even though the oven is off - any idea how to correct this?
The pilot light stays on most none electric lighting for gas appliance, this is normal if you do not have an electric ingnition on your oven.
Hope this is helpful
john
May 17, 2011 | Ovens
I have a elecric delonghi oven with a gas hob with 6 burners. the oven does not work at all no heat. the light comes on but no heat. the turkey is stuffed an no hat to cook it HELP PLEASE
if the temp indicator light comes on and/or oven fan circulates then its most likely the heating element. if neither then its thermostat or selector switch...
Dec 22, 2009 | DeLonghi DEBIGE 2440 Electric Double Oven
The fan works but oven does not heat up
If the fan is working o/k, and it it is an electric oven, then the oven element has probably failed.
It is usually located at the rear of the oven compartment behind a removeable cover.
Hopew this helps you.
Dec 09, 2009 | DeLonghi DEBIGE 2440 Electric Double Oven
Hope it helps!
Pete
Jun 20, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
Feb 02, 2008 | DeLonghi DEBIGE 2440 Electric Double Oven
Re:Electric Convection oven does not heat up. Convection fan works, light works.
It is probably and electrical service issue. If this is a North American unit, it uses two electrical circuits to provide power. You must find and reset the breakers and check that the wiring is operating as intended. Less likely: It could also be a manufacturing defect. DeLonghi uses screw compression connections on some products. Sometimes, they don't work well.
Dec 20, 2007 | DeLonghi DEBIGE 2440 Electric Double Oven
Ovens Logo
177 people viewed this question
Top DeLonghi Ovens Experts
ashburton
Naftali Haskell
Level 1 Expert
Jason Harris
Jason Harris
Are you a DeLonghi Oven Expert? Answer questions, earn points and help others
