Question about Delta 2567-212/215CB NeoStyle Chrome Bathroom Faucet
3 Suggested Answers
  • 2841 Answers
SOURCE: Fix delta bathroom faucet
The handles just pull off. Make sure the set screw is completely turned all the way out. It is more than likely corroded. Rock it back and forth while at the same time pulling up. It will eventually come off. Click link for view. http://www.deltafaucet.com/kitchen/details/2256SS-216SS.html
Posted on Dec 31, 2009
  • 17 Answers
SOURCE: Delta 2555-216 Victorian Double-Handle Centerset
If you notice right below the handle,there should be a small opening where ,by using an allen wrench you should be able to remove handle giving access to the stem retaining nut ......CAUTION... be sure cutoff valve is turned off(both hot and cold cutoffs.... under lavatory sink before removing..........unscrew retaining nut and remove stem.....hope that helps......
Posted on Sep 01, 2011
Where is the grub screw that has to be removed as I can't find it?
plumbing - How do I remove a stuck faucet/tap cover ...
diy.stackexchange.com/questions/.../how-do-i-remove-a-stuck-faucet-tap...
Apr 18, 2011 - Anybody can ask a question; Anybody can answer; The best ... There are total six faucets in a bathroom, two made into a bathroom basin ... The other possibility is that there's a small plastic "decorative" cap covering the screw.
How-To: Replace A Shower Faucet Cartridge ' Toolmonger
toolmonger.com/2009/12/01/how-to-replace-a-shower-faucet-cartridge/
Dec 1, 2009 - In many modern shower faucets like Delta and Moen (which is what I have) .... About a year ago, one of the bathtub faucets in my other bathroom jammedopen. .... the exact faucet I have in my shower, so you answered my first question, ...I can tighten and loosen the screw but the handle just won't come off!
Problem Removing Handle Off Of Delta Monitor 1400 Series ...
www.diychatroom.com/.../problem-removing-handle-off-delta-monitor-...
May 20, 2009 - 15 posts - ‎12 authors
... from a Delta Monitor 1400 series tub/shower single handle faucet. ... sorry for the REALLY sxxxxx question. which way to turn (loosen) the set screw. ... only suggestions i have on the issue. when a setscrew will not back off i ...
REMOVAL OF STUCK CURVED FAUCET HANDLE WITH HEX SCREW ' DIY Forums
www.diyforums.net/removal-of-stuck-curved-faucet-handle-with-hex-sc...
Feb 03, 2016 | Home
How do I repair a leaking mixer tap?
take the set screw out and repair the plastic washers inside it
Aug 31, 2014 | Delta Bathroom Basin Single Handle Chrome...
Leaking faucet
Remove the handles. See if the chrome slip nuts holding the stems in are corroded. If they are, the cartridges may not be fully seated or the o -rings that seal around the cartridges may need to be replaced. If either of these is the case you can tell for sure by turning the stems to the on position with the handles removed and looking for water seeping around the cartridge. If none of the above is the cause then check to see if the aerator (screen on the spout) is loose or corroded sending a light spray back towards the faucet body that looks like a leak. If this is the case remove and clean the aerator, then reinstall it making sure not to cross thread it. If none of the above, replace the faucet. Be sure to call Delta first before replacing because they have a lifetime warranty and you just might get your faucet for free!
Apr 05, 2013 | Delta Faucet Delta 2530-24 Innovations...
My delta two handle bathroom faucet the cold water handle is hard to operate tried wd40 on it and it worked for a while but it got hard to operate again
They have a lithium faucet grease for stems at hardware stores Home depot or Lowes. It a gease to help free up for movement of handle if they don't have it try a Plumbing supply house they should sell to public.
May 04, 2010 | Delta Faucet DELTA/PEERLESS FAUCET CO....
Fix delta bathroom faucet. How do you get the chrome handel off after you removed the allen screw. Doesn't want to come off with reasonable pressure/coaxing.
Dec 31, 2009 | Delta Victorian 2155-SSLHP Bar Two Handle...
The unit has a croosbar connecting the hot and cold water. How do you remove the crossbar to replace the faucet
Do we want to remove the faucet from the top of the sink?
First shut-off the water via the two valves under the sink. Then un-thread the hoses from the bottom of the sink. Sometimes it is possible to do with ordinary house tools but more than likely you will need to purchase a basin wrench for about $10. This wrench will allow you easy access to the bottom of the faucet.
Then, using the same wrench, un-thread the nut that is threaded on the same threads as the hose. This nut if probably pretty tight and will take some effort.
Replacing is the exact opposite except when replacing be sure to use plumbers putty on the bottom of the faucet as a means to keep water from running under the faucet base and ruining your cabinet.
May 21, 2009 | Delta Faucet 2520 Classic 4'' Centerset...
Can I replace delta faucet t2710 with Delta SBS 84010BN ?
yes . when buying the faucet dont forget to buy stainless steel suply lines for water line connection.
May 17, 2009 | Delta Faucet Delta T2710-LHP Classic Roman...
Delta 2567-212/215CB NeoStyle Chrome Bathroom Faucet Logo
70 people viewed this question
Top Delta Plumbing Experts
Donni Steen
Ed Mac
bwbconstruct
Level 1 Expert
Are you a Delta Plumbing Expert? Answer questions, earn points and help others
