Question about Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection
F8E0 low fan speed. Brand new just got installed. What does that take to fix
How do i set up brand new oven , the fan comes on but no heat
If your oven is brand new, just check if it's properly connected.
You are not supposed to set up ovens, . Ovens are not as smartphones or computers. They are supposed to work when you install them.
So if it won't work, call warranty service
Oct 31, 2015 | Ovens
My Jenn Air double oven giving error message saying low fan speed and will not work! Any suggestions?
It may be possible that the fan blades have built up grease and dust causing a drag on the blade. Clean the fan blade and see if it goes away.
Oct 02, 2014 | Jenn-Air Ovens
NEED TO WIRE A OIL FURNACE FAN FOR LOW SPEED IN HEAT AND HIGH SPEED IN COOL
Okay, I've got an answer for you.
If you get a Fan Control Relay that is DPDT, I think you can wire the Low Speed of a two-speed motor to the first N.O. contact, for Heat.
When the Relay trips, the N.O. contact will close, and the fan will run on low.
If it's a two-speed fan, these fans have two windings, the first for low, the second for medium, and both for High.
Wire both windings to the N.C. contact on the second half of the relay.
That way when the temperature drops below your setpoint, both fan windings will be energized and the fan will go nuts.
Of course, this means the fan will NEVER shut off.
And I still don't know why you need high speed in the Cool setting, when your thermostat isn't kicking the Relay.
Oct 10, 2012 | Honeywell R8285B1038 40 VA Fan Center with...
Two fan speed. When do I use the high and low fan ie for what type of cooking?
the fan is just used as you please, if the food your cooking is more smokey , use a higher setting,, if the lower one keeps the air clear,, thats good enough,,
Aug 08, 2011 | Ovens
What does f8e0 mean on my oven
Ok, this is very common with this model, and it is the main controller board. You need to call a service, man, and ask for a "Quote",
May 01, 2010 | Ovens
Why is error code F8E0 appearing on my Baumatic B205SS oven and alarm sounding
I have a B205SSA and the error code F8EO is appearing eveytime i have used the oven, i then have to reset it by turning off and back on again at the mains.
Any ideas? Cheers. Rich.
Mar 03, 2010 | Baumatic B205SS Stainless Steel Electric...
Ariston oven error code F8E0
solved by rotate the temperature knob!!!
maybe would be a problem of the potentiometer or knobe of temperature
Jun 28, 2009 | Ariston Technologies Ovens
Convection fan
This is caused by a faulty wiring connector. It is a gray iec type connector there will be 8 wirs connected on each side of it. You can get a replacement from blodgett directly. Or what I have done is to eliminate the block using solderless **** connectors.
Aug 06, 2008 | Blodgett (ZEPHAIREG-DOUB) Double Oven
Neff Double oven 1410/1420
I think you got it david ..
check voltage to the motor at low and high.. if voltage is good.. them it must be the motor...let me know
Jul 07, 2008 | Ovens
Bottom oven not working
If its brand new, most possibly the electrician did not bridge the mains connection. It sounds like an installation fault. There is usually a jumper between 1-2-3 on the L connection on the mains, and a jumper between 4-5 on the N connection. Oshie
Nov 27, 2006 | Gaggenau EB294/295 Electric Double Oven
Jenn-Air 27 in. Electric Single Wall Oven with Multi-Mode Convection Logo
325 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
