Question about Alpine Car Audio & Video
Alpine amp mpr f240 360 w
Mpr f240 360 w
My E350 2006 don't go over 40 mpr and don't switch
I have the same problem on my 2007 Mercedes E350, and cant get an accurate answer from any body, every body tell me different things even Mercedes Dealer. Help me!!!
May 01, 2012 | 2007 Mercedes-Benz E350 4Matic Wagon
Amp light on my MPR-M1000 keeps flashing
HI,
Disconnect the speakers fist. then check the amplifier light flashing or not. If not then then any of the speaker is faulty. If the amplifier's Light flashing even after removing the speakers then any one of the amplifier stage inside the amp is faulty. By blinking it shows that its in protection mode.
Normally the out put transistor can become faulty. Which can lead to the amplifier to protection mode to avoid damages to the speakers connected to it.
If its not speakers then you should consult the Alpine service centre or any professional technician. Because repairing such type of amplifier should done by a very qualified person. If not it will lead major defects which will make the amplifier scrap.
Ajin
Apr 27, 2012 | Alpine Car Audio & Video
Poor reception with Alpine cda 7892
I found the manual at Alpine.com.http://vault.alpine-usa.com/products/documents/OM_CDA-7892.PDF
Apr 15, 2012 | Alpine CDA-7892 CD Player
What transistor would be the replacement for the small transistor in my alpine mpr-m1000 called D600k Y 834? Where could I get it and what would it be called?
The transistor is LIKELY a 2SD600 which google brings up data sheets for you.
It is an Epitaxial NPN 100/120 volt 1 amp transistor, but do check the datasheet for verification.
A lot of these units seem to drop the 2S prefix of the Japanese labels.
Trace a lttle of the circuit and verify the 2SD600 makes sense.
Mar 27, 2010 | Car Audio & Video
Tri-mode amplifier hook-up
you dont have to have a crossover to hook up ur amp 2 ur subs
Feb 27, 2010 | Alpine MRP-F600 Car Audio Amplifier
My head unit has 1 set of preamp outputs can i conn. 4 speakers
Yes you can use a y to go to all four. Or you could bridge the four speakers wires onto the two outputs for 1 channel
Mar 31, 2009 | Alpine MRP-F320 Car Audio Amplifier
How to get amp status to come up on the screen of alpine d 310
you have to have an alpine kce-510m amp link module. You must also have a compatible amp, such as mrd-m300, mrd-m500, or the mrd-m1000. The amp link module plugs into the (ext) plug on the iva-d310 and the other end of the cable into an alpine kce-060m y-cable. The shorter of the y-cable plugs into the amp with the lowest id #.
Feb 11, 2009 | Alpine IVA-D310 Car DVD Player
Car Audio & Video Logo
23 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
