Question about Mitsubishi VS-60805 60" Rear Projection Television
Scrambled picture mitsubishi VS-60805
My sound is good, video out for another monitor is good along with selecting channels. Have a scrambled screen similar to old blk/wht sets where you had to fine adjust the tuner knob. The lines kind of go at a slight angle up from the right and it seems like it is trying to make the picture but can't. I'd rather not use this huge thing as a cable box for a smaller tv. I do have a good fluke meter but that is about it for test equip. I do have VS-60803 for parts although I don't think any interchange.
  • Donald Riles
    Donald Riles Feb 13, 2009
    Thanks for the help everyone. I did find the problem. It is a bad connection on the wire strip connecting the tuner board to the power board, the closest set of wires to you when looking in from front of TV.
  • Henry McKelvey
    Henry McKelvey May 11, 2010
    Hello deltamech,
    This sounds like a horizontal synchronization problem. If possible, can you post a picture of the problem so that I can determine if this is indeed a H-sync problem?
    After you post the picture I can better diagnose this problem.
    Thank you,
    Shuttle83
    http://www.electron-age-technologies-llc...
    Genius:
  • 1,139 Answers
Hello deltamech,
Are you using your component video cables? if you are check to see if you are using the correct inputs. Look at the babck of your TV and see if the RGB (Lettering) matches with the box you are connecting to. What I am talking about is the YP(b)P(r) vs the YC(b)C(r) they are incompatable with each other.
Check that and if that is the case either match the two proper RGBs up or use another interface.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Posted on Feb 10, 2009
The mitsubishi model vs-60805 tv will provide air channels off of cable hook-up, but does not provide cable channels. What needs to be done to recieve cable channels? The menu does not provide an apparent...
Mitsubishi VS-60805 is 1999 model tv and unable to receive digital cable channels because it is equipped with analog tuner that can not receive cable channels because it is almost 11 years old.
You need to hook Cable Box in AV input of tv, plug digital cable in cable box and get digital cable channels in tv. Cable box has its own remote control and inbuilt digital tuner to receive all digital cable channels and widely available in Store, Radio Shake, amazon.com etc.
Let me know if you have additional question.
Thanks.
Aug 07, 2010 | Mitsubishi Televison & Video
Mitsubishi VS-60805 Rear Projection won't operate in HD mode with Cable Box
Since this is an older first generation (1999) HD TV it may not be compatible with newer HDTV receivers because the standards back then were different - Make sure the HD cable box is plugged into the HD component inputs on the back of the TV (not the DVD inputs) and that the menu setting on the TV is set to DTV (not RGB) video. This TV will only accept 480i and 480p signals on the DVD input. Also the HDTV input will only accept 480i,480p and 1080i (it will not work with a 720p signal,make sure your cable box is not set to that mode)
Aug 17, 2007 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi VS-60805
What you probably see is a burning area due to Cooling Fluid leaking from one of the CRTs. If this is the case, It is not worth fixing in my opinion because the Board would have to be replaced and the leaking CRT would also have to be replaced. The availability of the Board is doubtful Due to it's age. You can check at 1800-553-7278. This is Mitsubishi's parts department #.
Hope this helps,
Skyassoc
Jul 17, 2009 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi VS60805 screen
If I can't get my 60805 working properly again I may soon have one :-)
I'm located in Orange County, CA, so if you're close I may be able to help you out.
Jun 16, 2009 | Mitsubishi VS-60805 60" Rear Projection...
Where can I get good E2PROM settings for Mitsubishi VS-60805?
I have this model and just got it working again. I have a Service manual also. But unsure about checking my settings
Jan 30, 2009 | Mitsubishi VS-60805 60" Rear Projection...
No picture but sound
I had the same problem with the same model. If you pull the cover off the speakers in the front , then the small black panel. looking from the front past your lamps are the 3 main boards, the r/h board has wire jumpers connecting to the center board. The set that is closest to you had a bad/loose/corroded connection on mine. All I did was resecure connection(try moving them with your fingertip) and turn TV on and check.
Jan 17, 2009 | Mitsubishi VS-60805 60" Rear Projection...
Colors properly aligned in HD but non-HD, or vice versa
you have to make the alignment for all 3 formats....standard....1080i...and 480i
Apr 29, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi VS-60805
Which transformer do you need. i have a source for alot of mitsubishi parts.
Mar 20, 2008 | Televison & Video
1080i connection has green hue
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Sony Convergence
http://www.techlore.com/blog/entry/19694/Sony-Convergence-Repair-My-Sony-TV-has-a-distorted-picture-/
http://www.techlore.com/article/19631/Sony-Convergence-Procedure/
Jan 09, 2008 | Mitsubishi VS-60805 60" Rear Projection...
Mitsubishi WE-52525
. Suspect the FMT PCB part # 930B924002 when set is warm.
Jul 31, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi VS-60805 60" Rear Projection Television Logo
215 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
