Question about UIFTech U381 Obdii Eobd Scanner
Will not connect for update
Not able to connect to pc for update
How to update the c101 and viola
FIRST INSTALL PC SUITE ON YOUR PC CONNECT IT TO INTERNET AND THEN CONNECT UR PHONE TO PC CLICK ON SOFTWARE UPDATE ICON IN PC SUITE AND IT WILL TELL YOU ABOUT UPDATES ....
Oct 28, 2011 | Nokia C101 Cell Phone
How can i update my nokia 3230
you can update it by using nokia pc suite installed in your computer with internet connection .........first install pc suite in computer->keep internet connection active->connect phone via data cable -> click on software update icon in pc suite->check for updates->then install it.
Sep 26, 2011 | Nokia 3230 Cellular Phone
Hwo iam update my nokia n73 phone.
You can update your phone by Nokia pc suite and nokia updater. Firstly connect your phone with your pc via multimedia cable. Then start nokia updater. You need internet connection to your pc to update your phone.
Apr 20, 2011 | Nokia N73 Cellular Phone
Hi my mobi is n 3110c i want to update my phon. But i dont know the steps to update
You will need a PC, Internet connection, the USB cable and d Nokia Software Updater.You can update your Nokia 3110c by connecting it to a PC via a USB cable and then imply follow the instructions given on the Nokia Software Update.
Feb 28, 2011 | Nokia Cell Phones
My samsung sgh m-200 mobile problem 1Chalte Chalte hang ho jata hai.2. auto restart hota rahta hai.plz solv my problems thanks
For this you need to scan your handset and memory from a updated antivirus
if problem persists you need to flash your phone
To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps)
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE(dowload the Nokkia Software updater by selecting this option) *Install the "NOKIA Software Updater" *Select Update**....(It takes 10-30 Mins)
**Please don't disconnect while updation process
To flash you need *USB cable compatible with your handset *A Computer *PC suite of your handset *Internet connection(Min speed 1Mbps) *Software Updater
To flash *Install the PC suite *Connect to USB *Open the PC suit *Select UPDATE PHONE SOFTWARE *Install the "Software Updater" *Select Update**....(It takes 10-30 Mins)
Thank don't forget to rate
Jan 28, 2011 | Samsung Cell Phones
How to access internet
hello there!
To connect to the internet follow the following steps:
  1. While in standby mode, press the OK button to connect to the internet
To disconnect from the internet:
  1. While in standby mode, press the Red end call button
  2. Press the left soft key for Yes to confirm Exiting the Web Browser
Please consult with your service provider for all other inquiries regarding the Mobile Web on the SGH-D900 handset.
Please make sure that you have a DATA PLAN from your provider or the set up for your GPRS settings.
For more information, The SGH-D900 uses PC Studio software for connectivity between your phone and a desktop computer. PC Studio is a Windows-based PC program used to easily manage personal data and multimedia files.
System Requirements:
The system requirements for Samsung PC Studio are as follows.
  • Windows 2000 or XP family
  • At least 300MB of free disk space
  • Interface devices such as USB, IrDA, and Bluetooth for the connection with the Phone
After installation, launch PC Studio 3.0. Be sure to have an active internet connection at the initial launch, as Live Update will automatically search for the most current version of the application and promptly install before use.
You can also update your Samsung PC Studio to the latest version manually.
Live Update can be performed as follows.
Run Samsung PC Studio. In the Launcher window, select the Tools > Live Update menu. (Make sure the PC is connected to the internet.)
  1. When the Welcome window appears, click the Start button.
  2. The available program update list appears. Click the Next button.
  3. Save all unsaved tasks and close all PC Studio applications. Click the OK button to proceed to the update process.
  4. When the update is done, click the Finish button to close Live Update. (In case the Live Update program itself has been updated, click the Start button to repeat steps 3 to 5 for updating other components.)
Hope it helps,
fossildude
Nov 09, 2010 | Samsung SGH-D900 Cellular Phone
Can not connect with pc, it does not show should i connect or not
yes i solved my problem, by turn the tomtom on then connect with pc .
May 29, 2009 | Tomtom One XL GPS Receiver
My system did an automatic update. Now I get a message that says that my backweb-137903.exe has been moved and so my HP center does not load. I looked for the file but it is not present on my PC. I also...
This error message probably occurred, because a spyware removal application incorrectly detected the Updates from HP Connections or Compaq Connections client software (developed by BackWeb Technologies), as spyware and improperly removed it. Since only part of the client software was removed, the errors displays because the software cannot fully open when Windows starts. Updates from HP or Compaq Connections is a messaging service that comes pre-installed on HP and Compaq desktop computers. The service provides product notices, support updates, tips, and special offers specifically for your model of HP or Compaq PC. If you no longer want to use Updates from HP or Compaq Connections, HP or Compaq Connections can be uninstalled through Add/Remove programs. If you still want to use HP or Compaq Connections to receive information regarding your PC, complete the following steps: CAUTION: Performing a System Recovery replaces system files and original software with the files that originally came with the PC. This process may move or remove certain files, like those stored in My Documents. Before performing a System Recovery backup important files and the files stored in the My Documents folder.Be prepared to reinstall software that was not originally included with the PC. You will also need to reconfigure an Internet Connection and obtain all critical Windows Updates, Virus definition updates, and anti-spyware updates. To resolve this error, reinstall the Updates from HP/Compaq Connections client software by performing a standard recovery:
  1. Remove all connections from the PC except keyboard, mouse, monitor and power cable. If any internal hardware such as a video card, or sound card has been added, they should be removed or disconnected.
  2. Restart the computer and press the F10 repeatedly after the logo screen appears.
  3. Click Next when prompted.
  4. Read and respond to the screens to recover the computer.
After the computer is recovered and you have completed the setup, you can do any of the following items to prevent the error message from displaying:
  • Adjust the settings in the spyware removal application to bypass the Updates from HP or Compaq Connections client software.
  • You can uninstall the Updates from HP or Compaq Connections client software before using your spyware removal application: Uninstall Updates from HP or Compaq Connections client software by clicking Start , Control Panel , Add/Remove Programs , Updates from HP/Compaq Connections , and clicking the Remove button. NOTE: If you remove the Updates from HP or Compaq Connections client software, you should visit the product support page for your PC model, HP Support and Drivers Search , for the latest information and software updates.
HP does not consider HP or Compaq Connections spyware software. If spyware removal software detects BackWeb as spyware and you would still like to remove HP or Compaq Connections, it should not be removed through the Spyware removal software. Instead, uninstall BackWeb using Add/Remove Programs as shown above.
Oct 05, 2008 | HP Computers & Internet
Not getting updates of symentec endpoint 11 on net
hi my name is paul
you don't really need to update your pc if its not on the internet
if you do connect to the internet then your anti-virus should automatically update its self and prompt you to install anti-virus update definitions
home this helps
regards paul
Jul 11, 2008 | Computers & Internet
UIFTech U381 Obdii Eobd Scanner Logo
Top UIFTech Office Equipment & Supplies Experts
jasbo
jasbo
Are you an UIFTech Office Equipment and Supply Expert? Answer questions, earn points and help others
