Question about Danby COMPACT ALL REFRIGERATOR DAR125SLDD, COMPACT
Purchased fridge DAR125SLDD this morning,plugged in after 13 hours,fridge is running & cooling but the outsides are very hot what do I do
2 Suggested Answers
  • 4 Answers
SOURCE: Danby Kegerator runs but does not Cool
sounds like maybe no coolant in system if compressor is working. you know like in your car a/c unit, sometimes refrigerant needs to be added. just a guess, I'm not an expert.
Posted on Nov 08, 2012
The top of my avanti mini refrigerator is hot
The return section of the gas cooling circuit is hot. Goes out cold comes back hot, so if that area has return lines behind it nothing wrong with the outside of a fridge being hot. Some fridges even have heaters built in around the doors and openings to prevent freezing up.
Jul 10, 2013 | Avanti 322Y Compact Refrigerator
Ive just bought a hot point ffa74 fridge freezer an it's now been plugged in for around 3/4 hours and the freezer isn't getting cool neither is the fridge, on the control panel there is a green...
The normal cool time for a machine is up to 24 hours, so I wouldn;t worry about anything at the moment, but if the product isn'l cool by the morning I would return it as a defect
May 14, 2012 | Hotpoint Refrigerators
Model # (P) 55662 serial # (S) 10149733GT Freezer is at 41' and fridge is at 49' and both are climbing. they were at 38' & 48' respectively this morning. * hours ago we tried: ...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 01, 2011 | Kenmore Side by Side Refrigerator
I woke up this morning to my refrigerator humming and not working. It is 5 years old. The freezer seems to be just fine. Help! It is stainless steal model PFSS5NFWASS
Top of Form
If there is no cooling at all , before we go further we must confirm the first step of confirming the compressor and gas pressure. So shut off the fridge and leave it off while you clean and check the evaporator for frost. If frost is seen it is a good indication as the compressor is working with sufficient gas within.
Now after about 6 hours plug in the fridge to start. Observe cooling to happen in about one hour and ice to from under three hours.
Earlier make sure that the thermostat was set to normal mode for freezer and fridge. If there is no ice formation we have a big issue as the compressor and gas must be checked out. If compressor is running check the pressure, get help to test gas pressure. If not you will need to fill up ,If gas pressure is good the possibility of the compressor being inefficient is high. In such a case you must take consensus to estimate and decide, if RPM of motor is low check capacitor.
However if Ice forms then observe the fridge for about 24 hours for cooling to continue and the fridge to cut off . If not the auto defrost timer, or the thermostat must be checked.
If defrost timer works but frost keeps forming check while the compressor shuts if the heaters are working, check continuity of the heaters.
So try this test from the outside and make your observations so that we come to the solution.
Jun 13, 2011 | Microwave Ovens
Refrigerator & Frrezer doesn't cool properly
Top of Form
Mar 13, 2011 | Kitchen Ranges
Side by side , fridge & freezer both stopped cooling last night, cleaned every thing this morning, unplugged for about 2 hours, plugged in and can hear fan running, but fridge and freezer do not seem...
did you feel the compressor runing?if not , need to check have power to the compressor. if power ok. i think the start relay or capacitor is bad. but make sure the condensor not drity. sometime it cause the problem. good luck
Jan 09, 2011 | Whirlpool 25.3 Cu. Ft. Side-by-Side...
We have a Roper by Whirlpool RT21LMXKQ freezer on top. Friday night it started clicking and the compressor would come on but only run for a millisecond before it cut off. Satruday morning we left if off...
It sounds like a start relay problem. try and see if you can remove the start relay and purchase a new one. You may find that you have a capacitor start & run, it could also be the start/run capacitor failing. at least the compressor is working, so all evidence leads to start relay failure or start/run capacitor failure. Try these first they are cheap enough to buy. if you are not sure you can check this yourself get a local sparky to look at it.
May 17, 2010 | Refrigerators
Vertical surface on the sides towards the front hot
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath
Aug 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Does not hold temperature, warms up.
if you hauled on its side then it is very possible you have oil in evaporator. replace all sealed system parts. compressor, drier and evaporator.
Jun 21, 2009 | Roper Refrigerators
Danby COMPACT ALL REFRIGERATOR DAR125SLDD, COMPACT Logo
20 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
