Question about Reddy Heater RLP100 Portable Forced Air Propane Heater with Variable Heat Ouput
Empire corcho model r15 btu1500 seriel number A39231
Two of the three bricks burn ok . fire stays inside the two when it burns. If I try to burn just one of the bricks instead of all three the flame burns higher than the brick.
3 Suggested Answers
SOURCE: can not get the bricks to light on my empire corcho
I have the same htr in Mich. & have worked on gas htrs.for many years.
Does the flame go out when you let go of the button to lite it?
If it does, then the thermocouple is bad.
If the flame stays on, but goes out when you turn the dial,
the gas regulator is bad.
Probably a little more expensive to buy new then to fix it.
Michael.
Posted on Nov 22, 2009
  • 4736 Answers
SOURCE: My mother has a 3
Hopefully, Becca the unit won't have to be replaced at this time. It sounds like the burner(s) is clogged and and needs to be cleaned To do this, turn the pilot light OFF and allow the unit to cool. Remove the front of the heater cabinet to access all of the inside workings. Carefully remove the 3 ceramic plaques and set them aside, where they won't get broken.Using a vacuum cleaner that has a hose, brush attachment and crevice tool. Vacuum all of the interior of the heater that you can reach with the brush attachment and crevice tool. Then turn your attention to the burner(s), Vacuum them thoroughly using the brush attachment, then switch to the crevice tool attachment and vacuum all the little holes on the top of the burner(s) thoroughly. Before reassembling the heater, carefully vacuum the ceramic plaques on both sides using the brush attachment. Be careful not to drop them. Then reinstall the plaques and the front of the heater cabinet.
Light the pilot and allow it to burn for 2 minutes, before turning the control knob to ON. Watch the plaques and the flames to see that burn as they should after turning it ON.
If the above didn't solve the problem, depending on the age of the heater, it may be time to replace it.
I hope this helped you and thanks for choosing FixYa.
Posted on Aug 16, 2011
Burner for corcho wall moont heater model number ck30t3lt
Search Results
    SunStar Corcho Vent-Free Natural Gas Infrared Heater with ...
    www.efireplacestore.com > ... > SunStar Heating Products Space Heaters
    SunStar Corcho Vent-Free Natural Gas Infrared Heater with Manual Controls ... For added convenience, you can mount this heater on a wall or have it stand on ...
    Tech Video: Wall Heater Maintenance - YouTube
    ? 3:33
    https://www.youtube.com/watch?v=8eglHvyNV3U
    Oct 19, 2010 - Uploaded by FMIPRODUCTS
    How to clean the Vent-Free Wall Heater burner's & pilot. ... Fix Mr Heater Vent Free Pilot Problems - Part ...
    EMPIRE CORCHO UNVENTED GAS HEAT
Dec 14, 2015 | Heating & Cooling
Replacing fire bricks
Fix-It Chick: Replacing firebricks / LJWorld.com
www2.ljworld.com/.../fix-it-chick-replacing-fir...
Lawrence Journal?WorldJan 4, 2015 - Firebricks are heat-tolerant refractory bricks used to line the inside of most fireboxes. They protect the exterior of fire-burning stoves and retain ..
Mar 13, 2014 | Stihl 44104-W1 - 051 & TS510 Cylinder &...
I have an Empire Corcho model CH-15 that is at least 15 years old. I have not used it much until past 2 years. It just started emitting a strong smell and a white powder is laying on the heater, above the...
Since it hasn't been used in at least 15 years, what you're seeing is the dust, dirt and spider webs that are being burned up by the heater. The strong smell is because of the clogged burners. Best suggestion is turn it OFF let it cool completely and thoroughly clean the unit. It may need to be dismantled some so that you can reach and clean everything. A shop vac with a house and brush attachment works well to accomplish this. Pay particular attention to the burner(s) and vacuum them several times. Dry clean everything you possibly can. Then reassemble the heater and relight the pilot and give it a try.
In closing, I must say, having been in the hearth business for 15 years, I' am totally shocked, that after 2 years of neglect, that a 15 year old gas heater would even light.
Apr 07, 2011 | Stoves Heating & Cooling
I have a Empire Corcho radiant nature gas space heater that the middle brick panel flairs when on. When the other two bricks light they burn normal (ie no flair or flames except slight flame as bricks heat...
Problem sounds like the incoming gas pressure is too high or the burner below the middle brick has debris or trash clogging some of the openings. Recommended next step is to remove all power / natural gas to the space heater and check all burners for debris or blockage. If burners are clear have your natural gas provider test the incoming gas pressure to ensure it is correct for that appliance.
Dec 13, 2017 | Heating & Cooling
HOW TO LIGHT PILOT ON EMPIRE CORCHO WALL HEATER MODEL R 15
I have tried to light my empire wall furnace by pressing the button and I have the gas on and it won't light
Oct 17, 2009 | Reddy Heater RLP100 Portable Forced Air...
Corcho Model CH30t-2 panels won't stay lit
HI it sounds like the fire cement between them needs replacing you can buy this at home hardware or heating supplier this should stop the flame down the middle , it stops air getting in and it will burn better , hope this helps you ?
Jan 10, 2009 | Heating & Cooling
Can not get the bricks to light on my empire corcho
Michael.
Nov 20, 2008 | Reddy Heater RLP100 Portable Forced Air...
Heating & Cooling Logo
243 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
