Question about Sony PlayStation Portable (PSP) Console
Psp problem with upgrade
Can you use gta the once?i down graded with it and psp said the files were corrupt.so i had to upgrade to 2.81.and it said configure network connection(i have no idea of doing any help).since then the game dont work and i am stuck with 2.81 any help please
  • 84 Answers
You should be able to downgrade with GTA. You might want to try it again with a different downgrader. I would recommend following this guide to downgrade http://boardsus.playstation.com/playstation/board/message?board.id=psp&thread.id=2792391 Then install this custom firmware so all the retail games will work as well as any homebrew application you might want to run. http://www.evilpsp.com/Custom+PSP+Firmware+3.3+0+by+Dark+Alex+PSP
Posted on Jul 12, 2007
SOURCE:
When i install gta vice city , an error message pop up says not enough video memory available
It is because your display driver does not meet the requirement to play the GTA game. It requires high graphic quality. I suggest you to upgrade your graphics.
Regards,
Muhaim
May 31, 2011 | Rockstar Games Grand Theft Auto: Liberty...
My psp used a 6.20 version.but when i update it into 6.37 version,i cant open my games.what i need to do to use 6.37 version.my psp is 3000
If you had custom firmware on your PSP, and upgraded to 6.37, there is currently no way to downgrade to the old CFW or to play any downloaded ISO files. You will need to wait until a new custom firmware is release or a down grade patch is available.
Feb 27, 2011 | Sony PlayStation Portable (PSP) Console
I have a sony psp. I have music stored on a small
corrupted data usually means just that corrupted data and usually won't let you play em at all. you may want to retransfer the files again... and after that if that didn't fix the problem reformat the new memory stick.
what you describe should have been fine. files just might have been corrupted from moving over from one to the other. is it for every song or just one? you could try this without the media go. i have an older firmware since i haven't upgraded my psp in awhile... but
1)on the desktop of your pc create a folder called pspmusic. right click on any blank spot on your desktop>go to new>folder> and rename that to pspmusic
2)plug in your psp to your computer like you normally do using the usb cable.
3)on your computer go to my computer and select the drive of your psp. *NOTICE THE DIFFERENT FOLDERS IN THERE AND WRITE THEM DOWN ON PIECE OF PAPER INCASE YOUR BIGGER MEMORY STICK DOESN'T HAVE THEM*
4)go to your music folder and copy everything in that folder to the pspmusic folder you created on your desktop on your pc in step 1.
5)once that done close that window down.
remove your old smaller memory stick from your psp and insert the new bigger one and connect it to your pc in the normal way.
6)go to the drive of the psp and to the music folder (if there isn't a music folder there create one) and open it. what you may want to do here is to delete all things in there or keep as is. just know that if there is a corrupt file in there you'll have the same problem. this is up to you for you can try this again later.
7)now go to the pspmusic folder on your desktop and copy all the music in that folder and bring it over to your music folder on your psp.
8)once everything has transfered over test it out and see if all works
its a bit more hands on than using media go but at least you see what is happening.
if that didn't work you may want to try formatting your new bigger memory stick
May 01, 2010 | Sony PlayStation Portable (PSP) Console
Music files
the music file is corrupted
Mar 07, 2010 | Sony PlayStation Portable (PSP) Console
Psp will hung up when playing Gta vice city stories
Are you playing the GTA Vice City Story from the Memory Stick or from the UMD.
If you are playing the GTA from the memory stick, I assume you have a customized firmware (CFW). Try to upgrade your firmware to higher version.
If you are playing the GTA from the UMD, update your PSP firmware.
Jan 19, 2010 | Sony PlayStation Portable (PSP) Console
How do you do the GTA psp liberty city helicopter cheat
LOL!
There's no such thing as a helicopter code for GTA LCS... well, if there is, maybe only RockStar Games knows about it!
There are other ways that you could getta helicopter... but they are rather quite complicated...
www.gamefaqs.com/console/ps2/file/925776/43563
.. review mostly about GTA III & GTA LCS.
If you've absolutely tried & followed the instructions to get the helicopter, there also might be another way of getting it too!
Oct 30, 2009 | Sony PlayStation Portable (PSP) Console
Downgrade my psp how to down grade my psps 5.03 to 4.00-4.05
You can solve this but it will cost around $25. You have to buy a Pandora's battery which hacks your psp but you will also need a Magic Memory Stick around $10 look on ebay or amazon and once you have these it will downgrade youre psp to 1.50 then you can upgrade it to anything you want also you can play N64, sega mega deive and pc games on your psp how cool!
Feb 09, 2009 | Sony PlayStation Portable (PSP) Console
How can i install games to my psp-3004 version 4.21?
your psp must be upgraded first or down grade..you should find the compatible version so that the iso folder will appear..
Feb 08, 2009 | Video Game Consoles & Games
Custom music for GTA L.C.S.
1) Download the Codemasters utility - ftp://downloads.codemasters.com/upgrade/Codemasters_EACSetup.zip
2) Make sure you have a game save for GTA on your PSP memory disk
3) Install the Codemasters utility on your PC
4) Connect the PSP to your PC in USB mode.
5) Goto the folder PSP and then SAVEDATA - look for the name of your GTA gamesave folder. For me it was ULES00151S0
6) Now you need to create a new folder in SAVEDATA that holds the custom soundtracks. Using the name of the game save folder remove the final S0 and add CUSTOMTRACKS - create a folder using this name. So for me my GTA music folder is called ULES00151CUSTOMTRACKS. Note that is a new folder - NOT the game folder renamed. For Vice City name the folder ULES00502CUSTOMTRACKS.
7) Fire up the Codemasters utility on the PC, select mp3’s from the hard disk or a music CD, select the custom tracks folder created above and convert your music.
icon_cool.gif Once converted, goto the custom tracks folder and rename all the files from *.toc to *.gta
9) Fire up GTA, select custom soundtrack in audio options and enjoy your own music.
Apr 06, 2008 | Sony PlayStation Portable (PSP) Console
8002014C
Try again with all this same steps but by using another memory card.
Aug 28, 2007 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Ekse
shevantha perera
Damen Wong
Damen Wong
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
