Question about WirelessPro.com Motorola FR50 Walkie Talkie
How to change batteries for FR50 motorola wallkie talkie
I have k7gfv700 Motorola walkie talkies w/ charger. The charge seems to work, but the lighs one the charge are red and the talkie do not charge. Do I need new batteries and where can I purchase the
You might try http://wirelesspro.com, we have found them to carry most TalkAbout accessories and batteries. Before ordering battery packs, you might try switching your existing good battery to the other radio and see if it solves the problem. This would assure you that it is indeed a battery problem.
Sep 28, 2014 | Motorola Walkie Talkies 2-Way Radio
Walkie talkie manual
We haven't found this exact manual, but this one is very close: http://www.motorola.com/mdirect/manuals/T289_User_Manual.pdf
The MON button is the Monitor button. It turns off any private line code settings you have temporarily so you can hear all radio traffic on your frequency.
Dec 01, 2013 | Motorola Talkabout FR50 (14 Channels)...
I was hunting and lost the back plate of my Fr50 Walkie Talkie and I would like to buy a replacement, can you help me...Thanks, Fred Tripp
Hi Fred,
Take your radio to your local Radioshack or similar store and the folk there should be able to assist you in the hunt of the part you require.
Hopefully this is helpful to you.
Cheers,
Peter
Dec 09, 2012 | Motorola Talkabout FR50 (14 Channels)...
How can i activate the squelch on a motorola fr50
Sorry, it doesn't have squelch or private line codes.
Best regards.
Aug 03, 2011 | Motorola Talkabout FR50 (14 Channels)...
I inheireted 2 fr50's, are they used for anything special, and how do i use them
The FR50 is a basic family radio service radio intended for family use, as opposed to business use. There are 14 frequencies set aside for family use in the US, and they are in this radio. The radio functions like most any other walkie-talkie. You press the push to talk (PTT) button and speak, release it when done, so others can reply.
Here is a copy of the user manual: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/fr50_User_Manual_E.pdf
If the radios do not talk to one another check the programming.
Best regards.
Sep 14, 2009 | Motorola Talkabout FR50 (14 Channels)...
Can't be received on my FR50 without ear buff in
Sorry, but these are a disposable radio. The schematics and parts list have never been released to dealers. Plus, with the basic repair being $69 on the repairable models, it would be less expensive to replace the unit.
Most likely you either have a bad speaker or speaker connection; or you have something deep in the audio accessory jack which is making contact and fooling the radio into sensing it has an audio device plugged in all the time.
Dec 15, 2008 | Motorola Walkie Talkie 2-Way Radio
Strange sound coming from walkie talkie, strange beeping
Most Motorola radios give a beep-beep when the batteries are low and need changing. Make sure to use a good brand of battery. One other thing to check for is leaking batteries, the crud with cut down on performance.
Oct 20, 2008 | Motorola Walkie Talkie 2-Way Radio
Fr50 beep
Hello mtnrvr,
The Motorola TalkAbout radios, especially the FR50 and FR60, are notorious for making a variety of beeps when you push buttons and activate various functions of the radio.
The beeps can be helpful when you are trying to operate the radio in low-light situations. But they can also be mildly irritating.
Sadly most models of TalkAbout do not provide any way to disable the beeps. I'd suggest not using this particular radio for covert surveillance missions.
Best Regards,
Agent Ken
Go Ahead. Use Us.
Apr 12, 2008 | Motorola Talkabout FRS 250 (14 Channels)...
Fr50 beep
Sorry but on this model, you cannot.
Kind regards.
Jan 11, 2008 | Motorola Talkabout FR50 (14 Channels)...
WirelessPro.com Motorola FR50 Walkie Talkie Logo
22 people viewed this question
Top WirelessPro.com Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a WirelessPro.com Radio Communication Expert? Answer questions, earn points and help others
