Question about Fujitsu fi-6770 Flatbed Scanner
Fujitsu 6770 scanning blanks and freezes with laserfiche
Flatbed scanner 22 doesn't have driver
You van download drivers from this link below:
Drivers
Dec 05, 2013 | Fujitsu fi-6770 Flatbed Scanner
What's wrong if i get error e9
E-9 error in Fujitsu fi-6670/fi-6770 is the Image Memory Alarm which implicates scanner memory malfunction.Turn off and turn on the scanner, does the same symptom still occurs? If yes, then you may have to replace the DIMM located at the memory slots on the CGA board. If the issue still persists after replacement of DIMM, then you may have to replace the Control PCA. I would recommend to contact an authorized FUJITSU scanner service provider or the dealer where you purchased the scanner.
Hope the above information is helpful.
Thanks & regards,
ScanCare
Jul 17, 2013 | Fujitsu fi-6770 Flatbed Scanner
Error e9 on fi 6770 means what?
Thanks & regards,
ScanCare
The rollers in ADF are not moving
select in software - adf front side , back side or duplex then only it will scan from adf.If you have selected adf and its not scannning then pls check whther the rollers are rotating or not.
if still problem remains mail me on felixsimon22@gmail.com
Feb 17, 2011 | Fujitsu fi-6770 Flatbed Scanner
AN ERROR "F" AND "4"
Hi,This error is Background switchover alarm. Check the background change over mechanism drive and BW motor functioning or not? Cleaning the mechanism may resolve the issue.
regards,Scancare
Jan 12, 2011 | Fujitsu fi-6770 Flatbed Scanner
Fi-6130 not grabbing paper, displays Code: DS32002
My scanner is Fujitsu M4097D. I just have problem with ADF: Error Code DS32002: Paper jam in the ADF. Here is my solution: 1. Bend two white platin pieces down a little bit in order to "sensor" the paper scanned. This problem is occurred after I am scanning 50 thick pages. Until paper count 42, it is stopped with error code DS32002. Hope help anybody having this problem.
Jan 06, 2010 | Fujitsu ScanPartner fi-5120C Pass-Through...
Can only scan simplex or duplex
The scanner can scan in either simplex or duplex mode only. If blank page is scanned, then it will appear BLANK, else someone would say, my scanner is not scanning properly! Remove balnk pages using software or sort on file size and delete the small sized files. Take care to ensure they are really blank.
S. Mohan, India
Nov 20, 2008 | Fujitsu fi-5110C ScanMaker Scanner
Blank Pages
The scanner's paper sensor may be jammed. IT is sensint there is paper and hence scanning!. Try and fix it. Sensor may be optical or mechanical. If optical remove shreds of paper or dust. If mechanical ensure it moves forward and backward.
S. Mohan. Chennai
May 09, 2008 | Fujitsu fi-5750C Flatbed Scanner
Why does the scanner hesitate when feeding the paper through the scanner and gives a scanned double image at the top of the page?
Is there a gear grinding noise associated with this? If so, call your local dealer for service. If not:Clean all the rollers you can reach with a cloth dampened with alcohol. Check for any obstructions in the paper path like torn paper, heavy toner buildup on guide plates or the edges of the scanning glass, or any paper guides obviously loose or out of place.
Nov 20, 2007 | Canon DR-3080CII Path-Through Flatbed...
How to scanning double sided document in fujitsu 5120c scanner
You may want to try using Laser Fiche. This scanning software allows you to select "Duplex" which allows you to scan double sided document
Oct 23, 2007 | Fujitsu fi-5120C
Fujitsu fi-6770 Flatbed Scanner Logo
Top Fujitsu Office Equipment & Supplies Experts
Chris Larocque
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
