Question about NetGear WGR614 Router
Can't access WIFI from wireless route connected to PC
I have installed the WGR614 wireless router in my PC and its working well. But my laptop can't access the WIFI because it kept asking for password. What must I do?
  • Anonymous Mar 28, 2014
    Cannot set up wifi ask for code
    Scholar:
  • 141 Answers
Call Netgear technical support. If you can't fix this try http://technicalsupport.blog.friendster.com
Posted on Feb 16, 2009
Tip
How to Connect a Laptop to a Wireless Router
  • 1 Purchase a wireless router that fits your needs and price range.
  • Follow the router's manual to set up the router and its Internet connection, which will probably require connecting a wired client to the router. Once the wireless router is set up, the wired connection is no longer necessary. However, it's best to leave the wired client connected if it's a separate computer from that on which you're going to set up WiFi. If something goes wrong, you can access the administration interface again.
  • Gather information from the setup process. In order to set up the wireless client, you will need to know the service set identifier (SSID), the Wireless Encryption Protocol (WEP) key and the channel and mode.
  • Boot up the laptop and plug in the WiFi card. This will not be necessary if your laptop has an integrated WiFi card.
  • Install any drivers needed to use the WiFi card. Insert the disc that came with the WiFi card and follow the on-screen installation process. Most discs will trigger a new hardware wizard that makes installation extremely simple.
  • Double-click on the "WiFi Connection" icon. It can be found in the system tray at the bottom of the laptop screen.
  • Click on "Properties."
  • Select the "Wireless Networks" tab.
  • Use the "Add" button at the bottom of the dialog if your WiFi network isn't in the "Avable Networks" section.
  • Click on "Configure" when you see your network's SSID in the "Available Networks."
  • Enter your network's SSID and WEP key.
  • Click on "Start," then choose "Connect To" and "Wireless Network Connection." Your computer should now be able to access the WiFi network. If the WiFi network is connected to the Internet, it should also be able to connect to the Internet.
  • on Oct 08, 2010 | Computers & Internet
    Trying to set up laptop from desktop but dont know password for router wgr614
    Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then configure wan settings and lan settings enable wireless if you want to use wifi Then save settings and restart router Then connect cable from internet service provider to WAN port of router and connect ethenet lan cable from computer to lan port of router. . Let me know if you need further assistance. Thanks for using FixYa.
    Nov 14, 2010 | NetGear WGR614 Wireless Router
    I don't know how to connect my second laptop to the netgear router to get internet service.
    Go to the first pc that is already connected. Right click your connection and note the status/advanced information, find the gateway IP address. Open a web browser and login to your netgear router. NetGear default is admin and password.
    Now go to the wireless setup, note the ssid or name of your wifi network, also note the security encryption and phrase you are using. If you don't remember you can set it again there and save but then you will need to reconnect to it, if all else fails use a data cable and plug directly up to the router to manage it.
    Once you know your wifi name and security key you setup, go to pc 2 and use the wireless utility scan or refresh you should see the name of your wifi network, click join to connect, it will challange you for the password. It if doesn't then all of your neighbors can use your internet and access your computers. Need to be sure to secure your wifi signal by managing it via the web management using your web browser.
    Aug 29, 2010 | NetGear WGR614 Wireless Router
    Laptop shows wireless signal is available. DSL cable, all lights burn green on the router. Can access google, when I try to access a web address, the page will not load
    in explorer > < tools > < internet options> <delete> all your temparary internet files.
    now try accessing google.
    On the router the only lights should be blinking are the connected ports Wan to the WWW the conneccted Lan ports to the intranet.
    Powercycle the router and the reset button on the back.
    Try a direct wire and see if the access to the net works.
    Reconfigure the WIFI of the router by the instruction book
    Aug 26, 2010 | NetGear WGR614 Wireless Router
    I have netgear wgr614 upstairs my laptop downstairs loads pages VERY slowly what can I do
    Verify that it is indeed a wifi signal problem by moving the laptop upstairs temporarily.
    If this fixes the problem, you're getting poor wifi signal downstairs. Not much you can do with the elements at hand. So try adding another element: install a wifi signal repeater (around US$ 25) somewhere in the middle. Or you can run a cable (or use Powerline Ethernet - around US$ 100) to downstairs, and there install a wifi access point (US$ 30-60). Or directly connect the laptop to the newly installed network wire.
    If the problem isn't fixed, you have some other problem on the laptop: most likely a faulty network configuration. Verify against whatever PC you have upstairs; they should have identical configurations except their IP address (if fixed instead of DHCP).
    Just to be on the safe side verify the laptop is properly operating and immune from virus and malware. Not all slowdowns are the system's fault.
    Happy navigation!
    Jan 03, 2010 | NetGear WGR614 Wireless Router
    My wireless router wont connect to my laptop
    Connect your Internet (DSL/Cable) modem to your router and power ON them both. Now turn ON your laptop's wifi receiver by either using a hard button, a sliding button or whatever button it is in your laptop's body. OR, maybe your laptop have a key combination to power on your wifi receiver like FN + F10. Make sure the wifi LED lights and there you can use your internet broadcasted by your router.
    Nov 05, 2009 | NetGear WGR614 Wireless Router
    I have a iphone 3gs and want to access wifi or wireless on toshiba satellite pro x200
    Laptop normally have single chip WiFi or Wireless Cards...
    These cards could be used as client(connecting to wireless router), adhoc or access point(a WiFi card could be used as Access Point to route your LAN(Wired) connection on WLAN)...
    Your laptop WiFi card is already busy as a Cleint, so if you want to use it as AdHoc, you have to remove all the other connection with the WIreless...ie, Disconnect the WLAN from connecting other devices, and follow the below mentioed steps to connect your device..
    When you are using Client mode you are not able to use it on Ad-hoc or Access Point feature...
    Setup laptop to Ad-Hoc
    1)Navigate to control panel and choose network connection, Right click on the Wireless network connection and click on the Properties on Wireless NIC
    2) Click-Wireless Networks Tab
    3) Click-Add
    4) Provide SSID Name, name to identify you rnetwork
    5)Security -Net Auth: Open
    6)Make -Data Encryption: Disabled
    7) In the check box present-Check on This is a Computer to Computer (ad-hoc) network.
    Change the IP address of the Wireless NIC card, by choosing TCp IP in the properties of WLAN and choosing TCP/IP v4 from the installed service
    TCP/IP on Laptop
    -IP: 10.0.0.1
    -Subnet: 255.255.255.0
    TCP/IP on iPhone
    -Static IP
    -IP: 10.0.0.2
    Now try searching for Wireless through your phone, you should able to connect..
    Please leave me comment, if you need further assistance
    Rnj VINODKUMAR
    Nov 01, 2009 | Computers & Internet
    Internet access not working on desktop thru Netgear WGR614 router
    Make sure your desktop doesn't have static IP address. Go to Network Connections, Properties of Local Area Connection, Internet Protocol > Properties. Select Obtain IP Address Automatically and Obtain DNS Servers Automatically. Apply the changes and restart the computer.
    Jan 18, 2009 | NetGear WGR614 Wireless Router
    NetGear WGR614 Router Logo
    91 people viewed this question
    Top NetGear Computers & Internet Experts
    Prashant M
    Prashant M
    Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
