Question about Sewing Machines
Singer 150 anniversary machine - Sewing Machines
3 Suggested Answers
  • 1116 Answers
SOURCE: How do I set my machine for a straight stitch .
Set stitch width to zero.
Posted on May 08, 2010
  • 54 Answers
SOURCE: We have a singer, Featherweight, 150 yr
are u talking about the pressure foot that u use to sew with or a pressure foot control... any low shank straight stitch foot should work...
Posted on Aug 18, 2010
Feed dogs are stuck in down position
The dial for that is usually underneath the machine and because it is not used very often it either gets stuck and won't slide or it may get loose and slide to the " lowered feed dog position" on its own.
Jul 17, 2015 | Singer 160 Anniversary Limited Edition...
How to replace sewing needle in Singer Ikea 150 Year Anniversary Game Boy Edition
Your user's manual is available as a free download at the Singer Sewing Machine site--select Support at the top. However, I noticed that yours is listed as a Izek 1500. Regardless, it will how you how to insert the needle, as well as many other features. Word to the wise, however--make sure that the replacement needle is all the way up, and the flat part is at the back, away from you. If you don't do those things, all kinds of nasty problems can result. Yours takes a standard sewing machine needle, by the way.
Feb 19, 2015 | Singer Sewing Machines
How to replace a needle in a Singer Ikea 150 year anniversary game boy edition
If you take a look above the needle, there is a clamp on the shaft with a screw, generally on the left side. That is called the "needle clamp." Put something under the needle first, then loosen the screw on the clamp, and the needle will drop out. THAT'S why you need to put something under it--if you don't it will drop into the bobbin area and can be hard to fish out.
Take a look at the needle you want to insert. It will have a flat part, and that flat part MUST be away from you--facing the back of the machine. Insert the needle as far as it will go (holding it with needle nose pliers works great for this) and tighten the screw. If the screw does not have "wings" on it, after you have hand-tightened it, use a straight-blade screw driver and tighten it at least 2 or 3 times more.
FIX MY SEWINGMACHINE
take it to a repair shop .
Jul 24, 2014 | Singer Sewing Machines
How do i thread the bobbin on a singer electronic anniversary edition
wind bobbin, drop into position ensuring that when thread is pulled bobbin rotates counter clockwise, pull thread towards you into slot, pull it to left under tension spring, then follow thread groove in bed to thread lock back left corner. close cover and start to sew ifr you need Singer 160 instruction email
Feb 04, 2014 | Sewing Machines
Singer 150 Anniversary Sewing machine...I am trying to remove the cover to get to the plug for the foot control. Screws are removed but can't take cover off.
I don't recommend you take this machine apart. I am a trained service tech and it's a task for myself. Why are you trying to take it apart?
Nov 05, 2013 | Sewing Machines
Need instruction manual for singer, featherweight, 150 yr model
You can try to contact the manufacturer. They may be of some help.
Jun 05, 2017 | Sewing Machines
We have a singer, Featherweight, 150 yr anniversary, model 132Q, we need to find a presser foot
Aug 17, 2010 | Singer 132QRFB Mechanical Sewing Machine
Sewing Machines Logo
78 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
