Question about Whirlpool RF365 Electric Kitchen Range
Bruners not level, seem to be warped
Do I have to buy new ones?
  • Mary Jacobson Jan 17, 2013
    I read somewhere else on the internet that folks have just used aluminum foil "shim" to even the burners. This seems to be a good solution, although it is not very "elegant" looking. By the way the range itself is level.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
Most burners on range tops have tabs on the bottom of them. Make sure the tabs line up and go into the drip trays that are under the burner.If you can't seem to get them level, try swapping them around, one by one to find the correct one.
Posted on Jan 17, 2013
Is it normal for a Cuetec R360 shaft to show some warpage when rolled on a pool table from brand new? I have gotten two so far and they are both warped. It doesn't seem right to me.
a new cue should not be warped, especially one that you pay good money for.
this is from their web site:
Cuetec's composite cladding of either graphite or fiberglass completely encases the solid wood core in an armor of high-tech synthetic material. This "Power Bonding Process" protects the cue from warping by locking out moisture and temperature changes.
Jan 13, 2015 | Pool & Spa
How to repair a refrigerator
There is generally two causes: 1 - the refrigerant system (compressor or coolant) or 2 - a leak through the seal around the door. The second issue (which is more of a DIY fix-it than the first) can be from 3 causes: 1 - the seal around the door is worn, warped or loose. 2 - the door is out of alignment. 3 - the appliance (frig or freezer) is not level, causing the door to be warped. Start with #3. Get a level and check that the appliance is level. If not, adjust the legs until it is. Did that fix the problem? If not, check if the door is out of alignment. If not, try replacing the seal. If none of these were the issue, consider the age of the appliance. It may be more cost effective to buy a new one than try to repair/replace the coolant system.
Jul 30, 2014 | Refrigerators
2004 Chevy Aveo The brake pedal pulsates and activates the ABS system when the brake is applied at low speeds
check rotor and brake pads. also check fluid level. one of those 3 causing problems.
more and likely its the rotor. its cheaper to buy new ones for around 20-30 dollars.
warped rotor will cause the pedal to ..pulsate. and more and likely you pads are wore.
when getting new rotor always put new shoes on so the rotor it can wear evenly.
May 14, 2011 | Chevrolet Aveo Cars & Trucks
Front brakes drag (more on left than right) while driving in rush hour stop-and-go traffic. Both rims get hot the left more than the right. Also have some steering wheel vibration and brake pedal pulsing....
Sounds like the pads are completely worn or either crystallized. The crystallized happens when the brakes get hot and cool water hits them, this will also warp the rotors. With the brakes pulsating, it may be the rotors are warped and have worn the brake pads uneven. I would have the rotors checked when buying new pads and if they are warped, buy new ones. If their not warped to bad, sometimes these can be machined until even but you never know how much metal will be left on the rotor.
May 28, 2010 | 2003 Chrysler Town & Country
Doesn't get Hot
You probably need a new regulator.
Apr 14, 2010 | Kenmore 774 sq. in. Cooking Area Gas Grill...
My car seems to warp front discs? Serviced the
Check your rear brakes. If the rears are not adjusted or functioning properly, they will put more strain on the front brakes, thus heating the rotors up too fast. Since the rotors in the front cannot dissipate the heat fast enough, they will most likely continue to warp until the problem with the rear brakes is fixed. Always remember: when installing brakes you need to lube all of the key points. On disc brakes, lube the area where the pads sit in the hangar, make sure the clips are free of dirt and rust. Lube the pad backing (not the part that contacts the rotor!) and be sure to remove and lube the sliding pins on the caliper well. I personally like using AGS's Sil Glyde or CeramLube. These withstand heat the best. On drums, lube the metal side of the shoe that contacts the backing plate, and be sure to lube your adjusters well. Also, very important: if you have rear drums, make sure they are adjusted the right way, you dont want them to drag, but you dont want to go thru another set of front rotors again! Good luck, 99% of the time, too much focus is put on the front brakes and not the rears. Focus on the rears!
Thanks for asking!
Nov 13, 2009 | 2000 Jeep Grand Cherokee
Brake are pulsating and not braking normal especily at slow speeds
Warped brake rotors would be my first guess. Don't bother getting the old ones turned or machined. Just buy a new pair and that should be it. BE SURE to have the parts store you buy them from CHECK them for trueness before you accept them. Lots of Made In China replacements out there and they are usually warped when NEW ! ! due to improper storage. Spend a bit more and get the "good ones" (Made in USA)....
Oct 30, 2009 | 1999 GMC Suburban
The door seems to be warped or tweaked in some way
Your fridge is not level. If you level it you will find that the door was fine , it was the fridge that was tweaked because it was not level and sitting correctly. Use a level, shims, and/or the adjustment screws on the bottom.
Jul 01, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Whirlpool RF365 Electric Kitchen Range Logo
50 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
