Question about CucinaPro Kitchen Appliances - Others
I have a cucina pro pasta maker #s178. The dough goes through the rollers but does not cut through the dough completly
It makes a ribbon of semi cut spagetti
4 Suggested Answers
  • 14 Answers
SOURCE: Ronco Popeil Pasta Maker Problems
After using the Ronco Pasta maker for a few times I discovered a couple of problems, the main problems are that it's a bit slow, took as much time as it does for handmade pasta.
The second problems was that cleaning the dies was a pain!
Posted on Jul 16, 2009
  • 287 Answers
SOURCE: Instructions for a Pasta Queen Himark Noodle Maker
These instructions are for the same machine. Himark was bought by Atllas Marcato. http://www.fantes.com/marcato.html
Posted on Oct 01, 2010
  • 248 Answers
SOURCE: Manual was not in box
kitchen.manualsonline.com
Posted on Oct 09, 2010
Cutter does not cut all the way through the dough
Luckily, I have two manual noodle makers, the same brand..with opposite working rollers ...so, using the two units at once, is going to work for me...heck man, I just bought the darn thing last month from ebay...
I thought that maybe just maybe I had a piece of floured crap, causing the cog or gear to stick..
Sandy
Oct 09, 2013 | KitchenAid Pasta Roller / Cutter Set
Kitchenaid pasta roller
The others had good solutions but I thought I would add mine as well.
I put vegetable oil on both outer edges of a folded paper towel that fits the entire width in the narrower roller settings of the machine. I run it through 3-4 times as if it were a piece of dough. It takes away the squeaking.....at least until it is needed again.
Feb 12, 2013 | KitchenAid Pasta Roller / Cutter Set
Just bought Imperia RM220 that won't start at all.. WHat's wrong with that?
Just attach the pasta machine to your countertop, table or cutting board with the clamp.  Put the crank in the hole.  The pasta goes inbetween the rollers of course and turn the crank.  Start with the rollers furthest apart or the biggest number and roll the dough twice on each number.  There are videos to watch on my website:
http://noodlemakermachine.com/wp-admin/post.php?post=16&action=edit
 Good luck with that!
Feb 15, 2011 | Imperia pasta machine - Original Made in...
Pasta Machine turning pasta sheets out with lots of holes? What are we doing wrong?
Start with the rollers farthest apart and when you first start rolling the dough will be uneven and have a few hole. But as you roll the dough over and over, it will be smooth with no holes in nice flat sheets. Rollthe dough twice on each setting, starting with the biggest number and rolling down to the smallest number for very thin sheets of pasta. Good luck. I have a recipe and videos on my website at http://noodlemakermachine,com.
Jan 16, 2011 | KitchenAid Kitchen Aid Pasta Maker...
Pasta roller squeaks when dough is not going through
Dec 30, 2010 | KitchenAid Pasta Roller / Cutter Set
Are there instructions for the Norpro ravioli attachment? I have a Norpro two piece set attachment for my Norpro pasta maker. It came with no instructions whatsoever. Are there any printed instructions...
Just bought one,so you're in luck lol.
Roll pasta dough until thin and translucent.
Dust lightly with flour.
Cut dough into four rectangular strips,each about 12 inches by 4 inches.
Place on strip of dough over the frame.(the metal part)
Press dough into frame with the indented tray.(plastic piece)
Remove the indented tray.
Fill pouches as desired.
Place a second strip of dough over the strip with the filling in it and press strips together with your fingers.
With a rolling pin,roll across the dough covered frame,gently at first and then increase pressure until the zig zag edges of the frame are visible through the pasta. The ravioli is now sealed. Remove excess dough and re-roll.
Remove ravioli from frame by by tapping it on counter.
I find that these instructions aren't the best. They should tell you to lightly flour the frame before using or else it's hard to remove the ravioli. I also find that tapping it makes no difference...I always have to push them out through the bottom.
Good luck and enjoy!
Oct 05, 2009 | Norpro Ravioli Maker & Press W/ Recipes &...
I have an old vitantonio tortellini maker (model #520) but i have lost the instruction manual
1. Make your favotite pasta dough, roll out thin.
2. Place a sheet of rolled-out pasta dough on the metal plate, press down with the plastic mold to create the ravioli pockets.
3. Fill the pockets with your choice of mixture (cheeses, meats, spinach).
4. Then brush the top of the pasta sheet with egg wash or water and place a second sheet of pasta dough over the first.
5. Then use a rolling pin to press down on the assembled raviolis.
6. The pressure of the rolling pin will adhere the two sheets of pasta together and will cut the raviolis apart along the edges of the metal plate.
7. The result is a dozen perfect homemade raviolis!
Sep 27, 2009 | Kitchen Appliances - Others
Why my dough is tearing when i try to make ravioili?
You have to let the dough rest about 30 min. to 1 hour before passing the pasta in the roller. Also if you put some flour on both side of your pasta for the first passing through the machine it works well.
Jul 21, 2009 | CucinaPro Cucina Pro 150-25 Pasta Ravioli...
I want to make ravioli in my pasta maker...
All the models of raviolis makers are not graduate identically...So I have the Kitchenaid ravioli maker and the #1 is the larger and the # 8 is the thiner. For the raviolis the best thickness is the #5 or 6 and all is perfect for me and delicious. Also here is what Kichenaid suggest for the thickness of the dough: If you do not own a KitchenAid Pasta
Sheet Roller, pasta sheets can be prepared
by hand. Pasta sheets should be rolled out
to a thickness of 1/16" (0.156 cm). Hop this help!
Jul 21, 2009 | Norpro Atlas/marcato/norpro Ravioli Pasta...
Kitchen Appliances - Others Logo
59 people viewed this question
Top CucinaPro Kitchen Appliances - Others Experts
Tom Chichester
Robert Kulkofsky
Robert Kulkofsky
Are you a CucinaPro Kitchen Appliances - Other Expert? Answer questions, earn points and help others
