Question about Electrolux EMS2487X Convection Microwave Oven
Normally hw many minutes it takes to heat water or food
Electrolux convetion microwave
  • 5,911 Answers
I can't view all of your question, so I will answer this to the best of my ability. If you're talking about heating a cup of water, it normally takes 1 minute or less for the standard microwave oven on HIGH. About 2 minutes if you want boiling water. I hope this is what you were asking. If not, provide me with another question and I'll see if I can give you a better answer.
Posted on Jul 14, 2007
6ya staff
SOURCE:
Electrolux microwave buzzes and food doesn't heat up
If the unit operates correctly except heating the food, then the unit needs a new magnetron.
Aug 29, 2012 | Electrolux EI30BM55H Microwave Oven
Food not getting heated
There are three common issues, magnetron "heats food" cracked high voltage diode, or a shorted high voltage capacitor. In order to find out you will need a professional to assess, it will be probably cheaper to replace the microwave oven.
Mar 16, 2012 | Electrolux Microwave Ovens
Microwave wont heat up food
If your microwave runs, but doesn'theat your food, verify that you have selected a cooking setting. You mayaccidentally set the timer. Test the magnetron by placing 1 cup of water in themicrowave and heating the water for three minutes. If the water doesn't heat,your magnetron is dead.
Mar 08, 2012 | Sanyo Microwave Ovens
Microwave lights up plate turns something hums inside but the inside of the microwave never produces heat.
Sounds pretty normal but the inside is not supposed to get hot - only the food is.
Try heating a half glass of water for 1 minute if it gets hot... its working - if not then the actual microwave generating device inside has probably died.
In that case buy a new microwave oven as the cost of parts and labour to repair is usually more than cost of buying a new one.,
Jun 09, 2010 | Maytag MMV1153A Microwave Oven
Maytag microwave oven model mmv4205bab not heating food
maytag microwave model # mmv4184aaq operates normally but will not heat food or water
Mar 07, 2010 | Maytag MMV4205 Microwave Oven
Crackling and popping sounds when you heat up food
thats normal water expanding and boiling off from the microwave boiling those tiny water pockets in food... sounds like popcorn sometimes.
Cover your food with a paper towel to avoid spatter on the ceiling of the microwave when this is happening.
Sep 12, 2009 | Sharp Microwave Ovens
Microwave oven not heating thoroughly
u need to clean the cavity inside the microwave .. step to clean that .. put a cup of water nearly half filled( 30 ml ) and start microwave for five minutes .. after that just open microwave and clean from inside with clean cotton cloth .. this will surely help ..
Mar 23, 2009 | Kenmore 63683 Stainless Steel 1200 Watts...
We have just purchased a GE microwave oven, model JES1358WL. the light is on, the turntable turning, the control panel shows cooking and seconds counting down when attempting to heat cup of water. it is...
First: never attempt heating pure water in a microwave, that is dangerous.
Ensure the oven is not set to the minimum power, otherwise the heating will be minimal.
Try heating some food at maximum power for two or three minutes, if it does not heat, take it back to the shop.
About water in the microwave, see here:
Microwaved Water - A MUST see
Superheating of water
Oct 16, 2008 | Microwave Ovens
Electrolux EMS2487X Convection Microwave Oven Logo
118 people viewed this question
Top Electrolux Microwave Ovens Experts
William Miller
William Miller
Paul Bade
Are you an Electrolux Microwave Oven Expert? Answer questions, earn points and help others
