Question about Emerson EWL20D6 Television
Which external speakers work with an Emerson 19" LCD digital TV?
The model we have has a coaxial digital audio output jack and we've tried speakers from Radio shack and some we had on hand. They don't work. What kind of speakers can we hook into this jack? Is there an ohms rating for this output that must match the speakers?
  • Anonymous Feb 07, 2009
    I have an Emerson 19" bottom of the line (LC195EM9 2) with the same scenario.....Do I need to buy some kind of digital processor to push the external speakers or what?
  • 2,992 Answers
Coaxial digital output is not a speaker-level signal, and you don't connect speakers directly to it. It's an output signal meant to feed an amplifier which takes that kind of input. You then connect the speakers to the amp and select the digital input, the same as you connect a CD player and select that when you want play a disc.
Posted on Feb 13, 2009
I have a westinghouse tv vr-6025z and I want to hook up external speakers.
most set have jacks marked "audio out" which could be RCA type jacks, or a coaxial or optical output . Connect a cable or cables from whichever one of those is compatible with the inputs on the back of your stereo receiver.
Dec 22, 2016 | Westinghouse VR-6025Z 60" LCD TV...
How do i connect hammacher wireless speakers to a toshiba smart tv
Model of both the TV and speakers, please. For example, without the model of the TV how is anyone supposed to know which inputs/outputs it has?
Edit: Dan, Thanks for providing the model numbers. I was hoping the solution would be something simple like switching the audio from internal to external speakers in the TV settings. However, when I looked at the owner's manual it appears that the rca jacks you tried on the back of the TV are inputs for old VCRs, DVD players etc. rather than an output which would be needed to send an audio signal to your speakers. In this case you will need to use the DIGITAL AUDIO OUT on the back on the TV. In order to use this you will need to purchase an Optical Digital Toslink Coaxial to Analog RCA converter. Make sure it uses a larger Toslink connector and not a mini one. The Toslink cable will plug into the DIGITAL AUDIO OUT on the back of your TV and then be plugged into the converter device. Your white and red RCA cables will go between the converter and your speaker transmitter unit. In addition the converter will have a power adapter that needs to be plugged into a wall outlet. There may need to be some audio settings changed in the TV menu to get this to function properly. It's best to buy from a retailer with a good return policy just in case it doesn't work.
Hope this helps.
Dec 15, 2016 | Toshiba Televison & Video
This t.v. doesn't have an audio output. How can I connect external/ sound speakers to it?
you can use the Digital Coaxial port on the back of the tv.
use a mono RCA and connect it to a digital receiver eg:surround to get external sound.
(this only works with receivers with a digital input and will not give any sound
if connected do a analog input)
Sep 05, 2011 | Coby TFTV3227 32 in. LCD TV
Model ELCHW402 40" LCD
The TV has two audio out options: a digital audio out (coaxial) and a 3.5 mm headphone jack. Both of these are just above the antenna in connector. The headphone jack is the top one.
For a sound system that uses RCA stereo plugs, get a 3.5 mm (M) to 2 red/white RCA F adapter at the headphone jack and use an RCA audio cable from the adapter to the sound system. Alternatively, you can use a 3.5 mm audio patch cable from the headphone jack and the 3.5 mm (F) to 2 RCA (M) adapter at the sound system. The TV speakers will probably be turned off automatically with this connection.
If your sound system has digital audio, get the digital audio cable. You will need to enter the menus to make this audio output active. See the Audio menu > SPDIF Type (PCM, Dolby or Auto).
I hope this helps.
Dec 24, 2010 | Element Televison & Video
I need to know the type of audio cable to use with the Altec Lansing BX1021 2 speaker system.
This type of jack is used for the digital audio inputs and/or outputs on A/V components such as receivers, CD players, DVD players, and more. Coaxial digital jacks are also sometimes found on higher-end PC soundcards for digital audio input and output.
Coaxial digital inputs and outputs use standard RCA-type jacks (so coaxial digital cables are terminated with standard RCA connectors). But the cable itself is specially designed to handle the much wider frequency bandwidth of digital signals
**** ~ Where did I find this information here is the URL Address where this information was found. ~ ****
Dec 07, 2010 | Altec Lansing BX1021 2 Speakers
The tv is a Sansui HDLCD1909A I can't find a
The only audio output on the HDLCD1908 and 1909 series of Sansui tv's is the coaxial audio out jack. It only works when the tv is tuned to a digital station on the tv's internal tuner. If this won't work for you try getting your audio from your cable or sat box, etc. I hope this helps you.
Jun 24, 2010 | Sansui HDLCD1908 19 in. LCD TV
Connect external pc speakers to flat screen tv
get a 3.5mm -> rca adapter. You need to convert from the 3.5mm jack that your speakers uses to the rca jacks that your tv expects.
Like this:
Aug 30, 2009 | Emerson LC195EM9 19 in. LCD TV
No surround sound
Your not goingto achive true dobly sound you need a HDMI solution for this and hence you dvd player is rather old since it does not use HDMI if you want true HDMI sound you need to purchase a DVD with HDMI outputs to the TV
May 24, 2009 | Sansui 19 in. LCD TV
Connect external PC speakers. Don't want home theatre system.
the only way this will work is if you have a headohone jack on your tv.
May 12, 2009 | Emerson LC195EM9 19 in. LCD TV
Emerson EWL20D6 Television Logo
1,176 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
