Question about Whirlpool GR465LXLS Electric Kitchen Range
When plugged in broil element comes on whirlpool gr465lxks range
F2 e3 code
4 Suggested Answers
catriver
  • 878 Answers
SOURCE: Whirlpool oven that does not broil
Nabril, looks like you have a thermal fuse in the broil circuit. Take your meter and on the control board go to connector P2-2, should be a blue wire. Pull the connector off and see if you have continuity from the blue wire to the red wire on the terminal block (where the cord connects) power off, wires off. If you don't have continuity, it's probably that fuse. If you do, the only other thing I would think it could be would be the relay itself. The schematic does not show the placement of this fuse. It could be on the back panel or under the main top. Check out the pic. Part number..3196548 Catriver..post back.
Posted on Apr 21, 2007
  • 464 Answers
SOURCE: GR465LXKS does not preheat to correct temperature.
did you check both the broil and the bake elements to make sure they were ok?
Posted on Oct 24, 2009
  • 1891 Answers
SOURCE: I have a Whirlpool electric
E 3 code And the F 2 code tells us that the oven has over heater . and to correct this problem replac the oven tempt prob . ( you could have melted wires or shorted wires also . ) if the probe replacement does not correct problem hte the clock will have to be replaced also .. mm hope this helps . feed back pls ..
Posted on Dec 05, 2010
Broiler will not work on a whirlpool range rf367lxsyo
the broil element
is the heating element that is found at the top of the oven and produces a very high heat for broiling. If the broil element isn't working, you should first do a visual inspection for signs that the element has blistered or separated. If the element appears normal then you can check for continuity with a multi-meter. Remove power from the appliance before performing this test. Remove the back panel and locate the terminals for the broil element and inspect the terminals and wires for signs of overheating or damage.
If there is no continuity then the element will need to be replaced. If the wires are damaged then they will need to be repaired. If the element is ok then you will need to check the broil circuit to determine the cause. This involves live voltage checks and should only be performed by qualified persons. Components to check include fuses, if the range is equipped, and oven control thermostat or electronic control.
Apr 17, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
The broiler element comes on by itself when the power is on--it will not turn off unless I turn the power off at the breaker. The bottom element does not come on at all. I get no codes on the display
You have a bad broil-element relay on the Electronic Oven Control (EOC) - the contacts have welded shut (closed). You will need to replace the EOC.
Oct 28, 2014 | Whirlpool Kitchen Ranges
Whirlpool wall mount oven won't heat at all. Error code E3 F1
Technical sheet says all F1 codes to replace control
Jan 17, 2014 | Whirlpool Ovens
I have kitchenaid Kerc700 electric range that had the code F2:E3 show up on the display. What does this mean?
Hello, Thank You for using FixYa. I will be helping you today.Kitchenaid F2-E3 means a button was held down too long if you push cancel and it comes back you would have to replace the glass console. Thats assuming its F2-E3 and not E3-F2
Thank You and please rate my answer if it was helpful..
Jun 12, 2011 | KitchenAid KERC700 Electric Kitchen Range
Whirlpool rf385 with error codes e3 f2
F3 - E2 Oven too hot Replace oven temperature sensor
Dec 09, 2009 | Kitchen Ranges
Oven comes on broil had to un plug. when pluged back in same thing happens.
Faults
Control faulty- replace
Short to earth
1) in the element
2) in the wireing
Jul 06, 2009 | Whirlpool GR465LXLS Electric Kitchen Range
Broil element will not work
You need to check the oven sensor. It should be about 11k ohms. This is the metal rod in the back top of oven cavity. Access it from the rear. UNPLUG POWER FIRST!!
Nov 03, 2007 | Kitchen Ranges
Whirlpool GR465LXLS Electric Kitchen Range Logo
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
