Question about Garden
Need to view wiring diagram for kubota B 1550, won't charge, headkights don't work
My kubota B 1550 tractor has electirical problems starting, charging, no headkights need to view wiring schematics
wadembly
  • 489 Answers
SOURCE: I installed a new battery in my B6200 Kubota
check the voltage at the battery when its running if its charging below 13.5 volts then you have a bad alternator or charging system not working properly
Posted on Jun 05, 2009
  • 62 Answers
SOURCE: Headlamps quit on L4200 kubota tractor, Wireing
CHECK THE FUSES
Posted on Sep 25, 2009
jdlipscomb41
  • 157 Answers
SOURCE: need wiring diagram for ford 4000 tractor 1967
check ebay
Posted on Oct 26, 2009
wireguy212
  • 1627 Answers
SOURCE: Need wiring schematic diagram for JD L130 lawn
You should price a new wiring harness,around $80 so there is not much reason to spend a lot of time trying to find shorts or open wiring.
Posted on Apr 18, 2010
suzukiracing
  • 200 Answers
SOURCE: Have an older Kubota B7100, started a few days
Try checking the main fuse.
Posted on Jul 20, 2010
Need the wiring diagram to Kubota TG 1860,specifically to engage blade
You will need to contact the dealer on this, the diagrams are in sections maybe he will copy it for you.
Jun 14, 2016 | Kubota Garden
Kubota wiring diagram
pull each switch and jump it if started found bad switch
Aug 28, 2014 | Kubota Garden
I have a kubota bx25 that won't start. it has power to the starter on battery side
you need to have power to the small wire on the starter for it to crank over
Sep 03, 2012 | Woods Kubota Bx 24 Bx 23 Bt610 Bh75 And...
Kubota L2250 DT wiring diagram
You can download:Kubota Tractor L2250, L2550,L2850,L3250 2WD 4WD Operator Manual
This Manual Covers
1. Servicing of Tractor
2. Specifications
3. Operating New Front Mower
4. Instrument Panel and Controls
5. Lift Link and Hydraulic Control
6. Wheels, Tires and Tread
7. Operating
8. Maintenance
9.Check and Maintenance
10. Adjustments
11. Troubleshooting
12. Long-Term Storage
13. Lubricant Specifications
14.Wiring Diagram
Jul 03, 2012 | Motorcycles
My mower discharge when the blades are ingauge
The wires connected to your PTO are the key to your problem. The electric pto is designed to run off the engine charging system when it is engaged and will run your battery down if it isn't. The fact your battery will charge and hold a charge tells me it is probably ok. You will need a wiring diagram to figure this out. You might check outdoordistributors.com. They have pdf files that you can view online for most lawn tractors. Good luck Tim
May 31, 2011 | Husqvarna 25HP Hydrostatic 54"Cut Garden...
I installed a new battery in my B6200 Kubota tractor. the tractor sat for 2 years, so I don;t if the charge light worked then or not. Now the charge light won't go out
Jun 05, 2009 | Garden
Ignition switch
A kubota dealer should be able to print one for you or go on line with model # etc and you should be able to bring one up yourself. I hope this helps. donnyb60
Mar 19, 2009 | Garden
Garden Logo
117 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
