I have a kenmore heavy duty 70 series model #11092575110 washing machine, that will not fill up past a small load. What can I do?
2 Suggested Answers
watugot
  • 290 Answers
SOURCE: belt on my kenmore 70 series washing machine
Your washer should be a direct drive unit, it has no belt. If you hear the motor running but nothing is happening you probably have a broken motor coupler. The coupler is about $10.
Pop off the trim pieces on each end of the console.
Remove the two screws that hold the console to the cabinet and flip the console back.
Remove the two clips that hold the cabinet to the rear panel of the washer and unplug the lid switch harness. The cabinet will tilt forward and slide off.
Remove the clips holding the water pump and move it to the side.
Unplug the wires from the motor and remove the clips holding it.
You will see the motor coupler.
Make sure you can turn the gearcase shaft with a pair of pliers so it is not locked up.
Post back and let me know what you find or if you need any help.
Posted on Dec 12, 2007
We have a Kenmore Heavy Duty 70 series model 11092575110. It has been running perfect and suddenly it has stopped with a load of clothes and water. Please advise. Thanks
As power reaching the machine? Is the motor being energized ? If power is reaching the motor and it is not turning, the unit has died a noble death while working.
Sep 09, 2015 | Kenmore Washing Machines
I have the kenmore heavey Duty 70 series 92273100 Model 110 that we just moved. Was working fine before. Now it won't stop filling, overflows, and doesn't go into wash cycle. It will only s
either the pressure switch is bad or the pressure switch hose from the wash tub to the pressure switch is kinked or plugged so air pressure cant reach switch and operate switch,remove hose at tub and blow into it and see if machine now operates,if not the switch is bad
Feb 19, 2012 | Washing Machines
Kenmore Heavy Duty Series 70 washing machine gets stuck in cycle.
Either your timing motor has broken or the gears that it drives are stripped. The timing motor is easy to replace but if the gears are stripped you will need a whole new dial assembly.
May 09, 2017 | Kenmore Washing Machines
Kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Feb 27, 2010 | Kenmore Washing Machines
I lost 23 small rhinestones from jewelry in washer...
Yes. They can get trap in the pump, if they got in between the inner and outer tub.
Dec 12, 2009 | Kenmore 22422 Top Load Washer
I have an old Kenmore Heavy Duty 70 series washer.
its a filter inside the water hose thats still blocked or the relay inside the washer for the cold feed is not opening up fully it could just need a clean or maybe a new one fitted
Nov 05, 2009 | Kenmore 22422 Top Load Washer
Kenmore Series 70 washing machine whines and low flow on cold H2O
Yeah you need to replace the water valve. To get to it you need to remove the cabinet on the newer direct drive models, If yours has a rear access panel then you simply pop the top to get to the valve after removing the hoses. Fairly simple job. Here is a good website for direct drive coupling replacement . It shows you how to open the cabinet. http://repair2000.com/coupling.html
GVI 151 is the generic part that fix all belt drive models. Direct drive will need its own little water valve buy hay it ain't but 20 bucks.
For a better explanation post you model number in the comment box and I will research it further for you amigo.
Jan 20, 2009 | Kenmore 22422 Top Load Washer
Slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Kenmore heavy duty 70 series model 82763110
set the load size to small, fill with water.
now after it fills with water do you hear anything? motor noise?
If you hear motor noise, it probably has a broken motor coupler.
if it doesnt do anything I would look at the lid switch and activator, the lid has to close and the switch has to know it closed. did the tab on the lid break off?
May 03, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore heavy duty washing machine 70 series
The most likely cause for water fill temperature problems is the solenoid has burned out, usually cold first, it gets used more. Not a repairable item , easy to replace
Dec 30, 2007 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
