Question about Toshiba Satellite P305D-S8828 Notebook PC
Cmos location satelite p305ds8828
Reset bios by - removing cmos battery
SOURCE: toshiba A135-S4527 cmos battery dead
I found where the cmos battery is located. By the Toshiba tech support website , it's next to the PCMCIA Slot, just behind it. To get to it, Take off LCD, keyboard, top palmrest, hard drive, battery, memory, top power cover,switch board, modem, network. and some others. Too many to describe here. Items to remove not in order.
I Have the service manual downloaded already.
Let me Know
comier957
Posted on Aug 10, 2008
Teis
  • 340 Answers
SOURCE: Satellite A215-S7422 Lost BIOS Password
Hi there, and welcome to FixYa.
Two ways to solve your BIOS problem:
One:
Removing the battery inside for the bios and find the jumper for clearing the CMOS.
Two:
Download your flash BIOS from here:
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1852724&rpn=PSAFGU&modelFilter=A215-S7422&selCategory=3&selFamily=1073768663&selModel=1852724%7CPSAFGU
As you don’t have a diskette on your model, you might be able to install it on a memory key, and boot from that, depending on your previous BIOS setup???
/Teis
Do vote before you leave,
Thank you
Posted on Dec 16, 2008
  • 1602 Answers
SOURCE: I need to locate the cmos battery on my Toshiba
THIS INFORMATION WILL BE IN A SERVICE MANUAL.
WWW.9MANUALS.COM
THEY ALSO CAN GET THE PART FOR YOU TOO.
RODGANDYSR
Posted on Mar 09, 2009
  • 22 Answers
SOURCE: need location for cmos battery on toshiba m35x satelite
This is not a solution as such, but could help
http://www.irisvista.com/tech/laptops/ToshibaM35X/satM35X_1.htm
http://www.insidemylaptop.com/fix-dead-toshiba-satellite-m35x-laptop/
Posted on May 23, 2009
SINGH99
SOURCE: satelite a60 shuts down after 3 seconds
SEND ME LAPTOP TOSHIBA PSA60L OC9003 VGA DRIVER
Posted on Jun 03, 2009
Toshiba satelite bios password recovery
On laptops there isn't an easy way to recover passwords in the BIOS. Sometimes you can reset the password. Other times, you'll have to contact the manufacturer to get it reset.
Some laptops will allow you to reset the BIOS password by pulling the CMOS battery. The CMOS battery is typically located under one of the bottom panels for access to the memory or wireless cards. Some models have the CMOS battery connected by a small wire with a clip connector, others have the CMOS battery placed directly on the motherboard with a metal retainer clip.
Here is a link to a removable CMOS battery with wires: http://www.laptopparts101.com/wp-content/uploads/2008/12/removable-cmos-battery-560x420.jpg
Here is a link to a CMOS battery that is directly on the motherboard: http://www.laptopparts101.com/wp-content/uploads/2008/12/coin-cmos-battery-560x420.jpg
On a laptop, if you unplug the power cord, remove the laptop main battery and then remove the CMOS battery - and then wait at least 5 minutes, some models will blank out the BIOS password. Not every BIOS password can be erased by removing the CMOS battery - but if you are comfortable working on the laptop parts it is worth a try.
If removing the CMOS battery doesn't fix the BIOS password, the only option left is to contact the manufacturer for a reset. (If you took your laptop to a certified technician - they would just contact the manufacturer for the reset, and then bill the time to you!)
The number to contact Toshiba is 1-800-457-7777.
Nov 19, 2011 | Toshiba Computers & Internet
I have forget my bios password please help me toshiba satelite pro M10
If you cannot access the machine after if has been powered up, it is still possible to get past the BIOS password. The BIOS password is stored in CMOS memory that is maintained while the PC is powered off by a small battery, which is attached to the motherboard.
If you remove this battery, all CMOS information (including the BIOS password) will be lost. You will need to re-enter the correct CMOS setup information to use the machine. The machines owner or user will most likely be alarmed when it is discovered that the BIOS password has been deleted.
On some motherboards, the battery is soldered to the motherboard, making it difficult to remove.
If this is the case, you have another alternative. Somewhere on the motherboard you should find a jumper that will clear the BIOS password.
If you have the motherboard documentation, you will know where that jumper is. If not, the jumper may be labeled on the motherboard. If you are not fortunate enough for either of these to be the case, you may be able to guess which jumper is the correct jumper. This jumper is usually standing alone near the battery. If you cannot locate this jumper, you might short both of the points where the battery connects to the motherboard.
If all else fails, you may have to clear the BIOS password by resetting the RTC (Real Time Clock) IC (Integrated Circuit) on your motherboard.
Many RTC
Dec 31, 2010 | Toshiba Satellite Pro M10 Notebook
Unlock pasword toshiba satellite model 2405-S201 intel pentium 4.
WHERE IS THE PASSWORD in BIOS OR IN WINDOWS IF ITS IN BIOS YOU HAVE TO RESET THE BIOS BY REMOVING THE CMOS BATTERY BUT IF PASSWORD IN WINDOWS XP YOU CAN TRY TO PRESS TWICE CTL+ALT+del TOGETHER AND PUT USER NAME ADMINISTRATOR AND PASSWORD BLANK OR ADMINISTRATOR OR ADMIN AND YOU CAN GET IN WINDOWS BUT IF IT DOSENT WORK THEN YOU HAVE TO FIND UTILITY LIKE PASSWORD REMOVER FROM THE NET AND TRY RESETING IT.
Dec 13, 2010 | Toshiba Satelite 2405-S201 Notebook
I have forgot vaio vgn-cr390 bios password
To reset the bios password on your laptop, you will need to remove the cmos battery on your laptop for some minutes and insert back, the cmos battery is located on the motherboard of your laptop, once the cmos battery is removed from the motherboard for some minutes, the bios password will be reset, and that fix the problem.
Dec 01, 2010 | Sony VAIO Notebook
Hello how to reset bios password of ibm thinkpad t23 2647
To unlock the bios password on your laptop, you will need to remove the cmos battery on your laptop for some minutes and insert back, the cmos battery is located on the motherboard of your laptop, once the cmos battery is removed from the motherboard for some minutes, the bios password will be reset, and that fix the problem.
Take care.
Nov 19, 2010 | IBM ThinkPad T23 2647 Notebook
Where are the bios reset pins on apire one aod150
Here is the BIOS reset pins and the CMOS battery of acer laptop. You can reset BIOS password also trough removing the CMOS battery. 04ebfdf.jpg
Apr 03, 2010 | Acer Aspire One AOD150-1920 Netbook
PASS BIOS ACER 2930 ASPIRE
Hi the only possible way to reset the password in the BIOS is to reset the CMOS battery. It is located in one of the panel below the sys (you must have proper expertise to do this) towards the right hand side. The battery is set on a jumper You first need to disconnect all power source i.e adaptor and battery. than remove the panels to try and locate the CMOS Battery. Remember not to tuch anything else or connect any of the cables any where else it may cause a problem for the sys and you. Once the CMOS battery is reset the BIOS password will have gone.
All the best
Feb 09, 2010 | Acer Aspire 2930-4661 Notebook
Can anyone help me on how to reset the Bios password to default on an HP Compaq 6710b Laptop? I have an HP Compaq 6710b Laptop. It is booting but it cant go beyond bios boot and i cant enter setup as it is...
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Oct 16, 2009 | HP Smart Buy Notebook
How to get toshiba bios password remover toos
ok what you will need to do is reset the bios. just take out the bios battery for a couple ofseconds then putit back in this normaly resets the password Regards Slitwrists
Jun 08, 2009 | Toshiba Portege S100-S1133 Notebook
Toshiba Satellite P305D-S8828 Notebook PC Logo
27 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
