Question about Pioneer PRO-510HD 53" Rear Projection Television
PLEASE HELP (Three Ghost Images)
For the past week and a half my TV screen has been displaying three separate ghost images. All my eforts to align the color convergence using the user manual have failed. I can't seem to adjust the '+' sign to appear in one color. Part red and part blue lines along the plus sign are still appearing. Also, there is a full curvature (in red and yellow) that appears at the bottom of the screen. Please HELP. You can e-mail me the solution directly if it is OK with you. My e-mail address: [email protected] Thank you very much.
  • Anonymous Jul 22, 2008
    We have the exact same problem, different model. thanks for the answer.
    President:
  • 3,130 Answers
You will need to have or change the convergence correction driver IC's. There are two of them in this TV set. Not a fix for a novice I'm afraid. If you have no solid state repair experience, play it safe and call out a pro to assist you in this repair.
Posted on Jul 12, 2007
SOURCE:
Ghost / Overlapping Image
ok you have defective convergence crrection circuit! or maybe the RF Box is defective! can you describe the color of the ghost?
Oct 12, 2007 | Samsung HCN4226W 42" Rear Projection...
Lower half of the screen has a digital ghost that is
Tv have a convergence problems,it dead.Tv convergence board is dead.Require changing the 2 STK convergence ICS and some or all it resistors.To solved the tv convergence problems.Tries Websites like Tvrepairworld.com,Tvrepairkits.com to buy a convergencce kit.To replaced those convergence parts on the board.
Jul 28, 2010 | Samsung HL-S5679W 56" HDTV
Colors on the screen are messed up with ghost HITACHI
Its not clear what kind of tv you have but it appears to be older rear projection tv with three picture tube. This problem does occur due to the convergence board going bad. Needs professional help to repair unless you know a lot about soldering ICs. Check out at www.fixurtvs.com for more answers on this problem, repairs and costs.
Feb 26, 2010 | Televison & Video
The picture is double pictured with what appears to be a ghost
projection sets on occation need to be re-alligned. check your owners manual if you have one and re-align your lamps to the test screen that is displayed when you press 'menu' from your remote or from the front of the tv. This should fix alot of it and you may find the color adjustments may need adjusting after re-aligning your lamps. hope this helps. I had one and that sounds like the 'ghost' images I had till I did this.
Aug 11, 2009 | Toshiba 55H70 55" Rear Projection...
Epson 1290 prints a ghost image in cyan or magenta
I like this one! No don't have a solution but....interesting Try it's test not by computer, just printer, may need head alignment, should be a command for this on printer
Apr 23, 2009 | Epson Stylus Photo 1290 InkJet Printer
Color ghosting or shadows
The most likely cause is shorted convergence chips and possibly a few pico fuses.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer2_bing.gif Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2
Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
You can see some more examples and find a fix herebb0cf99.png http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 19, 2009 | Pioneer SD-532HD5 53" Rear Projection...
Flashing (ghosting) on screen when playing DVD's or VCR tapes
I've had a similar problem, It was not the TV or the DVD player but the SCART junction box (a separate unit that automatically sent the live input to the output SCART socket, to fix I just uses a spare empty input socket.
if you don't have one of these units try with a different SCART socket or AV input also try replacing the leads between the player and TV.
Nov 10, 2008 | Digimate DGL32 32 in. LCD Television
Pioneer PRO-510HD 53" Rear Projection Television Logo
112 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
