Question about BernzOmatic TS3000T Quickfire Self-Igniting Torch
How to fix a bernomatic ts3000t torch trigger only clicks no spark
Trigger only clicks no spark
When cutter's off/on switch is turned on, torch is active without pressing button on torch.
Turn the power off on the machine and check the continuity of the trigger wires with a continuity tester to make sure they aren't shorting together.
Oct 23, 2015 | Welding Tools
I have a accurate tools 3n1 stick,mig, and plasma cutter everything works except the plasma press the trigger air comes out but no arc at all on tip to metal can hear the relay clicking when switch between...
Could be as simple as having the ground cable connection placed into the wrong port on the front of the machine. Foot peddle/machine selection switch in peddle mode instead of machine mode? Internally it could be high frequency spark leakage or failed HF circuitry. These are the most common causes of spark failure. Oh and be sure you have good consumables and they are installed correctly. Air pressure leaving the torch head should be around 70 psi.
Aug 27, 2014 | Welding Tools
I have a Victor R1600 Cutting Torch that the trigger handle malfunctions after a couple weeks of use. The company replaced the first one, but will not replace another, only credit! The problem with the...
Hi:
That's and easy fix and you can do it yourself, call your local welding store like praxair www.praxairdirect.com and give them the brand and model of the torch and they will SHIP direct to you the right part. Check the link here.
Aug 22, 2011 | Victor ST900FC Straight Cutting Torch...
216 mig no feed no fire maybe selonoid problem please help seloniod does not click
It could be just the simple problem of the trigger not working. Disconnect the trigger wires from the machine at the plug at the front of the machine. See if you can manually trigger the machine by placing a piece of bent over mig wire onto the contacts. If the machine does trigger from this then your fault is in the torch somewhere. It could be the trigger (which commonly does fault from a dusty environment) which is easily replaced by going into any welding store with the torch model number (magnum 250L), or it could possibly be that a trigger wire has broken from the torch being damaged
May 29, 2011 | Lincoln Electric Lincoln Power MIG 216...
I have a clarke weld 85 en mig welder which starts to weld without having to press the trigger on the gun. what could cause this please
I have a clarke 85en no gas welder. the gun on this particular welder is always live the trigger only feeds the wire
Mar 08, 2011 | Welding Tools
Gun trigger no worky
Remove the torch and check for continuety, if it is the switch youcan purchace a new one from the torch manufacturers.
Nov 24, 2009 | Miller Welding Tools
No arc. Power and Air OK
if the main power cable is cut that is your problem,unit uses high frequency.the two leads go to the gun trigger back to unit,no fuse or fuseable links in the gun.
May 13, 2009 | Welding Tools
Miller 2050 that will not spark.
This is relative to 3 causes , contol board , pwm board or torch
Feb 28, 2009 | Miller 903777012 SPECTRUM 2050 PLASMA...
Thermal dynamics cutmaster 50 2004 yr.
Check contacts in tip and be sure it is all lubed correctly. If you have good air pressure and flow it should arc after pulling the trigger for about 2-3 seconds.
Sep 27, 2008 | Welding Tools
BernzOmatic TS3000T Quickfire Self-Igniting Torch Logo
43 people viewed this question
Top BernzOmatic Tools & Hardware - Others Experts
Are you a BernzOmatic Tool and Hardware - Other Expert? Answer questions, earn points and help others
