Question about Microsoft Windows XP Home Edition
Panasonic cordless won`t dial with magic jack
I get a dial tone but it won`t dial . cordless works fine on other land line and majack works with corded phone
  • 1 more comment
  • Anonymous Mar 01, 2009
    I have the Panasonic 2 Line Cordless, handset model KX-TGA650B. After a whole day of troubleshooting my entire house, I found that line 2 DTMF Signal works on Magic Jack, but Line 1 DTMF Signal on the phone does not. Regardless of all the wiring tricks I could do, Line 2 always worked and Line 1 Never worked. Hope this helps someone else. (I'll be buying a new 2 libne phone, I have to have my MJ on line 1 so my Vonage can stay on Line 2, for specific reason particular to me only.) If I switched the lines, they both work as Vonage Line 1 adn MJ line 2.. Amazing.
  • Anonymous Mar 18, 2014
    i dont have any dial tone
  • Anonymous Mar 20, 2014
    magic jack has no dial tone
I have solved the problem , go to http://www.tntdiscount.info/panny-mj-fix.php to see the fix.
Posted on Feb 03, 2009
Turn off your LOCAL AREA CODE entry in the Panasonic... Magic Jack WANTS the area code to ALWAYS be dialed... so store incoming caller ID's with the AREA CODE INTACT and dial only from numbers with an area code displayed. Worked for me!
Posted on Mar 12, 2009
My land lines are working but all my handsets say check tel line...no dial tone or response. Batteries are good according to tester. Anything I can do??
ck the red and green wire that goes to the system those 2 make the phones work just do the main main phone first , , it does not sound like the phones are broke you are not getting a dial tone due to no connection to the line itself
Dec 10, 2014 | Panasonic Kx-tga641m/kx-tga641 Cordless...
Why does a CS6124 not work with Magic Jack?
that phone should work with magicjack , you are not getting a dial tone because you are no setting it up right somewhere along the line ,
Dec 10, 2014 | VTech Communications Cs6124 Cordless Phone...
CL82309 static no dial tone
Line issue - contact your service provider for relief.
Sep 10, 2017 | AT&T CL82309 - Cordless Phone
Hi, I have a Panasonic Cordless phone with 2 bases. I have moved one from upstairs to the phone jacket downstairs. Our third phone worked fine until I switched two of them around. Now only the plugged...
You could plug your non-cordless phone into suspicious phone jack to see if you have dial tone-if you dont have dial tone, the line maynot be connected and you should open the jack to see if there is more than 1 cable attached. If there is more than 1 cable attached and you dont have dial tone at other end of cable the cable might be cut or shorted somewhere inbetween. You can test continuity by tying 2 wires together and test with a multimeter on resistance to see if it is open circuit or maybe even short circuit. To test for short circuit, untie the cables and you should not get a reading. If you do have dial tone when you plug in non-cordless phone the distance might be to far for receiver to pick it up(ie..greater than 10 metres). I hope this has been helpful.
Aug 26, 2011 | Panasonic Lands Phones
Continuous dial tone on phone line . When i try to dial out- i just get a continuos dial tone- happening on my 2 cordless, landline is fine. Dont use a magic jack, changed out hardware, new cordless dont...
There are two possible answers to this problem. The first thing is to check on the cordless phones, is a 2 way switch, one setting is for DP=Dial pulse (setting for old rotary phones) 2nd setting is TT= Touch Tone. I would guess that the setting should be set to TT on both cordless phones for touchtone.
Second thing to do is to plug in the base unit of your cordless phone to a jack that currently has a landline phone plugged into it that works and test again. If cordless phone works OK then go back to the original jack that didn't work and reverse the wires in the jack: that is what is known as a "polarity" issue.
Aug 31, 2009 | Panasonic Lands Phones
My GE phone 27958 just stopped working. I originally thought the cordless handset needed a new battery, but upon replacement that did not help. I found that the base which is plugged into the land line...
check power ?
Is Ac - DC converter pack plugged into power point ?
Is the DC plug plugged into the phone ?
does power point work ?
Check correct dc voltage being produced from the AC - DC power pack converter ?
Isolate other phones on other extensinos to see if uniden is cause or not of no dial tone.
You may have another phone off hook and phone line has timed out .
Jun 11, 2017 | Uniden Cordless Phone
No dial tone, just buzzing noise - should be 2 line phone, 1 jack
What you need is a dsl filter since you are working off a splitter. You can usually get these for free from your phone company.
Mar 20, 2009 | Uniden TRU9466 Cordless Phone
Phone Rings,but cannot answer
if there is no dial tone that means that the connection is not being made when you pick up the phone hence you cannot answer nor can you get a dial tone
the fact that the phone rings indicates that the land line is good so the fault is in the phone itself
Nov 06, 2017 | Panasonic KX-TG5652 Twin Cordless Phone
Dial tone hanging
There are two wires going to your phone. Inside the wall jack, switch the red and green wires and the keypad should work .
Dec 10, 2008 | Panasonic GigaRange KX-TG5480S Cordless...
Cordless Phone. It doesn't work!
The phones base station is burned out, they are not replaced after warranty or repaired, so time for anew phone. Buy a UNIDEN
Jun 30, 2017 | Panasonic KX-TG2302 Cordless Phone...
Microsoft Windows XP Home Edition Logo
1,215 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
