Sony Handycam CCD-TRV87 Hi-8 Analog Camcorder
Problem for Sony Handycam CCD-TRV87 Hi-8 Analog Camcorder
Sony trv87
By dbiern6900 on Jan 25, 2009
I was recording today and the not would go off and then on several times intermittently. I had tried removing the batteryand using only AC power but had the same problem. Now it wont turn on so I can record. It will however turn on so I can play the tape. that is ok. I pulled the batteries and AC and let it sit for 5 minutes and put both batteries back in with no luck. There is No LCD screen No view finder no power.
Solution #1
posted on Jan 25, 2009
Not Rated)
dbiern6900
Rank: Apprentice
Rating: 0%, 0 votes
Although the battery shows it takes a charge and the camera will run in playbackmode (VTR) I found if I remove the battery and run on AC the camera turns on and now I can record with it. The battery must be the problem.
Was this helpful?
Yes
No
Popular Solutions for Sony Handycam CCD-TRV87 Hi-8
Questions and Unsolved Problems for Sony Handycam CCD-TRV87 Hi-8
Do you recommend Sony Handycam CCD-TRV87 Hi-8 Analog Camcorder?
Answer
Answer
I have a non-functioning Sony CCD-TRV67. I'm trying to locate another camera that will play the... (More)
Answer
I changed the tape, cleaned the head and tried and external mic and still will not pick up audio... (More)
Answer
old hi8 sony handycam playback not working i have it on the player mode editsearch works, rec. works... (More)
Answer
camcorder works in play mode but wont switch onto camera mode
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony Handycam CCD-TRV87 Hi-8...:
Top Camcorder Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Camcorder Experts
Top Camera & Camcorder Repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
