Question about KitchenAid KEBC208 Electric Double Oven
KitchenAid oven won't heat after heating.
KitchenAid Model KEBS208 DSS8 double wall oven - lower oven won't heat after cleaning. Do I need to replace the thermostat, thermal fuse or what. What do these parts look like and where can I find them in the oven?
  • Anonymous Feb 14, 2009
    I have the same problem.
  • qdskinner Mar 17, 2009
    Same issue her
catriver
  • 878 Answers
SOURCE: Electric Oven doen't heat
cdkd, there should be a TC0, on the back of the oven. Thermal cut out. You want to check to see if it is open. You will have to pull the oven out enough that you can remove the back panel cover and check it. The lower and upper oven should have one. It's a very cheap part to replace. If this TCO fails, no heat. Check this first before buying a new board. Catriver..post back.
Posted on Dec 27, 2006
SOURCE: OVEN will not heat
I have the same model, 3 yrs old, and the exact same thing happened. KitchenAid made the appointment with a repair company and when the tech came out the first thing he said was "you can never use the self cleaning cycle because this always happens.' He replaced the thermal fuse thermostat and said that a lot of times the digital panel will go out and that will cost around $400. The cost of the thermal part was $80 plus his $90 labor charge. I called Kitchen Aid back, and they swore they never heard this complaint...all you have to do is look on line to see it is a major complaint!
Posted on Nov 02, 2007
aborcass
  • 2651 Answers
you need to remove the oven from the cabinet, the fuse is located on back wall about 6 inches down directly between broil element leads
Posted on Feb 24, 2008
SOURCE: Whirlpool Double Oven RBD305PDB7 - Upper Oven Won't Heat
I have the single oven of this style and I had to replace the thermocouple (part number 4450934) on the back of the oven three times (used the cleaning cycle three times). After using the cleaning cycle, the oven would not heat so each time I had to pull the oven out from the wall to access the back so I could change the part. Once a new part was put on the back of the oven, it worked fine. To pull the oven out, open the oven door and look down by the doors hinges. On each side you will see a screw that's holding the side molding on. Remove the screws and then the molding. That will give you access to the screws that hold the oven into the framing around the oven. Remove the screws and then you can pull the oven out to access the back to change the thermocouple. The oven is heavy so you may want some help to get out. It is not a one man job, maybe a one man and wife job. It is heavy. I hope this helps. Better late than never.
Posted on Nov 24, 2008
SOURCE: Dacor Wall Oven won't heat - Cannot find thermal reset switch
Open the oven door and unscrew the vented panel at the top. Make sure the oven is off. Atop the electronics in there you'll see a little red button. Push it. Voila.
Posted on Jul 14, 2010
Kitchenaid Superbra double wall oven still not heating. Replaced thermal fuse of top oven; lower is OK. Also replaced the 2nd thermal fuse near the control panel on the top of the unit. Any ideas?
Get me a complete model # number for this oven We then can give you step by step what to check .Knowing how to use a meter Is a big help with any electrical issues . Getting Us the model will tell us what is used to control your appliance, The big and first thing to check is the power do you have it all were it needs to be most ovens run on two legs of 110/120 volt. in combo Make 220 volt It all needs to be there or you will not get proper heat
.https://www.youtube.com/watch?v=NOdYp8CFjdU&feature=share
Feb 02, 2017 | KitchenAid Ovens
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
Hotpoint 24in double electric wall oven 20RJ83D not heating, element is working
The thermostat for the upper element has gone bad. Needs to be replaced.
Apr 15, 2017 | Ovens
I used the self-cleaning feature and now my oven will not turn back on.
Their is a high limit thermostat that has tripped,on older model and on some newer models it has a red button on it that can be pushed in to reset it.Other times once it goes out it must be replaced.
For the upper oven its behind the control panel,for the lower its behind the grill between upper and lower oven
I hope this helps you to understand why your oven wont heat,
Gene
Aug 05, 2011 | KitchenAid Architect KEBS207S Electric...
Oven door locked, can't get plastic cover of control panel off
you have to first remove the side trim there should be some screws in the side usaly 2 but sometimes 4 ---you could have replaced just the fuse for less than 20 dollers
Aug 09, 2009 | KitchenAid Architect® KEBS277S Electric...
My KitchenAid Supra self cleaning convection wall oven stopped heating after I had used the self cleaning program. I ordered a new heat sensory unit $80.00 but after I installed it the oven is still not...
There is a overload thermostat on the rear of the oven that will have to be replaced.
Self cleaning features are not recommended by most appliance technicians.
Self cleaning causes parts to fail often.
Feb 27, 2009 | KitchenAid KEBC107 Electric Single Oven
Kitchenaid superba electric oven kebc107kss05
Did this with me twice now on self clean. It's the thermostat on the back of the oven. Set to trip when oven gets too hot which happens with self clean. Part is about $45 - $50 and pretty simple to install. Hardest part is pulling the oven out of the wall.
Nov 11, 2008 | Ovens
General Electric Double oven wall unit
id say something different like a thermal fuze or relay
Nov 21, 2007 | KitchenAid Architect Series KEBC107KSS...
KitchenAid KEBC208 Electric Double Oven Logo
119 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
