Question about Dryers
Maytag dg482 gas dryer won't heat
My maytag dg842 gas dryer won't heat at all. What do I need to know to fix it? How do I know what part is broken?
  • pboyle0317 Mar 29, 2009
    "Maytag dg482 gas dryer won't heat" Gas won't ignite. Gas is on duct work is clean, motor runs but no heat.
  • Dryers Master
  • 8,220 Answers
Pilot safety most likely. most of these older units had a mercury bulb safety simular looking to a thermocouple.
Posted on Jan 25, 2009
Dryer works but won't heat up
i had a maytag gas dryer that did this and it was an easy fix. small part called "gas coil"
If it's gas dryer that may be the issue.
Dec 02, 2011 | Dryers
My Maytag gas dryer won't heat
Hello Todd,
Their are several things that could cause the dryer to not heat, i have posted a tip i wrote what to check whena gas dryer doesn't heat
http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Nov 12, 2011 | Maytag Dryers
Maytag Neptune wont heat up what is problem
We just converted my neptune gas dryer to propane. It ignited yesterday but we could smell propane. So, my husband fixed that ,now it won't ignite and heat up
Nov 10, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Maytag dryer mug15pdaww won't light, the ignitor
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Jun 16, 2011 | Maytag Dryers
I have Maytag gas dryer #DG482 - after load is in & its started, it squeeks - Could this be a belt?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jun 01, 2011 | Maytag Dryers
No heat
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 11, 2010 | Maytag Neptune MDG5500AW Gas Dryer
My maytag dryer is not staying hot to dry clothes
heatman101
May 19, 2010 | Maytag Neptune MDG9700A Gas Dryer
I have a maytag dryer model number is mce8000ay
heatman101
Dec 23, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Maytag DG482 Dryer Won't Heat
The heat is regulated with a Klixon mounted next to the blower housing near the vent pipe so it can judge the temperature of the air coming out of the drum.Right next to it is a melting type fuse. If the dryer runs and gets too hot the fuse will melt.But the dryer will still run. So if the fuse is good(continuity) and the dryer control(cycle) thermostat is also good then you should have power going to the gas valve assembly when the machine is running unless the timer is in the no heat or wrinkle free/cool down mode. When the gas valve assembly is energized the flame sensor a%20flame%20sensor%202.bmp flame sensor mounted outside the burner chamber detects the heat from the ignitor. When the heat is very intense then the sensor shuts down the ignitor
a%20igniter.jpg Ignitor and that frees up the power so that the coils can be fully energised and open the gas gates. The gas comes out and hits the red hot igniter and you have ignition. It stays on for maybe 2 or 3 minutes or until the control thermostat is satisfied and shuts down power to the gas valve assembly. So... If your gas dryer has a good flame sensor and a good igniter AND the dryer will work some and quit, replace these: dryer%20coil%20kit.jpg Gas operator coils
part# 279834
The coils get hot and quit on these machines when they get a little age on them. It is aggrevating because it is a hard to diagnose thing. But well worth the 20 bucks. SOURCE
Jul 07, 2009 | Maytag Dryers
Takes almost 4 hours/timed cycles to dry 1 load of bedding/sheets
most of the time your complaint is the home owners house venting.run a load with the venting detached[it wont hurt a thing] if ok then must clean venting till dried as well as with out venting.if still long dry times first must make sure air ways in dryer are clean[should have good air flow at back if hand held there] and may need to remove front to clean lint filter area.and inspect blower ,making sure mounted to shaft and not worn in the center[blower key way, inside the hole where motor shaft goes thru blower]you dryer only has one element so if you have heat its heating.if you did all above and have problem still can be electronic[thermostats,timers etc........but i have fixed 1000s of dryers and their having problems are rarer.i hope that helps God bless ,tom
Jan 08, 2009 | Maytag Dryers
Dryers Logo
289 people viewed this question
Top Dryers Experts
