Question about Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive
Maxtor 320gb External hard Drive Question
I just bought a Maxtor one touch 4 320gb drive and was wondering if it was ok to unplug and disconnect the unit from my PC after I have backed up my pics and music to it. I really dont want to leave it attached to my pc, I only want to connect it when I need to add stuff to it. will this be ok or will I lose data. Also How do you run the program to use the safety drill feature? the safety drill feature is included with the drive, but how do you use it. Thanks for your help.
You can remove and disconnect the drive with out losing data. Since it is a usb drive its always best stop the device before removing. You do this by clicking on the icon in the task bar . It has a green arrow above it. As for the safety drill have not use it but should be able to get instruction once you install it ( look at the help files ) Hope this helps
Posted on Jan 25, 2009
Where do I get aMaxtor one touch 4 320GB manual
Located within the software ( / guides/manual ).
Downloads and Updates available at seagate.com, search function
May 13, 2014 | Maxtor Computers & Internet
External HDD no longer recognized by new win7 PC
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked. I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 19, 2010 | Maxtor OneTouch 4 500GB External USB 2.0...
I have a maxtor III usb 2.0 500 GB external hard drive. the light on the front goes out and works sometimes. when the light goes out the external drive gets disconnected . i checked for loose connections....
Possibly, the USB is not receiving current enough and occasionally it resets the USB interface. Try connecting it to another system, or to a powered USB host, and see what happens.
Another possibility (but you'd need to disassemble the external enclosure and connect directly the disk inside to a SMART-capable motherboard) is that the hard disk is developing a fault.
Apr 15, 2010 | Maxtor 160GB OneTouch III Mini USB 2.0...
Windows vista states insufficient space on Maxtor One Touch drive
You could check that the backup software settings are pointing to the correct drive. (I've made this mistake before).
Nov 03, 2009 | Maxtor OneTouch 4 Plus 500GB External USB...
My computer cannot dectect my maxtor one touch III 320GB
well, 2 options, your hard drive is not working in that case, just get a internal hard drive which is serial and open the case for the maxtor and plug the drive inside the case. its cheaper to buy the inter hard drive, then to replace the external hard drive.
Oct 29, 2009 | Maxtor OneTouch III 300 GB Hard Drive
How to Connect Maxtor OneTouch 4 Mini 320Gb to PC
I have one as well running along with a PC. PCs and Macs are formatted differently. Go to www.maxtor.com and create a search for reformatting from a Mac to a PC with your Operating System in the search as well. Should have no problems after doing that. It will tell you and or show you where and how to reformat.
Oct 01, 2009 | Maxtor OneTouch III Mini Edition 120GB...
Maxtor One-Touch 4 750gb power light flashes and goes out straight away.
Try to remove the drive and connect it directly to another computer.
If still doesn't spin up then most likely the board has failed.
Nov 03, 2008 | Maxtor One-touch III Mini 40 GB USB 2.0...
Maxtor One Touch III 320GB
THE PROBLEM IS MASTER AND SLAVE CONFIGURATION .. MAKE YOUR BACK UP HD A SLAVE IT MAY BE A MASTER NOW..
AND IF ITS A MASTER MAKE IT SLAVE
IF IT STILL DOESNT WORK THE CONTROLLER IC ON MOTHER BOARD CAN BE FAULTY.
Jul 28, 2008 | Maxtor One Touch III 500GB FireWire/USB2.0...
Drive won't mount
i had a maxtor one touch go bad and had to open the case and take it out of the external casing and put it into my computer as an internal drive. then it worked fine. it was a single drive.
just today i had a maxtor TB drive go bad, and since i think it has two drives inside it i am very worried that i will not be able to do the same thing.
May 25, 2008 | Maxtor OneTouch II external hard drive...
Maxtor Personal Storage 3200 (U01E200) 200 GB Hard Drive Logo
153 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
