Question about Salter 9007 Glass Lithium Digital Scale
Salter 4001 err code after battery change - Salter 9007 Glass Lithium Digital Scale
After changing battery, why does err appear and not a 0?
The replacement battery could be defective or installed incorrectly.
Sep 05, 2015 | Salter 9037 - Digital Bathroom Scales /...
Battery code for Salter kitchen scale Model 6055
i needs manuals of calibration of the scale salter model 6055
Aug 23, 2011 | Salter 2001 electronic kitchen scale
My Salter bathroom scales (model 929) are showing an ERR message. They seem to think everything weighs more than it does as if u press gently on them the weight goes up really quickly until limit reached...
The best day chessboard type is the traditional type of weight, in contrast, electronic weight scale error degreehighestelectronic
tems, affected by environments, bumps can make reading deviation.The use of electronic weight meter can more precisely?
Electronic scales are generally placed in the hard flat floor use, not on the carpet or other soft object surface by using.Each weight to body weight in the same place, the same time, wear the same clothes.
Hello, I just see a online stores
http://www.tmart.com/Digital-Scales/ sell digital scales. Some advice, for reference purposes only and finally I wish you luck!
Jul 25, 2011 | Salter Health & Beauty
E appears on Salter scale, even with new batteries
Hallo I have problem witch kitchen scale Salter.E appear when I pushed on and it takes 3 sec
How can I fix this problem
Than You
Sep 18, 2009 | Salter 2001 electronic kitchen scale
I changed the battery on bathroom scale Salter 987
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery untill you first complete the steps listed above.
Jul 21, 2009 | Salter Stainless Steel Electronic Bathroom...
Salter 9007 Glass Lithium Digital Scale Logo
Top Salter Health & Beauty Experts
traccie
Level 1 Expert
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
