Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Keep lossing connection
My internet connection keeps getting lost of gets very slow, its only normal for like 30 minutes a day, ive gone through 3 routers and 2 modems but its still happening, what do i have to do, is their a certain router setting i can do or should i just call a cable guy?
    Problem Solver:
  • 15 Answers
If the Lights on your cablemodem indicate that it has lost connection with your Internet Service provider when the internt is "broken" Then it meens you need to call a cable-guy... your cable signal can varry throuought the day, and when it "drops" its too low for your modem to be happy with...
Posted on Jan 25, 2009
Scratched sim card
You could try getting a replacement SIM with your phone provider. They usually do this for a small fee.
Dec 30, 2013 | Apple Powerbook G4 A1106 Modem Board And...
I have a mitsubishi wd-62525 the power light keeps blinking, and i can't get picture. i unpluge it than want 2min than it stop blinking and i can turn to tv on and get a picture than after 30-40mi
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 06, 2012 | Mitsubishi WD-62525 62" Rear Projection...
My RCA modem keeps resetting connection. When I reset it or turn it off to reconnect to the internet. It starts up the usual connection process and after a while doesnt connect and restarts the connection....
All cables may be secured but the internet signal is not enough to keep the modem latched. When it drops too low, the modem lets go and tries to acquire it again. You need to check all the connections and you may have a screen on the modem setup that shows you the signal strength. Keep in mind that any connection your signal travels through causes a loss of signal and the SPLITTER connections are big loss of signal devices. If you lose 3dB it is half the signal
Nov 06, 2017 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
100% internet connection but PSN won't let me login
That is very common, I too get that DNS error while attempting to log in. Im pretty sure it is just the playstation servers. For me it usually takes like 20-30 minutes until they get it running again or if your anxious to play just keep trying, sometimes it might only take 5 or 10 min. Hope this was helpfull.
Aug 15, 2009 | Sony Playstation 3 (PS3) Console
Emachine laptop model W4620 with does not connect to the internet
Do the following steps in order, checking to see if you're reconnected to the internet after each step.
1) Check all of your connections, make sure that all of the cables are plugged in securely and to the correct ports.
2) Reboot your modem and/or router. If this PC is connected directly to a cable/dsl modem, unplug the modem's power cord, wait 30 seconds and plug it back in. Wait a minute or so and then check your internet connectivity.
-If the PC is connected to a router that is connected to the modem, unplug the power to both the modem and the router. Wait 30 seconds, reconnect power to the modem. Wait a minute or so and reconnect power to the router. Wait a minute or so and check your internet connectivity.
3) Do a ping test to see if you are connected at all. Click the Start button, and on the Start Menu, select "Run." A small window comes up, in which you will type "cmd" (without quotations) and press ENTER. A command prompt window will come up with a blinking cursor. At the cursor type "ping yahoo.com" (without quotations) and press ENTER. Your PC will send 4 transmissions to see if yahoo.com responds. You will see about 10 lines on your screen - the 3rd line from the bottom should read something like this: "Packets: Sent = 4, Received = 4, Lost = 0 (0% loss)"
If you have 4 received and 0 lost, you're connected to the internet, move on to step 4. If you get 0 received and 4 lost, you're not communicating at all with the internet, skip ahead to step 5.
4) You're connected to the internet because you got a response from yahoo.com. Now we just need to get your browser working. Still in the command prompt window, type the following command (without quotes): "netsh winsock repair" then press ENTER
5) Go into the Control Panel and go to Network. Check your network connections to make sure that they are working properly and are Enabled.
If this doesn't get you reconnected, send me a message and we'll go for round 2!
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 16, 2009 | eMachines W4620 Notebook
My internet keeps disconnecting
It sounds like the wire from your house to the isp switch is faulty you should probably call them down to fix. Or it could just be the modem are you using the same modem for both computers? If so then that's probably the problem.
Mar 14, 2009 | Belkin (F5D7050) 802.11a/g/b Wireless...
Holden Rodeo 2001, check engine light keeps coming on!?
I'm having same problem on my 2000 model rodeo 4wd 3.2L V6. Other day check engine light came on. I checked engine bay nothing abnormal, or power loss. Next day light was gone. 2 days later driving, a sudden loss of power and light came up. After idling for a couple of minutes, drove off with light still on but all power back. 1 hour later of faultless driving loss of power for a minute or so. Engine temp normal. Had break for 1/2 hour and set off for last hour of journey without fault except check engine light still on. Following dayon startup light went out???
Seeking help from experts.
Feb 09, 2009 | 2000 Isuzu Rodeo
Download issue n inter net issue
try reinstalling your windows your OS might be corrupted from a Virus infection. viruses or worms usually hog your Internet , that might result to a slow internet connection..
Also if you have a 256kbps connection, your download speed of 25KBper sec is normal
because 256,000 kbps / 8bits = 32 KB/s (thats your maximum dl speed)
but assuming there is a loss in transmission about 15- 20% lost your max dl speed is only 25.6 KB/s thats why your connection is normal.
Jan 11, 2009 | Intel Pentium III , 900 MHz Processor
HTC TyTn II data connection problem
It keeps connecting because an application keeps wanting to access the internet.
Make sure you set your email to manually download messages.
Turn the Weather Tab off in HTC Home Screen as it automatically downloads the weather.
Turn off "QuckGPS"
Disable Error Reporting to Microsoft in the System settings
Also remember MMS messages will require internet connection.
Everytime you send a MMS or receive a MMS your phone will connect to the internet.
Jun 20, 2008 | HTC TyTN II Smartphone
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
