Wires going to flyback transfomer
I have a sony kv36fs120 tv. I am trying to replace the main board but cannot get the wires out from the flyback. Can someone please help me
  • Robert Graf
    Robert Graf Jan 25, 2009
    ok i understand but my problem is that i didnt get wires that go with the new flyback and this is why i wanted to remove the old ones from the flyback so i can use them. should they have provided the wires for me?
  • Robert Graf
    Robert Graf Jan 26, 2009
    I got my board from sony direct and called them back. They are sending me a kit for about 35 dollars so i can install my board.
    Habit-Forming:
  • 47 Answers
Wires going into the flyback are not removable but are integral to the flyback. The three wires comming out the flyback are the thick red one (anode button) which attaches to the tube is removed by pinching the button to release the clips on the tube. The other wire probably white is removed by unsoldering it from the small board on the neck of the tube and the 3rd and last wire is probably black, this is the one you may have your issue. To remove this wire, you must disassemble the tube socket..look for two tabs..pry open gently and seperate. Then with a small jewelers you'll be able to release the black wire..hope this helps.
Posted on Jan 25, 2009
  • GSampaia Jan 26, 2009
    Wow....Yes your replacement flyback should have 3 wires comming out of it that are part of the flyback...May I ask, where did you get this replacement board/flyback, can you tell if the wires were cutoff. I would call and let them know that the wires are missing. Sorry for additional questions, but have been repairing tv's for over 30yrs. and have never experienced missing flyback wires...have certainly seen them cut. Some Flybacks for Projection type tvs have removeable wires....but your tv is a crt/tube type which should have the three wires as discussed. Good Luck
3 Suggested Answers
Shuttle83
  • 1139 Answers
SOURCE: Picture weak and stays on only a few seconds.
Hello tellis356,
He replaced the Integrated High Voltage Transformer (IHVT) (I so hate the term flyback even though it is descriptive of the function of the component). However he may have only solved part of the problem. My next question is did he perform a diagnostic on the CRT (picture tube)? It may well be the CRT, but I would first suggest that you have the repairman check the voltage and signal levels in the horizontal section of the TV and check the video signal and voltage levels at the output of the Video processor to the CRT socket board. Then after these are tested and proven to be within specifications, then run a diagnostic on the CRT using a CRT test set. This way he'll know for sure if the problem is in the circuitry or the CRT.
I am suspecting that the first trouble you experienced was the set was completely out? If so that is why he may have replaced the IHVT. He should have also replaced the Horizontal Output Transistor because it is in series with the IHVT and would have taken some of the damage that the IHVT would have sustained. So having him check that too would not be out of sorts.
I hope this helps,
Thank you,
Shuttle83
Posted on Nov 22, 2008
FaceTheFacts
  • 245 Answers
SOURCE: The stand by timer light
You have a bad MCZ. Try taking a blow dryer to the right side of the TV to see if this fixes the problem.
http://cgi.ebay.com/LOT-2-MCZ3001DB-IC-SOCKET-MCZ3001D-670581001-/220499156868?pt=LH_DefaultDomain_0&hash=item3356c61f84#ht_1871wt_1020
You will have to find these and replace them both on the board to the most left of the T.V. There are two of them. The one closest to the back of the T.V. is probably the problem.
Posted on Jun 20, 2011
I want to find a flyback transfomer number in model no kv-21m3a(sony)
Look at MCM electronics. They have a huge line of flybacks there.. and sony is a common brand that they seem to carry.
Jan 05, 2015 | Televison & Video
My TV will not stay on...the power comes on and off 3 times and then stay off.
Problem will be in the Deflection board,Located on the bottom left handside it will have FBT flyback Transfomer on it, check Capacitors CP150, CP120, CP114. If CP 150 is Swollen or vented on Top the replace all 3 caps.2200uf 16v use 25v, 220uf 35v.
You ship board for repair to PTS 1-800-844-7871
These sets are also known for having Bad FBT flyback Transfomers and alot of Poor Solder Connetions
Jul 01, 2011 | RCA HD52W59 HDTV Projection Television
White lines on the screen.sounds ok.picture is coming behind white line.
Lines means Screen Drive is overdriving, try adjusting the Screen control on the FBT flyback Transfomer, adjust it down. If that does not Clear out Problem then replace the CRT Board that is connected to Picture Tube.
Jan 22, 2011 | Sony FD Trinitron WEGA KV-27FS100 27" TV
I have a Sony Trinitron Model number KV-35V65, 6 years old. The tv has presented with this problem. The screen will go black, the fan continues to run, and the power stand-by light blinks. It was doing...
Poor Solder connections can cause this problem ,first try resoldering board.Solder FBT flyback Transfomer Pinns. Encompass Parts Distribution is listing this Model.They also have Service Manual.1-800-638-3328
Oct 13, 2010 | Sony Televison & Video
The picture is closing from the top
needs service, resoldering the main board, changing of capacitors near the flyback transfomer area..in general it needs to be reserviced
Nov 16, 2009 | Orion1934 19" TV
When I turn on my rear projection tv the picture is fine, then all of a sudden it goes blurry, after about 45min you turn it off and then back on and the picture is fine. what could the problem be. the...
well if your tv was to be a normal tube tv, i could suggest to check your crt socket. in this case its projestion tv, so your are having three crt sockets. the main problem is with your main flyback transfomer. try to change the flyback and it should work back to normal. other way to test is try to adjust your transfomers focus, if it is adjusted, and goes blury again, then you need to change it,...and try to re-service the board...best luck
Oct 19, 2009 | Philips Magnavox 51MP392H Rear Projection...
HI I HAVE A 40" SAMSUNG LCD MMODEL LN-T4061F MY QUESTION IS YOU TURN REMOTE ON AND TV JUST CLICKS NO SOUND OR PICTURE WHAT COULD IT BE TAHANKS
POSSIBLE OF SOME COMPONENTS IN POWER AREA HAD BEEN DAMAGED, AREAS TO CHECK IS POWER AREA, NEAR FLYBACK TRANSFOMER...THE BEST OPTION IS TO RESOLDER THE MAIN BOARD..THEN TRY IT
Oct 14, 2009 | Televison & Video
D-Board
We got a new D-Board and we are trying to unhook the wires from the old flyback transfomer without breaking them.
Feb 20, 2008 | Sony KP-46WT500 46" Rear Projection...
Open Questions:
Televison & Video Logo
233 people viewed this question
Top Televison & Video Experts
