Question about Tools & Hardware - Others
My hubby bought something like this the other day. It says 5 blades. When I opened it either they are all stuck together or it is one blade made of 5 blades...if that makes sense. Have you used these before and if so, if it really is 5 blades, how do I get them separated without cutting myself. Thanks Lisa
  • David Ford
    David Ford May 11, 2010
    What are these 5 blades for, what type of tool and application. Please let me know and I will do what I can.
  • 10,865 Answers
Hi lisa. take the tool and the blades to your local hardware store and they will be able to assist u.
Posted on Feb 26, 2009
Have used my brand new Andis Excel clippers for 3 weeks. after a couple day started having trouble with clippers not wanting to turn on or they would come on but cut on and off several times before working...
install the clipper blades onto the unit properly
read the user manual on how to do it
From your description it indicates that the blade base is on the tang but the clipper is not inline with the activator and will click in a bit more
Mar 08, 2018 | Andis Health & Beauty
How to remov blades
The blade will be stuck on the shaft and both will be damaged and require replacement. With that knowledge you now understand that drilling a hole sideways through the blade cap isn't wrecking anything you are going to use again. You can then get something into the hole for leverage. Here in NZ blades are under $20 and motor shaft sleeve is about $5.
Aug 11, 2014 | KitchenAid Food Processors
How can I get kitchen aid blade out that is stuck
The blade will be stuck on the shaft and both will be damaged and require replacement. With that knowledge you now understand that drilling a hole sideways through the blade cap isn't wrecking anything you are going to use again. You can then get something into the hole for leverage. Here in NZ blades are under $20 and motor shaft sleeve is about $5. If you don't replace the parts it will happen again.
Aug 11, 2014 | KitchenAid Kitchen Aid 13-cup Food...
My blade is stuck on, how do I get it off?
May 28, 2014 | KitchenAid Food Processors
I have a Badger 5 (5-81A). The motor is humming when it's turned on, however, the blade does not turn. The blade does seem to move freely. Tried reset and hex key but still nothing.
you have something stuck in it more than likely,, use the key ( unplug it first) and turn it backwards,, keep looking inside with a flashlight for the lodged object once you see it,, remove it,, sometimes the key won't work if its something caught in the blades themselves, so use the handle end of a broom or plunger with a wooden handle to push on the blade itself to turn the unit over
May 02, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
The garbage disposal turns on, but the blades are not rotating. It sounds like the motor is not turning over.
Use wood stick or broom handle and see if blades rotate freely.
If blades are stuck, then use wood stick to wedge free the blades.
If blades rotate freely and disposal doesn't work, then disposal has gone bad.
Install new one.
For replacement instructions:
http://www.fixya.com/support/r7929008-replace_garbage_disposal
Jan 29, 2011 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
I used my dpc 6410 64 cc saw all day cutting pavers and seemed like my blade was bent , we called it a day n came back the next morning to find the blade was straight ... am i goin crazy er did it do that...
Make sure that the blade is on correctly. If there is something stuck between the blade and the mount it will make everything off. Or if the but holding the blade on is not on tight enough you will have the same issue.
May 29, 2010 | Makita DPC6410 64cc 12" Power Cutter
JR3050T blade lock lever is stuck
Put a blade in it.
This will release the locked open feature.
Dec 30, 2009 | Makita JR3050T Recipro Saw 9 Amp
Reassembling blades on hedge trimmer
the blades are stuck , i spray my trimmer with wd40 before every use to keep them juicy you should too. also sometimes if you hit a large stick it will put a divot in the blade cause ing it to stick. as for putting it together, find some one who can do it without directions. but when you use them next make sure you soak em good with wd40 or something if you dont i guarantee they will always stick. wd40 willl not hurt any shrubbery, as ive been doing it for years.
Jan 25, 2009 | Ryobi 18V Hedge Trimmer
Tools & Hardware - Others Logo
102 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
