Question about Dell Dimension 4600 PC Desktop
I have a DELL 4600 and conected new speakers but have no audio device. ie i cannot turn up the sound not allowing me to select. I dont know what to do any suggestions
  • Bill Fisher
    Bill Fisher Jan 30, 2009
    Where do I get the sound driver download from?
  • Anonymous Feb 03, 2009
    my computer will not play any sound.
  • 3,940 Answers
Re-install the sound drivers and ensure that the sound card is propertly selected as the default playback device in CONTOL Panel, Sound & Audio Devices, Audio tab
Posted on Jan 25, 2009
Dvd driver modelCSAJ426911932,my computer does not have sound card ,it has it in the motherboard.alternative conection??????????
you might have to get a portable usb sound card if you mean dont have a sound card installed also
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers also
control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Jan 02, 2011 | Computers & Internet
I have a dell computer that runs windows xp. im not a complete idiot but im not very computer savvy. I was messing around a few weeks ago trying to clean up my system from the previuos owners stuff . i...
Many Dell PCs have an internal speaker that will allow sounds and even music to play - it is just not as good as the external types that offer sub woofers and stereo sound. As long as you're hearing the familiar Windows Sounds and not simple beeps - your sound card drivers are probably ok.
This makes me think that you've either inserted the speaker plug into the wrong jack on the PC or have an issue with the speakers themselves. Generally, these jacks are color coded. If yours are, make sure that speakers are connected to the GREEN jack. If not color coded there should be an indication of an arrow pointing OUT or a speaker icon near the speaker jack. If still no luck, it is possible that the cord between the plug and the speakers has gotten pinched or broken. Try plugging a pair oh head phones into the jack - or plug the speakers into another device with a speaker jack. I'm pretty sure you'll get your answer after doing that. Some final thoughts: Maybe your speakers need power? Are they plugged in? Is the outlet powered? Is there a power indicator? Is the volume knob turned to minimum?
If you still have problems - provide the model number of your Dell PC and we can dig some more - but I think you'll find the problem if you follow the steps above.
I hope this was Very Helpful - and good luck!
Mar 15, 2010 | Computers & Internet
I have just installed speakers on my computer, but I can't get any sound.
Check to make sure the speakers power up.
Check to make sure you have installed the speakers into the correct jack on the back of the PC.
Go into Control Panel and check the settings by double-clicking the "Sounds and Audio Devices" icon. Make sure the Mute box isn't checked and that the volume is turned up.
Dec 09, 2009 | Dell Dimension 4600 PC Desktop
Laptop speakers & hp jack dont work, works with line in only
first try to reinstall audio drivers, remove audio device from device manager, install new drivers.
Apr 13, 2009 | Dell Latitude D820 Notebook
Have no sound
hi! here is the answer:
Audio Output
  • Type Sound card - Integrated(Any Audio Card that fits the pci slot
  • Sound output mode 5.1 channel surround
  • Audio output compliant standards AC '97
  • Speaker(s) Desktop
Rate me please.
Apr 02, 2009 | Dell Dimension 4600 PC Desktop
Scratching (static) noise coming from computer speakers
I foudn this in anther forum:
I have an ASUS motherboard P5E3 Premium. The audio that came with it was the Sound Max audio. I also noticed abnormal sounds coming from the speakers. They included sounds during hard drive activity and also with mouse movement. They were not loud but noticable. I searched all over the web but didn't find the answer. I stumbled across the fix myself. I also have vista-64. In the sound control panel > speaker properties > levels... there is a pc beep slide bar. I noticed that if it is disabled then the abnormal sound went away completely. Problem solved. Hope this helps.
Nov 18, 2008 | Dell Dimension 4600 PC Desktop
Sound
Check the control panel and see what your default sound device is set for.
Do you have a third party sound card like a sound blaster plugged into here?
Jun 10, 2008 | Dell Dimension 4600 PC Desktop
Had to reboot and somehow driver for windows media says can not play no driver for speaker was installed
Over here:
http://support.dell.com/support/downloads/index.aspx
Audio - audio device - drivers. are what you need.
Speakers don't need drivers the sound device needs them
If you need anything else let me know
May 11, 2008 | Dell Dimension 4600 PC Desktop
No sound
Is this a Dell Dimension 4600 PC Desktop?
If so I can help you find sound drivers for it. You have to figure out if the speakers are the problem if you do not get an obvious error to indicate that it is a software problem.
Have you;
Checked power?
Checked plugs to make sure they are in the right place?
Swapped out the speakers with a set that you know work?
Used headphones to make sure the sound is actually coming out of the computer?
Let me know the answers to these questions please.
Dec 21, 2007 | Dell Dimension 4600 PC Desktop
Dell Dimension 4600 PC Desktop Logo
140 people viewed this question
Alun Cox
