Question about Dell Computers & Internet
Which CPU's will A Dell GX280 MB ser # CN-OH726 support
I replaced a damaged power supply and Motherboard on my Dell Optiplex GX280 P4 3.6GHz Mini-tower. The 4 prong 12V power connector had a fried pin (molten and blackened) on it when I dismantled the PC.
I got a new power supply and located a MB taken from a GX820 and attempted to utilize it as a replacement.
The new MB, Ser# CN-0H7276-13740-56F-01XG powers up and reports that the CPU is not supported.
Is there any way to determine which CPU's can be supported or would resetting the BIOS allow the CPU to work?
The physical configuration (3 PCI slots, 1 PCI-e, 2 SATA etc), the sockets (LGA775) are all the same as well as the intel chip (FW82801FB)
  • travlin_man6 Jan 25, 2009
    Sorry, the new MB was taken from another Optiplex GX280 (unknown configuration).
    This is a FOXCONN MoBo (LS-36 per the sticker on the board) and does come up on a search at the FoxConn website.
    Typically there is a range of processors that will function on a motheboard but may require a change in setting (voltage jumper, clock speed, etc) in order to function. I am looking for any information on this board from Dell that would help me determine what CPU;s will work and any specifications available.
  • 741 Answers
The CPU must match the motherboard. You can go to the MOBO manufacturers website and find out exactly which CPU fits on that model. Without that information from the manufacturer you may fry something on the board.
Don't forget to rate this solution before logging out.
Posted on Jan 25, 2009
  • Randall  Trahan
    Randall Trahan Jan 25, 2009
    Go to www.hardwaresecrets.com
    They have good information on tricks to find motherboard types and many other things that may help you.
We have around 30 units of DELL Optiplex GX280 having mother board failure. It was more then 3 years old already. Once the turbo fan become noisy then it will gone dead.
May be serious. See if the power light goes amber after power up. I had (have - still siting in my basement) one that did same. Power up, fans sound like 747 taking off. Power light goes and stays amber. This is USUALLY caused by bad capacitors on the mother board. Known GX280 problem going back. If you look on the motherboard, the capacitors should have flat tops and not leaking. If the are rounded or leaking, the MB has probably gone bad.
I obviously can not be 100% sure about this as the unit is not here.
You can google "gx280 solid amber light loud fan" and see the issues. Here is one such link.
http://en.community.dell.com/support-forums/desktop/f/3514/p/19253544/19414291.aspx
Feb 16, 2011 | Dell OptiPlex 330 Desktop Desktop Computer...
I am looking for a schematic for a Dell Optiplex GX280 power supply. The supply is model HP-U2106F3.
I just replaced my GX280 power supply (mini-tower) with the following 400W for $30.
http://www.cputopia.com/hp-400w-dell-optiplex-gx280-mini-tower.html
The only place I can think you will find an actual schematic for the PSU is from the manufacturer.
Feb 13, 2011 | Hi-Pro Refurbished HIPRO POWER SUPPLY FOR...
I have dell optiplex GX280 when i press the power button i dont get any display and cpu fan reach to its max speed how can i fix this prob?
May be serious. See if the power light goes amber after power up. I had (have - still siting in my basement) one that did same. Power up, fans sound like 747 taking off. Power light goes amber. This is USUALLY caused by bad capacitors on the mother board. Known GX280 problem going back. If you look on the motherboard, the capacitors should have flat tops and not leaking. If the are rounded or leaking, the MB has probably gone bad.
You can google this and see the issues. Here is one such link.
Feb 11, 2011 | Dell OptiPlex GX280 PC Desktop
I have dell optiplex gx280 computer.i am facing problem of CPU high fan speed when i turn on the PC.it goes to full noise like a jet fighter and nothing get appeared on the screen and fan continuously gone...
dells usually go full blast on power up then slow down to normal,sounds like fan is not responding to slow down signal i would try replacing fan, its got to be a dell fan
Jan 08, 2011 | Dell Optiplex GX280 (99301) Motherboard
Massive noise, now unable to access computer at all. constant amber light, not moving to next stage, nothing on screen, several thermal events previous to it blocking my access
Noise is most likely CPU Fan racing. Fault is most likely motherboard failure (Solid Amber power LED is usually MB and thermal events could be associated) Replace the motherboard
Feb 17, 2010 | Dell Optiplex GX280 (99301) Motherboard
Optiplex gx280 won't boot and cpu fan goes faster
Sounds like a bad motherboard, I try resetting the bios , removing everything but the video , could be a bad power supply too (if you have one jump the wires in there as a test). you can buy those dell MBs cheap on fleabay.
Eric
Jul 30, 2009 | Dell Computers & Internet
Dell GX280 High Speed Fan and No Display.
i had same problem today and i tested my machine and solved the problem at last.
the problem is the thermal value that your mainboard sets for your cpu.
please replace the mb.
ps: before this process,i tried almost everything . cpu fan , memory , cpu , cables ,case ... everything. but the problem is on your mb.
Feb 04, 2009 | Dell OptiPlex GX280 PC Desktop
Problem withe dell gx280 fan and display
Unfortunately this seems so be a motherboard problem, Dell's solution is to replace the motherboard I'm not sure there's much you can do at home or work to fix this - if it's still under warranty get dell to replace the motherboard if not im afraid its the bin for it sorry
Feb 02, 2009 | Dell OptiPlex GX280 PC Desktop
Dell GX280 no display
plug in a video card in a pci slot and see if your video comes on and do the same with your agp slot
Jan 25, 2008 | Dell OptiPlex GX270 PC Desktop
Computers & Internet Logo
1,231 people viewed this question
Alun Cox
