Question about Intuit QuickBooks Pro 2008: Windows
Landtech dos for windows - new systems (XP) need to windows
Hi, We recently upgraded our computers to XP. Currently an office system LANDTECH is running our forms through a DOS program. Landtech for windows however is also loaded... We want to upload the DOS version forms into the Landtech Word database... not sure how... if we can't do that, i need to solve the problem regarding network printing as Landtech DOS has LPT ports (which are obviously defunct on the XP machines) and we need to change the LPT ports to read the USB connection to the network
  • jpak Jan 29, 2009
    Unfortunately the Hub would have worked, but there were other elements that came into play, that I didn't factor in when I sent the "SOS"... Thanks for the response though!
  • 101 Answers
You can get a hub for the lpt and usb try www.tigerdirect.com
Posted on Jan 25, 2009
Error in ms office
Rename and Reinstall the Vbe6.dll File
NOTE: You need your Office CD-ROM to complete this task.
  1. Quit all currently open programs.
  2. Start an MS-DOS prompt in a window by doing one of the following:
    • Microsoft Windows 95 or Windows 98: Click Start, point to Programs, and then click MS-DOS Prompt.
    • Microsoft Windows Millennium Edition (Me): Click Start, point to Programs, point to Accessories, and then click MS-DOS Prompt.
    • Microsoft Windows NT 4.0: Click Start, point to Programs, and then click Command Prompt.
    • Microsoft Windows 2000 or Microsoft Windows XP: Click Start, point to Programs, point to Accessories, and then click Command Prompt.
  3. To change the directory to the location of the Vbe6.dll file, type one of the following (including the quotation marks), and then press ENTER: CD "C:\Program Files\Common Files\Microsoft Shared\Vba\Vba6"-or- CD progra~1\Common~1\Micros~1\Vba\Vba6NOTE: This is the default directory for the Vbe6.dll file. If you installed Microsoft Office into another drive or directory, you must type its path.
  4. To unregister the Vbe6.dll file, type the following.
    In Windows 95, Windows 98, or Windows Me, type: C:\Windows\System\REGSVR32 /U VBE6.DLLIn Windows NT 4.0, Windows 2000, or Windows XP, type: REGSVR32 /U VBE6.DLL-or- C:\Winnt\System32\REGSVR32 /U VBE6.DLLNOTE: This is the default directory for the Windows System directory. If you installed Windows into another directory, you must type its path.
  5. In the MS-DOS prompt window, rename Vbe.dll to Vbe.old by typing the following and then pressing ENTER: rename vbe6.dll vbe6.old
  6. Quit the MS-DOS prompt window. To do this, do one of the following:
    • Type Exit at the command prompt, and then press ENTER. -or-
    • Click Close (the X in the upper-right corner of the window).
  7. Start Microsoft Word.
  8. On the Tools menu, point to Macro, and then click Macros.
    The Windows Installer detects that the Vbe6.dll file is missing on the system, installs the file from the Office CD, and registers it again.
Mar 23, 2010 | Microsoft Office Professional 2007 Full...
Got a new imac moved ms office file to my book -
Try to change the File system of the hard drive to FAT. It is currently in NTFS. Mac recognizes NTFS file system as read only. You must use the disc utility and format it with a volume format of MS DOS.
By changing it to MS DOS (FAT) you can use it with Mac and PC. Readable and writable.
Aug 04, 2009 | Western Digital My Book Essential Edition...
I am not able to install Windows XP on Compaq Presario CQ60-104TU
Recommend removing OLD DOS Operating system First. Then Install Windows XP. XP will NOT upgrade older systems unless it's Windows 98 and Fully Updated. However, can NO Longer do because Microsoft does NOT support any versions other than "2000/ME/XP/Vista".
Jun 09, 2009 | Computers & Internet
Unable to save anything!
You are still using a trial version of the office. Microsoft Windows office will not allow you to save once your trial version expires. Check to be sure you have a full version.
Uninstall all former versions.
Check your system clock to be sure its using a current date and time.
Install the full version of windows office and you should be ok. Cheers
Apr 24, 2009 | Computers & Internet
Installed a new hard drive
Well, since the new hard disk is not formatted, and there is nothing currently on it, you will not get a dos prompt or an operating system detected. What you need to do is insert your Windows XP disk, then reboot the machine. When you see the HP screen, tap the F12 key, which will take you to a boot menu. On the boot menu, choose your CD drive, then the computer will boot from the windows disk. From there, just format your disk, and install Windows.
Apr 14, 2009 | HP Pavilion 520c PC Desktop
Failed attempt to upgrade to XP
Do you know how to get to the DOS prompt? Or do you have an ME floppy that you can boot from? If so, you can run the DOS FORMAT command to remove the partition that XP created. The syntax is here:
http://www.computerhope.com/formathl.htm#03
BTW, upgrading to XP from an ME system can be very tricky because of the incompatibilities between hardware. On the systems that I have upgraded, I've disconneced/removed all but the necessary hardware, including floppy drives, modems, sound cards, etc. And if you still have problems, consider a newer/replacement video card.
Jun 10, 2008 | Computers & Internet
New graphics card
Intel Pentium® III, AMD™ Duron or Athlon™ class processor or higher
128MB system RAM
A 300W system power supply
An AGP 2.0 (or higher) compliant motherboard
50MB of available hard disk space
CD-ROM or DVD-ROM drive
Microsoft® Windows® 98, ME, 2000, XP, or Windows®
VGA or DVI-I compatible monitor
This is what you need for graphic card to work!!!
Its very good card!!!
Jan 22, 2008 | Computers & Internet
hi,
i don't think you really need dos. just in case, you can download it from the following link.
http://www.microsoft.com/downloads/details.aspx?DisplayLang=en&FamilyID=96cc3197-b7e5-4b31-badb-ddaac771295f
Good luck
Jan 20, 2008 | Computers & Internet
Upgrading windows xp to vista
You can upgrade from your current edition of Microsoft Windows XP or Windows 2000 to a corresponding or better edition of Windows Vista by purchasing and installing an upgrade copy of Windows Vista.
While selecting the edition of Windows Vista that's right for you, it's important to clearly understand what hardware your PC will need to ensure the features you want will run reliably.
Nov 16, 2007 | Computers & Internet
Intuit QuickBooks Pro 2008: Windows Logo
135 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
