Question about Dishwashers
Need service manual and wiring diagram
I have a wire hanging and a small leak only during the rinse cycle. Model is a Frigidaire FDB641RAS0 Dishwasher
    President:
  • 2,651 Answers
Ther are not many places for wires to be hanging from , it should be obvious where it should go, as far a leak the most common place is from the heater connecter(s) small brass lock nut on right side of unit, 2 of them holding the heater in. the brass is quite soft andusually cracks straight down the entire nut and needsto be replaced.
Posted on Jan 25, 2009
My Kitchenaid model KURD25SHBL0 dishwasher is not draining. Drain line is clear, wash cycle runs fine, and there is no obstruction to overfill sensor. Can hear pump runnng during drain cycle but no...
Usually the wiring won't affect the direction of the pump turn. It is more likely that the fins on the drain pump empellar are damaged.
May 30, 2011 | Dishwashers
FRIGIDAIRE LEQ2152 what are the diminsions of the unit?
Hi and welcome to FixYa, I am Kelly
Sorry to keep you waiting. I just now saw your post.
The installation instructions with dimensions is here: (2.94 mb)
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134917700es.pdf
(^-See page 6)
Owners manual:
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134763300een.pdf
Wiring Diagram:
http://manuals.frigidaire.com/prodinfo_pdf/Webster/134509400efs.pdf
Firgidaire manuals if the above is not the correct model:
http://www.frigidaire.com/manuals Enter your model number and all of the manuals for the model number you entered (like above manuals) will be availble for download.
Thanks for choosing FixYa,
Kelly
May 17, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
Spin/rinse cycle quits
it may be an intermittent door lock switch. i believe on your model when you remove the front access panel you will find a pair of wires in a plug with nothing attached to them on the r/h side where the wire harness runs. when you are in the spin cycle, check with a multimeter for 0 volts across the 2 wires. if you are showing 120 volts, then your door lock is bad. if yours has never been changed it actually has been updated to a new style. costs about $120.00 for the part. instructions should come with revised part
Aug 20, 2009 | Washing Machines
Frigidaire Model FDB2810ldc0 s/n:TH43526319
Dishwasher is leaking water from underneath during the rinse cycle and a small drip during the wash cycle
Sep 22, 2008 | Dishwashers
Test bosch heating element
remove the kick plate at bottom of dishwasher, at the left leg there will be a wiring diagram. remove console and test element from there. diagram will show which wires to test
Nov 16, 2007 | Dishwashers
Jenn-air manual
You can find everything you need and diagrams at http://www3.sears.com/.  Just type in the model #.  There is no repair manual that I know of.  If you need help solving a problem once you have seen the wiring diagram let me know.
Oct 12, 2007 | Kitchen Ranges
Dishwashers Logo
179 people viewed this question
Top Dishwashers Experts
