Wishing to set up voice message centre on Brother fax-520mc for caller to leave message. I have lost the manual.
My answering machine won't pick up to external callers
Try Googling (Panasonic)(KX-T7456)(manual) without parens to get instructions.
Jun 05, 2017 | Panasonic KX-T7456 Corded Phone
Have lost my instructions for a brother fax 520mc where can i get one please
You can download the manual here: http://www.givemefile.net/smanuals/faxes/brother/fax-520mc.html
Mar 13, 2011 | Brother FAX515 Roll paper Thermal Fax
Manual for a Brother Fax-520MC
Well you may please follow the link below to get your manual -
http://www.devicemanuals.com/guide/Service%20and%20Repair/Brother/Brother-FAX-520MC-Fax-Parts-List-==TXpFd09Ua3g=.html
Good Luck!!
Thanks for using FixYa!!
Aug 20, 2010 | Office Equipment & Supplies
Program Fax-930 brother machine so it answs fax call on 6 rings
Here is the users manual for that;
http://www.fixya.com/support/p170643-brother_fax_930_all_in_one_thermal/manual-1604
Mar 16, 2009 | Brother FAX 930 All-In-One Thermal Printer
Setting up the Answering machine
http://www.vtechphones.com/vtechui/support/manual_list.cfm
Dec 18, 2008 | Vtech 5.8GHz Cordless Phone with Digital...
Brother 685 MC Answer phone & fax
Download Brother FAX-685MCowner's manual. It is free.
Oct 06, 2008 | Brother Office Equipment & Supplies
Brother Multi function centre with fax, MFC 885CW we have the setting on F/T, it answers a fax after 2 rings, if a call coming in it keeps ringing, but on callers end it keeps beeping fax noises, callers...
I had the same problem using my Brother MFC 8460N fax on the same line as my regular telephone, which has an answering machine.
There was nothing wrong with my equipment. It was a set-up issue. I solved it as follows, and maybe this will be helpful to you:
Here's what I did, step by step:
1. Put your MFC and your telephone near each other, and within reach of a phone wall jack.
2. Go to the fax machine. Take the telephone line with the clip on the end of it that comes out of the fax machine. Put that into the telephone wall jack.
3. Go to the answering machine. Take its telephone line with the clip on the end of it and put that into the BACK OF THE FAX MACHINE. The port on the back of my fax machine says something like EXT TAD which means external telephone answering device.
4. Go back to the fax machine. You'll now need to play around with the menu options for the fax. My Brother MFC shows this stuff in a little screen on the front. Try and find the Fax Setup options. Next, try and find the Fax Receive options. If you do, select something like External TAD fax receive mode. Do not give up, you're almost done.
5. Next, set ring numbers on both devices, the fax machine and the answering machine. I set both devices' ring numbers to 4. I don't know if these are the optimal settings, or what happens if you set them at different ring numbers. I only know that a "4 and 4" setting works for me, and am not inclined to mess with it.
6. Final detail: the setup should be transparent to a voice caller. Someone who is sending a fax, though, might be a little confused IF, like me, they lean over to listen to their fax machine dial and screech, just to be sure it's working. Such a person may faintly hear my outgoing answering machine message before they heard my fax machine's screech kick in. They might think that they had a wrong number, cancel the fax, try again, call me with questions, etc., etc. So I changed my outgoing message to something like: 'You have reached xxx xxx xxxx. To leave a voice msg, please wait for the tone. To send a fax, please continue the transmission and it will be printed. Thank you!'
That's it. Hope this was helpful.
Best,
Wilbere
Check out my listings on http://stores.ebay.com/WILBERE
Aug 07, 2008 | Brother Office Equipment & Supplies
Brother 4100e Fax Problem - Caller ID won't work with Fax Machine
Usually, fax machines don't have caller ID capability.. If the sender's fax number appears on the faxes you receive, it's just that they have programmed it into their fax machine as a header.
Jun 29, 2008 | Brother IntelliFax-2820 Laser Fax
Lost instruction manual
Go to website www.fax.philips.com
Then click on Support and then click on the Sagem link.
Select Fax Philips and then PhoneFax Philips.
Select product from drop-down list.
Select User Manuals and then the appropriate version.
Feb 28, 2008 | Philips Magic5 Voice DECT Duo - Fax /...
49 people viewed this question
k24674
jasbo
jasbo
