Question about Seiko SKA192 Wrist Watch
My whatch Seiko 8F33 finished the battery
I think I left my whatch long time with out battery. When I replaced the battery, the secounds start jumping each 5 secouds and the calender not work. If somebody know about this problem please help me.
    New Friend:
  • 122 Answers
Try to clean very well the contacts of the battery.
Posted on Mar 15, 2010
  • 343 Answers
Here is the manual for your watch.
Hope this helps
http://www.seikowatches.com/support/ib/pdf/SEIKO_4F32_8F32_8F33.pdf
Posted on Jan 21, 2010
SOURCE:
I'm trying to find a battery to a Seiko watch, serial # 152635. The case # 8f33-0010.
Take it to a jeweller, $6 to $8 and takes 10 minutes. Most have a screw back. They have the batteries, the tools and the know how.
Jan 05, 2017 | Seiko Watches
I put a battery in a seiko 8f33, the time and day are working fine.The date will not work. I have been thru the process of reprogramming. What have I done wrong???
Your watch has a perpetual calendar which can only be set from inside the watch using the touchpads around the edge of the movement.
This link is for the instructions
http://www.seikousa.com/support/ib/pdf/SEIKO_4F32_8F32_8F33.pdf
Dec 05, 2012 | Watches
Seiko SGF204 second hand hesitates or jumps a second and looses probably 10 minutes an hour. Any suggestions would be appreciated. Thanks
When the watch jumps a second or seems to stop then tick twice, it indicates that the battery is low. You will need to take your watch to have the battery replaced.
Feb 28, 2011 | Seiko SGF204 Wrist Watch
I cannot get my Seiko SNA304 chronograph second hand to reset after battery change. Keeps resetting to the 17 minute position, I have tried to use the manual instructions but with no success, Any help...
Seiko watches are a popular accessory for both men and women. The history of Seiko watches goes back to 1881 long time ago, when the company that was to become Seiko began. From the beginning, the method to set a Seiko watch has been designed to be a simple process.
The following are the steps to set a Seiko watch for the time, day and date function, and for setting the chronograph on an analog watch.
Set the Time:
  • THE CROWN
Pull the button on the side of the watch carefully, the crown, out to its most extended position. You will need to unlock the crown if your watch has a locking crown. To unlock, turn the crown counter clockwise. While the crown is pulled out in the setting position, the watch will cease functioning.
  • 12 O'CLOCK POSITION
Turn the crown clockwise to move the hands of the watch past the 12 o'clock position on the dial. The day and date will change to indicate AM setting but will not change for PM setting. It is recommended that you set a Seiko watch in the morning for instant day and date setting; however,this can be done manually.
  • FINISH
To finish setting the time, simply push the crown until it is flush with the side of the watch.
Good luck and thanks for using fixya.
Dec 18, 2010 | Seiko SNA304 Wrist Watch
Hi, I am a seiko 8f33 perpetual calendar watch. I just got it back from Seiko...had the battery changed and new band. the problem is that I tried to set the date and the watch stopped working. Does...
If your watch stopped working while changing the time it can be for a couple of reason . One is i never set the watch between the hours of 11 pm and 4 am or else your movement can be damaged. The main reason is usually that the watch crown was not pushed all the way in to the first set . If the watch crown and stem is pulled out and not in the start position the watch will not run. Also after setting time you might need to reengage the watch by pressing on the jumper buttons on the top side of the crown they look like push buttons.
Oct 17, 2010 | Seiko SKA192 Wrist Watch
Secound hand jumps every four secounds,but watch keeps correct time.
It may be that the battery is running low. Have you had the watch for some time?
(Other watches use a similar behaviour to indicate low battery).
May 13, 2010 | Luminox 3007 Original Navy Seal Diver...
Reset timer after battery change in seiko sna285
If the stop watch hands are not in the "0" (12 o clock) Position, follow the prodedure below to set them to the 12 o Clock position
1, Pull the crown to secound position
2, Press Button "A" for 2 seconds.
3, Press Button "B" to Adjust the minute Hand to "0" Position
4, Press Button "A" for 2 secounds then press Button "B" to adjust secound hand to "0" Position
5, Press crown into normal position
AmFix Jewelry & Watch Repair
203 N. LaSalle Street,
Chicago, IL 60601
Ph: 312 641 7000
Email: [email protected]
Web: www.goamfix.com
Aug 28, 2009 | Watches
Second hand doesent return to 1200 position after replace batt
I just replaced the battery in my 20yr old Seiko chrono sports 100. And I had the same problem. I think I stopped it on 12 while in stopwatch mode and held down the start stop button and the set button at the same time. See if that works dude.
Dec 06, 2008 | Seiko Le Grand Sport SDWF73 Wrist Watch
Seiko Kinetic that doesn't work
This watch does not have a battery, but has a capacitor which is rechargable. It is not taking a charge, and needs to be replaced. You should take it to a store with a watchmaker ON THE PREMISES. Or you could send it to: www.bscwatchrepair.com
Jun 27, 2007 | Seiko SKA192 Wrist Watch
Seiko SKA192 Wrist Watch Logo
473 people viewed this question
Top Seiko Watches Experts
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Vernon Taylor
Are you a Seiko Watch Expert? Answer questions, earn points and help others
