Question about GE Advantium 120 Convection/Microwave Oven
Advantium circuit board replacement - GE Advantium 120 Convection/Microwave Oven
Display is blank
If the display is blank, and the oven works, 9 times out of 10 it is a problem with the circuit board that drives the display.
Apr 16, 2014 | GE Advantium 120 Convection/Microwave Oven
My GE Advantium microwave is beeping about 5 times every 2 minutes or so. The display says, "Keypanel Shorted. May need service. Press CLEAR to continue." Ironically, I need a working keypanel to press...
check the touch pad or control unit any short circuit in the control unit, other wise any moisture at control unit chec the circuit other wise replace the touch pad.
Jan 28, 2014 | GE Advantium SCA2000B Microwave Oven
Only microwave not working
Chances are you have a bad secondary / cook relay on the control circuit board. The relay can be replaced. See details here.
Jul 06, 2013 | GE Advantium 120 Convection/Microwave Oven
Advantium won't shut off
The problem is the microprocessor control board, professional should verify.
Mar 11, 2012 | GE Advantium 120 Convection/Microwave Oven
I have a GE Advantium Microwave Model # SCA1000HWW, where the lights stays on, the fan is on and the turn table is spinning when you shut the door.
Main relay RY1 on your main PCB is shorted.
You can order a new board (part number WB27X10776) for $167.20 from the Pros here. They're our favorite supplier.
Or we can repair your circuit board with our $39.95 service.
The service manual will help you with disassembly. It's here.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly if you need further help.
Jun 20, 2011 | GE Advantium 120 Convection/Microwave Oven
My GE Advantium model SCA1000HBB01 was cooking on the oven setting and suddenly quit working. As if no power. The circuit is still good. I was advised it was possibly a blown fuse inside the MV on the...
When you take the top off and stare into the unit you will see a white fuse in a black plastic fuse holder. Look carefully. I had to replace the melted fuse holder as well. Radio shack has the fuses and holders.
Sep 14, 2010 | GE Advantium 120 Convection/Microwave Oven
We have had a lot of problems with the Advantium overheating and blowing the thermal protection fuse or switch located on the left side of the microwave. It was replaced twice under warranty, and a...
Thats a defective product, and it should have just been replaced with a new one under warranty. Any device that is blowing out a recomended fuse rating frequently is defective. The product itself is overloading the fuse, and making it blowout. Do not under any circumstance replace it with a higher fuse rating. This will make the product a fire hazard. The technician should have looked into the problem which is not the fuse.
Nov 25, 2009 | GE Advantium SCA2001BSS Microwave Oven
GE Advantium mircrowave oven
The problem with my Advantium was the fuse inside the microwave.Thanks to all of your fixya emailers ,I was able to change the fuse myself.I would recommend your site to all as you were a great help to me. Thank you, wlpasko.
Apr 09, 2009 | GE Advantium SCA2000B Microwave Oven
Advantium 120 fan and tray keep running
Looking at the service manual here, I'd bet that relay number RY6 is shorted on the "sub PC" relay circuit board, or its driver transistor on the main "smart" board is shorted.
Unless your technician does component-level repair, he'll probably want to just sell you a new sub board, or main ("smart") board, or both.
They list for $64.78 and $109.83 respectively here. Hard to tell what they'll mark them up to.
Then add about $150-200 for the labor.
On the other hand, we regularly repair such control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
Or you can tell your technician about our services.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Jan 07, 2009 | GE Advantium 120 Convection/Microwave Oven
GE Advantium 120 Convection/Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
