Question about Frigidaire FRS23KF7AB Side by Side Refrigerator
Ice on the bottom of freezer
Ice froms on the bottom of freezer want to know why this is happening ive have about 6 in. of ice on the bottom of my freezer please help
  • 31 Answers
Sounds like your freezer drain is blocked. first, turn the temperature controller up a little bit, maybe one or two stops, then wait 24 hours to see if the ice melts at all. If it starts to go away, then you may need to toss a few towels on the floor next to the freezer because 6 inches of ice melt is gonna make a mess.
After you get that sorted out, turn the temp down one click to make sure that everything is staying cold, and that the ice is not reforming.
good Luck!
Posted on Jan 25, 2009
Why do I have ice buildup on freezer floor of my samsung?
Check for a clogged drain line. Snake out and get some vinegar in there. Any water collecting from the defrost cycle is supposed to be led away and outside from the unit
Sep 04, 2017 | Freezers
Ice build up in bottom of freezer
somewhere in the back of most freezers there is a drain line. mine thought is yours must be plugged up. sometimes you can look in the back of the unit on the outside to see that hose. do what you can to try and clear it
Jul 05, 2017 | Refrigerators
Bottom mount Freezer Iced up
if you have frozen water droplets on everything most likely the door was left open and when the warm air mixes with the cold air in the freezer this happens,look at the top of the door or the sides of the freezer door,also up on the ceiling where the light switch is,if there's ice there the door was left open,common problem with freezers on the bottom,you can shut down the machine,and with a hair dryer blow the hot air into the vent holes in the back inside wall of the freezer and if ice is on ceiling melt that out too.good luck.
Jul 09, 2012 | Kenmore Refrigerators
Heavy Frost in the freezer
There are a few reasons for frost building up inside the freezer compartment. Refrigerators work like dehumidifiers collecting the moisture in the air inside and defrost is supposed to remove the moisture while defrost through a drain and then to the defrost condensate pan below the refrigerator. Ever notice how ice in freezer over time the ice cubes become smaller? Or food that is not sealed dries out. You either have one of three problems. Defrost drain blocked behind the rear wall in back of freezer, air leaking into freezer through the door seal and in your case the drawer seal and finally water possibly leaking into freezer from Ice Maker, Let me know, Thanks Sea Breeze
Jun 19, 2010 | Samsung RF265AA Bottom Freezer French Door...
Water/Ice pooling in bottom of freezer
check out the drainage hole if it is properly closed.
Feb 20, 2010 | Amana Freezer DeepFreeze AFU2067BW 19.6...
My Maytag side by side fridge freezer is leaking at the bottom and ice is collecting at the bottom of the freezer. I cannot find any model number but think it's about 6 years old
The drain is clogged behind the wall in the freezer you can do one of three things take the back wall inside the freezer off and thaw the drain in the bottom and clear it out,Pay someone else to do this,or you can mover your food for a day unplug the unit open the freezer door and leave it off for 24 hours allowing the ice to clear from the drain,seems to happen about every five or six years with Maytags..
Aug 12, 2009 | Maytag Freezers
Amana freezer on the bottom not keeping temperature
Hi, If you had ice, there is a drain plugged in the freezer. If you had a frost build up, there is a problem with the automatic defrost.
I can help in either case. Please let me know if you need more assistance.
Thakns
Vic
May 13, 2009 | Nor-Lake Freezer Norlake Refrigeration 6'...
Water "pouring" from freezer condenser
sounds like drain in freezer is clogged and has iced over
so when unit goes into defrost water leaks into freezer bottom and freezes
you can either shut off fridge for a day and let ice in drain melt
and hopefully clear line
or u can take back cover off freezer section pour hot water in drain pan and make sure drain hole is cleared and draining down to pan
Jun 21, 2008 | Sub-Zero 611 / O Bottom Freezer...
Freezer wall ices up, fridge not staying cool
Is it ice in the freezer or frost? snow like.. big difference in problems
Sep 13, 2007 | Kenmore 72912 / 72914 / 72919 Bottom...
Ice tray stuck
Hi My Samsung freezer was nor a RB2155 it is a RS2630SH however after not making any ice because the tray was stuck in the upside down position or thereabout after 6 weeks it suddenly started making ice again, we had not done anything to it but we heard it dropping ice one evening and we had a look in the ice container and low and behold the ice box was full to the top, I would still like to know why it went like that in the first place in case it happens again it is a mystery. Larry
Oct 09, 2006 | Samsung RB2155 Bottom Freezer Refrigerator
Frigidaire FRS23KF7AB Side by Side Refrigerator Logo
134 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
