Question about Stewart Warner Cessna 172 Oil Temp Cluster Gauge w/ Capillary Tube, 823255
823255 stewart warner - Stewart Warner Cessna 172 Oil Temp Cluster Gauge w/ Capillary Tube, 823255
Old schematics
It would be a Stewart Warner radio. The schematic is available as a JPG for a $1 download. But most likely, not nessesary as the components are very accessable and visually troubleshot.
Aug 17, 2014 | Radio Communications
Does Martha Stewart have a good blueberry muffin recipe?
Here is a link to Martha Stewarts famous blueberry muffin recipe. You can actually replace with any kind of berry you like. I always make them with black berries, blueberries and raspberries!
Jan 10, 2013 | Baking
Need a manual for a schwinn bicycle speedometer SW645
If it is a Stewart Warner, check ebay, they are very old.
Jul 31, 2010 | Cycling
Wire my stewart-warner tach into a CHEV HEI ignition
Most HEI dist are labeled on the coil cover where the module/ power plugs in on the side of the cap It should be the only unused space there , unless you had a factory tach. You will need a plain female spade on you tach input wire and it should plug right in
Mar 14, 2010 | 1987 Chevrolet V30
My electric furnace has a strange odor.
your coil may have dirty sock, the coil at air handler (evaporator) needs to be cleaned with coil cleaner that will mask or remove the dirty sock smell
Oct 27, 2009 | Heating & Cooling
Stewart Warner Cessna 172 Oil Temp Cluster Gauge w/ Capillary Tube, 823255 Logo
Top Stewart Warner Sport & Outdoor - Others Experts
Are you a Stewart Warner Sport and Outdoor - Other Expert? Answer questions, earn points and help others
