Question about Mach Speed Computers & Internet
How to solve conflicts ' I/o. Ir , memory address
For the last 6 months or so my computer constantly crashing.
system info: conflicts in I/O , IR , and Memory address
system history: constant changes in hardware resourses ,conponents,
software enviroment.
  • al epps Jan 25, 2009
    The following conflicts appear as following;
    IRQ 21 via rev 5 or later usb universal host
    IRQ 21 via rev 5 or later usb " "
    IRQ 21 " " " " " " "
    IRQ " IRQ 21 via usb host controller
    President:
  • 2,559 Answers
Just change the IRQ setting to a non conflicting IRQ address.
To do this,
Start Device Manager:
  1. Click Start, point to Settings, and then click Control Panel.
  2. Double-click System, and then click the Device Manager tab.
loadTOCNode(2, 'moreinformation');
  • If there is a problem with a device, it is listed in the hardware tree under Computer. Also, the problem device has a symbol that indicates the type of problem:
    • A black exclamation point (!) on a yellow field indicates the device is in a problem state. Note that a device that is in a problem state can be functioning.
    • A problem code explaining the problem is displayed for the device.
    • A red "X" indicates a disabled device. A disabled device is a device that is physically present in the computer and is consuming resources, but does not have a protected-mode driver loaded.
    • A blue "i" on a white field on a device resource in Computer properties indicates that the Use Automatic Settings feature is not selected for the device and that the resource was manually selected. Note that this does not indicate a problem or disabled state.
    NOTE: Some sound cards and video adapters do not report all of the resources they are using to Windows. This can cause Device Manager to show only one device in conflict, or no conflicts at all. This can be verified by disabling the sound card, or by using the standard VGA video driver to see if the conflict is resolved. Note that this is a known problem with S3 video adapters and 16-bit Sound Blaster sound cards, or those sound cards that are using Sound Blaster emulation for Sound Blaster compatibility.
  • When you select a specific device in Device Manager and then click the Properties button, you see a property sheet. The property sheet has a General tab.
    Some devices may have other tabs besides the General tab. Not all property sheets have the same tabs; some devices may have a Resource tab, Driver tab, and Settings tab, or some combination of these.
    At the top of the property sheet, there is a description of the device. When you click the Resource tab, the window in the middle of the tab indicates which resource types are available for the selected device.
    The list box at the bottom contains a Conflicting Device list. This list indicates a conflict with an error code.
  • Use Automatic Settings check box. If Windows successfully detects a device, this check box is selected, and the device should function correctly. However, if the resource settings are based on Basic Configuration <n> (where <n> is any number from 0 to 9), it may be necessary to change the configuration by selecting a different basic configuration from the list. If the particular configuration you want for the device is not listed as a basic configuration, it may be possible to click the Change Settings button to manually adjust the resource values. For example, to edit the Input/Output Range setting:
    1. Click the Use Automatic Settings check box to clear it.
    2. Click Change Setting.
    3. Click the appropriate I/O range for the device.
  • If you click My Computer and then click Properties, you see a property sheet with a View Resources and a Reserve Resources tab.
    The Reserve Resources tab excludes a resource from use by Windows.
    The View Resources tab displays the resources that are allocated by Windows or inherited from a Plug and Play BIOS or PCI bus computer.
  • To disable a device in Device Manager, in Properties, on the General tab, clear to select the Disable in this hardware profile check box
Posted on Jan 25, 2009
  • 1,183 Answers
The problem could be a bad memory module. reseat your RAM or memory cards on the computer . The might get resolved . If you have two memory modules check with one .
Thanks
proton
    Sergeant:
    Champion:
  • 334 Answers
Get Ashampoo win optimizer 4 its free if you register at the website its free then you can clean your registry. It has no viruses. It works great i use it.
God Bless Greg
    Master:
  • 763 Answers
Try to format it and see also the manual of your motherboard if your specs is compatible with each other. try also scanning your computer with antivirus before doing format.
thank you for using fixya
CHARCOIS
  • 10,515 Answers
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Your posted problem may be addressed in a couple of methods:
  • ensure that your motherboard is ACPI compliant and if it is, ACPI enabled;
  • re-flash or update motherboard BIOS;
  • ensure that in the CMOS/BIOS settings & configurations, none of the IRQs are reserved;
  • clean the entire motherboard with particular attention to the PCI slots and devices installed in them;
  • a pencil eraser would be ideal to clean the little gold pins of the add-on cards/devices;
  • replace the Lithium CMOS battery.
Pls postback updates. Good luck and thank you for using FixYa.
    Genius:
  • 1,847 Answers
Issue seem to be with the memory card, try replace it with a new one.
  • 916 Answers
Check your BIOS settings and make sure there are no conflicting IRQ assignments.
Yellow light constantly flashes on all handsets
Yellow light constantly blinks on top of all the cordless phones
www.faqqq.com/.../yellow-light-constantly-blinks-on-top-of-all-the-cord...
Question Product: Panasonic KX-TG5432 Digital Dual Cordless Telephone Question Details: Yellow light constantly blinks on top of all the cordless phones The.
Panasonic KX-TGP550 Normal Status Lights
www.statuslights.com/panasonic/panasonic-kx-tgp550.html
Red (Rapidly Flashing), The Base Unit is paging handsets. (KX-TGP-500 only). Amber(Solid), The Base Unit's IP address may conflict with the IP addresses of ..
Jan 16, 2016 | Panasonic KX-TG7641M KX TG7641M KXTG7641M...
Scrabble page is constantly crashing on iPad
Have you got the latest updates? Email the software company to see if there are any patches to solve your issues!
Feb 08, 2015 | Electronic Arts SCRABBLE for iPad
Channel and volume changes all by itself on a sylvania lc320ssx
Sounds like a main system control memory IC fault. Contact any service technician, or authorized service center for Sylvania. Gopakumar Gopalan Google
Mar 07, 2014 | Sylvania Televison & Video
My hp compaq nx 6110 keeps hanging, what are the thing i can do to stop this hanging to permanently
For the starters I would suggest re-installing new Operating System. If that will not help, then there is a chance that you have faulty Hard Drive, RAM or even motherboard. In that case you will need to make diagnostics for all possible components or just give to repair shop.
Aug 17, 2011 | HP Compaq nx6110 PC Laptop
Have had dish for about 6 months with no problems today the remote stopped controling the receiver, it still wors ont he TV for volume and wwhat not but it wont change channels or pull up the guide. Looked...
It is possible that the remote simply needs to bere-addressed to your receiver. You can do this by pressing the 'System Info'button on your receiver (or access system info through the menu). Once thesystem info screen is pulled up, press the 'SAT' button on your remote once andthen press the 'Record' button. This should get your remote working with yourreceiver again.
Feb 01, 2011 | DISH Network IR Remote Control
Getting Disconnected
Either you hava an IP conflict (two devices use the same IP address eg printer/laptop/ ethernet adapter/ wlan card etc. etc.. Look at the device map and check all IP addresses, if in conflict: give another one manually. Ips like 192.168.1.1 can be changed by giving another number to the last "space" behind the point (192.168.1. (1-99). Every device must have a unique one. Vista normally does that but sometimles the IPs are preset andf cannot be changed by VISTA.
2nd possibility: You have an onboard "N/G" or "A" adapter and / or ethernat card and a USB or external WLan adapter, all activated in parallel. Makes the firewall go crazy, disconnects adapters constantly, which try to reconnect.Disdable all but one. Then enable one after the other to find the "impossible" combination or just use one.
Jul 26, 2010 | D-Link DIR-625 (790069292637) Wireless...
N79:d screen constantly changes colour n vibrates
The colour changing and dare i say it...vibration is the connection between the phone and the back. as you may know the n79 has chip in the back cover to tell the phone which colour to make the screen to match. Mine did this for months and months and then I changed the back and everything has been fine since then! Well apart from the fact that it crashes twice a day when i turn the keypad lock off and somehow i've smashed the lcd screen, but other than that all good!
Feb 03, 2010 | Nokia N79 Cellular Phone
Siemens Condensor Dryer E46-38. After a few
Mine is 4 years old and the pump went within 8 months! The dryer has had 6 new pumps in total! It was last fixed 6 months ago and now playing up again! I dont even constantly use my dryer! I am very disappointed with Siemens now, my last dryer lasted me 10 years and it was constantly on the go when my children were young! Here comes, tomorrow I have got to book another repair! No more Siemens for me.
Oct 20, 2009 | Siemens Dryers
Computer crashes constantly
I had the same problem. plus the battery went down fast. not knowing what to do i pulled the original 512 meg memory chip and installed a 2gig chip that i got at Fry"s. it has worked ever since.
Apr 01, 2009 | ASUS Eee PC 900 Notebook
Mozilla crash report
U must disable some stupid add-ons. Simply click :
1. START
2. all programs
3. Mozilla Firefox --> Mozilla Firefox Safe Mode
4. In the window that appears check DISABLE ALL ADD ONS and then hit the RESTART MOZILLA button
Worked for me after 2 long weeks without mozilla :)
Hope this helps
Nov 26, 2008 | Mozilla Firefox
Computers & Internet Logo
Top Mach Speed Computers & Internet Experts
David
David
Abhinandan  Patil
Abhinandan Patil
Iqbal Husain
Iqbal Husain
Are you a Mach Speed Computer and Internet Expert? Answer questions, earn points and help others
