Question about Radio Shack Pro-95 Handheld Scanner
Have PRO95 scanner lost showing readout of agencys on radio
Shows channels but not agency
    Habit-Forming:
  • 33 Answers
You need to Reset the display,
Turn off the Scanner, wait 10 seconds then turn it back on,
Now Insert a pointed object, such as a straightened paper clip, into the reset hole on the left side of the scanner above the PWR DC 9V jack.and hold it for 5 seconds.
The display should return to normal operation..
Note this will not erase the frequencies in the scanner it will reset the display processor.. Let me know how it goes.. :-)
Posted on Apr 07, 2009
Can no longer pick up local channels. Any ideas why?
weak batteries,possible bad antenna connection(remove and re install to get better connection)
Jan 23, 2016 | Uniden BC72XLT Handheld Scanner
How do I get the pro-2055 scanner to only hear the Trunking channels I want and by-pass the agencies I don't want to hear. I've programed the talk groups in but can't get it into an ID scan mode.
Hi, my name is John. Just L/O the ones you don't want, then SCAN..hope this was helpful Please rats this solution on the thumbs four thanks John
Sep 04, 2010 | Radio Shack Pro-2055 Base Scanner
Scanners
Your scanner has wide coverage and should already tune the frequencies used by your area law enforcement agencies. If you can't locate or tune them, chances are that your local agencies are using trunked radio systems, and your scanner is not capable of following such systems.
For a comprehensive database of active frequencies and systems in your area, and a lot of other useful scanning info, visit:
www.RadioReference.com
If you don't have the operating manual for your scanner you can download/print it here:
http://www.uniden.com/pdf/BC92XLTom.pdf
BillB
Feb 18, 2010 | Uniden BC92XLT Handheld Scanner
Unbearable noise after every radio message - squelch doesn't help
Doesn't sound like you're doing anything wrong. Either the scanner is defective or your locale is using some kind of oddball system that's causing the noise. Take it back, show them what it's doing. If possible, try another scanner in the store and see if it does the same thing. You should be entitled to a refund, exchange, or full credit towards a different model . . .
Jan 20, 2010 | Uniden BC72XLT Handheld Scanner
All digital trunked TGs are garbled. Can't hear
You may find the agencys are running encryption on their networks to prevent people from listening in depending on what country you are in and what agency's you are trying to listen to. To date i know that the encryption is very secure here in aus and cannot be broken or de scrambled
Jan 09, 2010 | Radio Shack Pro-96 Scanner
Need user manual for Uniden radio/scanner BC60xlt-1.
Follow the link below to download/print the manual for your scanner. You may or may not be able to hear the services you mentioned using this scanner due to its limited frequency coverage. Many public service agencies now transmit in the 800MHz range, and many have upgraded to trunked and even digital radio systems. I cannot find any reference to PCH LOCK, but an educated guess would be that it means all programmed channels are locked out. If none of the 10 channels contain programmed frequencies, displays will show 000.0000MHz, and all channels will be locked out. Programming a frequency into any channel should override the lockout. On the other hand, the message could indicate that this old scanner is tired and in need of replacement. Here's the link to your manual:
http://www.uniden.com/pdf/BC60XLTom.pdf
For a comprehensive database of active frequencies in your area, visit:
Jan 03, 2010 | Uniden BC60XLT-1 Handheld Scanner
Where can i get police frequencies for arkansas?
Hello there:
depending on what part of the state you live in this should help out a lot
  1. Central Arkansas Police Frequencies Central Arkansas Police. Benton Police. 154.580. Bryant Police. 155.565. 155.580. 154.680 new ... Shannon Hills. 37.220. Sheridan Police Dept. 155.640 ...www.skylord.com/kevin/central_police.html - Cached
  2. Northwest Arkansas Police Frequencies Northwest Arkansas Police. Bentonville Citywide Trunked System. 856.2625. 857.2625. 858.2625 ... Fayetteville Police Department 10-codes ...www.skylord.com/kevin/nw_police.html - Cached
  3. Arkansas State Police Scanner Frequencies and Radio Frequency ... Scanner Frequencies and Radio Frequency Reference for Arkansas State Police ... Arkansas State Police operations are conducted on this system. Frequency Display ...www.radioreference.com/apps/db/?aid=603 - Cached
  4. Arkansas Scanner Frequencies and Radio Frequency Reference Scanner Frequencies and Radio Frequency Reference for Arkansas ... Arkansas State Agencies. Frequencies for Arkansas public safety agencies. Choose Agency
  5. OK?
  6. best regards michael
Sep 28, 2009 | Radio Shack Pro-95 Handheld Scanner
Pro95 shows trunked freqs are being received, but no audio...
be foe you can recieve them in a closed mode you must input their talkgroup id if not you will not recieve anythang also remember to set your mode to Mot for motorola, fm is foe conventional, am is for aircraft...ect. in the oppen mode you will pick up everthing and their neighbor that uses the frequency set. hope this helps
Jun 01, 2009 | Radio Shack Pro-95 Handheld Scanner
Locking in to my local police dept
they should have sold you the book with all the codes for law enforcment agencies so you can program all the codes u want to hear
Feb 22, 2009 | Radio Shack Pro-95 Handheld Scanner
I'm tring to find codes for a police scanner for henderson,ky.
RadioReference.com is the world's largest radio communications reference website, featuring a complete frequency database, trunked radio system information, FCC License assignments and callsign maps, 10-Code Lists, agency maps, files, downloads, links, and detailed agency information for most public safety, military, and local government communications.
Best of all, registration and access to all the data is free, however some special reporting features and downloads are only available to Premium Subscribers of the site.
that should solve your problem
Jan 11, 2009 | Radio Shack Pro-95 Handheld Scanner
Radio Shack Pro-95 Handheld Scanner Logo
135 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
