Question about Mr. Heater Big Buddy Heater
Mr heater fan starting to make noise when starting
    Master:
  • 996 Answers
Needed lubrication for fan motor shaft
Posted on Dec 11, 2014
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 81 Answers
Try taking apart fan housing & look to see if fan blade is scraping the housing. next look to see if fan blade is secure to fan motor shaft.next look to see if fan motor bearings are worn egg shaped and try oiling fan motor bearings with sae 30.
somewheres amoung all this inspecting of the fan motor, you will find the cause of the problem and learn what new parts you may need to buy to fix it.
Posted on Oct 07, 2013
The on & off switch for the fan----the switch on or off which position is correct
I have the "Big Buddy" heater and the switch is on top, if it is clicked down toward the front of the heater, the fan is on (little yellow dot), pushed back, the blower is off.
Nov 06, 2015 | Mr. Heater Mr Heater Portable Buddy...
MR HEATER FAN NOT WORKING
Fan or its operating circuit may be faulty
Feb 26, 2014 | Mr. Heater Heating & Cooling
Im on my 2nd big buddy and both of them the fan has gone out, the first on went in a week, and this one last a couple of months.
fans
1. oil the bearings,sae 30 or wd40 for places you cant get into.
dont take fan motor apart unelse you realy have to.
dont let your fan motor bearings get worn egg shaped from lack of oil.
2. make sure fan blades not hitting or scraping fan housing and fan blades are securely fastened to fan motor shaft.
3.mr heater fan motor is 12 volts DC , so it may have a segmated comutator and brushes.
I dont know because i have not yet needed to take my mr heater
fan motor apart but i have worked on hundereds of ac fan motors
in the past 65 years.
4. keep fan motors from getting wet. they hate water.
5. keep fans clean, they dont like foriegn materials.
Your specific problem: first fan 2 weeks,second fan 2 months.
how much you use them, are you wearing the brushes down?
Getting fan motor wet? foreign material getting pulled into fan or fan motor? off/on switch work ok. batterys good,battery contacts ok? fan transformer 110 vac to 12 vdc good? fan bearings oiled?
need more info to diagnose properly.
all of the above needs to be checked out to tell whats happened.
fan & fan motor needs to be inspected.
Feb 21, 2011 | Mr. Heater Big Buddy Heater
Mr slim heater fan won't start
Check fan contactor energized or power to contactor is o.k.
Dec 14, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Mr Heater MH12T noise and little difference in heat settings
HI Check out mr heater wed site there has been some recalls on some of there heaters if not take it back .............
Feb 09, 2010 | Mr. Heater MH9B Ceramic Utility
My mr heater mh9b won't stay lit. The pilot flame starts acting wierd and making noise after ten to fifteen minutes of being lit and then goes out completely. It can be re-lit but goes out again in a...
my mr heater mh9b won't stay lit. The pilot flame starts acting wierd and making noise after ten to fifteen minutes of being lit and then goes out completely. It can be re-lit but goes out again in a bit. Any suggestions?
Nov 17, 2009 | Mr. Heater MH9B Ceramic Utility
Mr heater tank top '' singing ''
I have the same situation. It could be in the regulator. My sounds off when first starts and then I reduce it to low and it stops. Maybe use the low setting and see what happens. If not return it and try a 2 burner instead of the single unit.
Nov 06, 2009 | Mr. Heater Model MH12TS - Single Tank-top...
Heating & Cooling Logo
314 people viewed this question
Top Mr. Heater Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Mack Baxter
Are you a Mr. Heater Heating and Cooling Expert? Answer questions, earn points and help others
