Question about Panasonic KX-TG5622M Twin Cordless Phone
No dispaly on screen.
I have Panasonic KX-TG5622 cordless phone . about one year lod. last two day suddenly there is NO display at all on LCD sreen ( not showing dialed number .screen is just blank all time ) phone is working, try to replace battery...no result . Any help will be appreciated . Thanks Sincerely Praful Parikh
  • Anonymous May 12, 2009
    SAME AS PREVIOUS USER
    New Friend:
This is how I fixed mine:
http://hackaday.com/2009/06/20/repair-a-malfunctioning-lcd/
There are also YouTube videos showing the same thing. This is a common problem with Panasonic LCDs on cordless phones.
Posted on Jul 30, 2017
    Novelist:
  • 201 Answers
Three possibilities. 1) The LCD screen is cracked from a fall or hit etc.. It can be visible or a small crack hidden on and edge or corner, only visible after taking out the display. 2) The phone was exposed to moisture or high humidity long enough for corrosion to start. This could have happened many months ago. The corrosion has finally effected the LCD. If you're up to disassembling the phone you can clean the LCD connector with rubbing alcohol and a tooth brush as well as clean the LCD cable itself with a pencil eraser. Typically the LCD is held in with a little 2-color connector that you open with a tiny screwdriver or other tool by carefully prying off each side of the connector a little bit. (1-2mm) when you are done just slide the lcd connector in all the way and push the connector back in. 3) It's unlikely but the LCD can just stop working. It's not worth paying $30 to $50 for a new one. Just replace the phone.
Posted on Jul 12, 2007
I fixed mine by opening the handset case, and discovering that nothing was wrong or corroded, except that one of the charger contacts (the big and shiny long ones at the bottom of the handset) was a little loose. The two screws at the bottom of the circuit board also hold the contacts in place. Make sure they're tightened if they seem even a tiny bit loose.
The LCD was totally fine, and my contact ribbon for that was held in by tape and glue, so there was no way to check for internal corrosion KX-tga560m.
Posted on Jul 15, 2008
Blank display screen
I got my display to come on while on the base unit, by making charging contacts connect. When I did this, then battery indicated it was low, then though I had taken it out a working phone. Maybe the fact is one of charging units are not charging correctly if have several. I have a 3 system unit and it is the base that seems to have the problem.
Aug 28, 2013 | Panasonic KX-TG5622 Phone
How to set up voicemail on kx tg5622
You may download a copy of the manual here.
The KX-TG5622 isn't an answering machine. If you have voicemail service offered by your telephone service provider, contact your service provider for instructions on accessing and setting up the voicemail system. See page 32 of the manual.
Jan 30, 2013 | Panasonic KX-TG5622 Phone
Can the lcd screen be replaced on a panasonic KX-TG5240 cordless phone? are these lcd screens available?
Return it under warranty. They will send you a new one.
http://www.panasonic.com/uk/support/warranty-information.html
Aug 03, 2011 | Panasonic GigaRange KX-TG5240M Cordless...
I have purchased KX-TG5622 from singapore and ins...
Only stupids buy cordless phone from Singapore. India uses ETSI DTMF standard for Caller ID which is not supported by any cordless phone sold in Singapore. It is about time you trash your worthless instrument in the dumpster.
May 20, 2010 | Panasonic KX-TG5622M Twin Cordless Phone
Can I register a panasonic kx-tg55438 handset to a kx-tg5622 base
No, The kx-tg 5622 uses only the kx-tga560 (2 of them) for its cordless sets
Jan 07, 2010 | Panasonic KX-TG5622 Phone
Nothing shows up in the display. This has only been recently after a power glitch. The display lights when a call is made or received.
I unplugged the base unit from the wall for more than 10 minutes. Sometime after I plugged it back in (not immediately)the display re-appeared.
Nov 16, 2009 | Panasonic KX-TG2631 Cordless Phone
Display light is on but the words don't show up.
Dear a1trkr,
Press the menu button on the handset and type in (1) (4) (5) THen press 1-6 for LCD Contrast.
Hope that works! I have a panasonic and I love the clarity and range.
Best of Luck, The Writer.
Jun 02, 2009 | Panasonic KX-TG9331T Cordless Phone
KX-TG6051B panasonic cordless phone - lcd screen doesn't work
I am just now having the same problem tried everything short of taking it apart. got six years out of it.
Nov 01, 2008 | Panasonic KX-TG5632 Phone
KX-TG 1100SP CALLER INFORMATIONNOT DISPALYED
check page 18 from your user guide (or at "http://phone.manualsonline.com/mdownloads/2a9697eb-f1f9-a434-457a-98ab6de1d9cc.pdf" if you don't have the book), your security code may not be set. good luck!
Feb 26, 2008 | Panasonic KX-TG1100 Cordless Phone
Handset voice very low and LCD display is blank
My 1740 handset volume was also low. As a shot in the dark I changed the speaker and it fixed the problem. I got a new speaker from www.panasonic.com .
Feb 11, 2007 | Panasonic KX TC1740 Cordless Phone
Panasonic KX-TG5622M Twin Cordless Phone Logo
607 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
